This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
It's important to note that the device's firmware version is distinct from the WiiM Home App version. To check your device's firmware version, open the WiiM Home App, go to the 'Device' tab, tap the 'gear icon (Cog Wheel)' for device settings, select 'Device Info', and then view 'Firmware Version'.
5.2.829661 (Latest)
Release date: September 17, 2026
What's New
1.
SoundCloud: Added support for seeking within tracks.
2.
Google Cast: Added support for WiiM multi-room playback and wireless WiiM Sub Pro output.
General Improvements
1.
Network: Improved Ethernet stability and IPv6 address handling.
2.
TIDAL Connect: Reduced playback stuttering.
5.2.827567
Release date: August 27, 2026
Audio & Playback
1.
Soundtrack: Updated the SDK to improve playback stability and performance.
2.
Multi-Room Playback: Improved synchronization and playback stability during multi-room playback.
3.
Spotify Connect: Fixed pop noise when skipping tracks and Prevented certain speakers from leaving the group when starting playback.
5.2.826052
Release date: August 12, 2026
Audio & Playback
1.
Spotify Connect: Fixed popping sounds when skipping tracks.
2.
Dolby Digital: Fixed playback stuttering under fixed-resolution output of 24-bit/192kHz.
Bug Fixes
1.
Volume Control: Fixed the volume jumping to 100 after a long press on the remote.
2.
Qobuz: Fixed playback stopping when loading high-resolution artwork.
5.2.824843
Release date: July 31, 2026
New Features
1.
Auto Headroom: Added automatic headroom adjustment to help prevent audio clipping. Turn it on or off in the latest WiiM Home app. Learn More >>
2.
Amazon Alexa: Added an on-screen animation when interacting with Alexa.
3.
Standby Display: Added the option to select a standby wallpaper by touching and holding it on the device screen. Learn More >>
4.
Subwoofer Calibration: Automatically aligns the subwoofer’s volume level with the main speakers at the listening position. Learn More >>
Audio & Playback
1.
Multi-Room Audio: Improved audio quality during multi-room playback.
2.
3.
Google Cast: Updated the SDK to improve playback compatibility across music streaming services.
4.
iHeartRadio: Added FLV support to enable playback for certain radio stations.
5.
Sound Machine: Fixed an issue where playback could stop unexpectedly.
6.
Open Network Stream: Fixed an issue where playback might not resume after a long pause.
7.
Bluetooth: Reduced playback stuttering and ensured the Bluetooth name updates after renaming the device.
8.
Spotify Connect: Reduced playback stuttering.
Bug Fixes
1.
Date Display: Fixed an issue where an incorrect date could appear on the device screen.
2.
USB Media Library: Fixed an issue where newly added files might not be detected during a rescan.
3.
Standby Source Mode: Prevented switching to HDMI when no HDMI cable is connected.
5.2.818432
Release date: May 29, 2026
Playback & Audio Improvements
1.
Dolby Playback: Fixed audio stuttering issues with Dolby bitstreams.
2.
Optical In: Optimized playback stuttering issues.
3.
WiiM Radio: Added support for WiiM Radio (requires the latest app version)
4.
Amazon Music: Fixed an issue where Amazon Music could skip tracks unexpectedly.
5.2.817334
Release date: May 18, 2026
New Features
1.
Simultaneous Audio Output: Supports COAX or Optical output together with Line Out, configurable in the WiiM Home app.
2.
TV Remote Volume Step: Allows volume step adjustment when using a TV remote, configurable in the WiiM Home app.
3.
Automatic Updates: Adds support for delaying automatic firmware updates, configurable in the WiiM Home app.
Audio & Playback
1.
Audio Input Latency: Reduces audio input latency to approximately 35–40 ms.
2.
VU Meter & Spectrum Display: Fixes stuttering when switching display modes.
3.
Playback Stuttering: Reduces stuttering during music playback.
4.
USB Library: Fixes special character display issues; Improves scanning speed and stability (requires upcoming app update)
5.
Qobuz: Fixes a crash issue when using Qobuz.
1.
OOBE Setup Status: Displays the setup mode status during OOBE.
2.
Time Display: Fixes incorrect Egypt daylight saving time display.
3.
Audio Input Switching: Improves the speed of switching between audio inputs.
5.2.813259
Release date: April 8, 2026
Highlights
1.
Sub & Main Speaker Sync: Automatically aligns subwoofer and main speakers for improved timing at the listening position.
2.
Per-Input Screen Control: Enable or disable the screen display for each input mode.
3.
Headphone EQ: Added independent EQ for headphone output optimization.
4.
Standby Source Mode: Automatically switch to a selected input when entering standby, enabling instant playback.
5.
6.
Surround Setup: Simplified setup with full backward compatibility. (requires upcoming app update)
Screen
1.
Playback Screen: Added a vinyl-style playback screen for a more immersive experience.
2.
Localization: Added French language support.
Playback & Audio
1.
2.
Line In: Fixed distortion during extended playback sessions.
3.
Bass Output: Fixed low bass levels for Apple TV (Dolby 5.1)
4.
Audio Sync: Improved sync accuracy at microsecond level for better group playback (requires upcoming app update)
Radio & Streaming Services
1.
2.
3.
4.
Deezer: Fixed unexpected playback interruptions.
1.
2.
HDMI ARC: Disabling automatic audio output now correctly keeps WiiM in standby and defaults to the TV speakers.
3.
4.
Audio Input: Fixed playback crash issues.
5.
Remote: Fixed occasional disconnection and unexpected max volume issues.
6.
Alarm: Fixed incorrect alarm and preset volume behavior.
7.
Roon: Fixed occasional crash issues.
8.
EQ: Enables EQ for Dolby 5.1 playback.
9.
Alarm: Fixes BBC and vTuner alarms defaulting to the chime.
10.
Spectrum Display: Improves dynamic visualization.
11.
5.2.809035
Release date: February 28, 2026
Display & UI
1.
Per-Input Now Playing: Customize the Now Playing screen for each input source.
2.
New Cover Layouts: Added larger album-art views for a more immersive playback screen, with Home and Music Source icons hidden.
3.
Dolby Visuals: VU Meter and Audio Spectrum now work during Dolby playback.
Playback & Audio
1.
Optical In: Fixed dropouts caused by input stream format changes.
2.
Short-Track Transitions: Improved near-end handling to prevent skipping or audio “leakage.”.
3.
Track Skips: Resolved multiple cases of unexpected skipping / premature track changes across services.
1.
Live Metadata: Added ICY support for richer “now playing” info on TuneIn, iHeartRadio.
2.
Qobuz: Added Track Radio / Artist Radio / Album Radio.
3.
vTuner: Improved reliability with backup stream URL fallback.
4.
SoundCloud: Added third-party login support.
5.
TuneIn: Fixed alarms occasionally starting late or failing to start playback.
6.
iHeartRadio / Pandora: Fixed intermittent stops and unexpected skipping.
7.
Napster: Fixed My Music playback failures, incorrect station controls, and a disconnect-on-no-internet crash.
8.
Plex: Fixed alarm progress display, station history playback failures, and occasional early skips.
9.
Amazon Music: Fixed interruptions when playing short playlists.
USB & NAS
1.
USB Notifications: Added connect/disconnect pop-ups.
2.
Faster Browsing: Reduced app timeouts when browsing USB drives.
3.
NAS Playback: Fixed playback and display issues for NAS sources.
5.2.804553
Release date: January 14, 2026
What's New
1.
Plex Remote Access: You can now stream from your Plex media server over a wide-area network (remote connection)
2.
Localization: Added German language support for the device screen.
User Experience & Interface
1.
Faster Setup: Optimized the Wi-Fi onboarding flow for reduced setup time. Added a "Cancel" option and clearer device name display during the process.
2.
Screen Enhancements:
  • Volume Feedback: The screen now wakes to show the volume bar when adjusting volume, even if the display was off.
  • Responsiveness: Fixed a display delay when switching inputs via the remote.
  • Source Switching: Improved the switching speed when changing between different audio inputs.
Audio & Stability
1.
Streaming Stability:
  • TIDAL Connect: Fixed an issue causing random playback stops.
  • Amazon Music: Resolved an issue where playback occasionally failed to start.
  • TuneIn: Fixed playback issues specific to NPR podcasts.
2.
System Performance:
  • USB Library: Fixed a potential memory issue (OOM) during large library scanning for better stability.
  • DAC Settings: Refined the logic for default DAC filter selection.
  • Alarms: Fixed a bug where alarm presets would not stop playing after the set duration ended.
5.2.739061
Release date: December 18, 2025
Bug Fixes
1.
Multiroom: Fixed an issue preventing multiroom setup with some routers.
2.
Google Cast: Fixed missing subwoofer bass output and EQ not working.
5.2.738432
Release date: December 12, 2025
1.
Wi-Fi: Stronger connection stability; improved compatibility with Wi-Fi 7 routers.
2.
Sync Audio: More accurate calculations at low volume.
3.
Audio Spectrum: Better timing alignment with playback.
Music Services
1.
Qobuz: Stabilized progress bar; fixed shuffle dropouts, playback-mode mismatch, and missing artist/track metadata.
2.
Soundtrack: Updated SDK; fixed disconnects when renaming the device during playback.
3.
SoundCloud: Fixed playback stops, genre-preset failures, and unexpected logouts.
4.
Plex: Added remote streaming over WAN.
5.
Amazon Music: Fixed position reset after back-to-back seeks.
6.
USB Library: Fixed disappearing album art.
7.
NAS: Fixed missing metadata.
8.
TIDAL Connect: Fixed playback interruptions after ~1 hour.
Playback Enhancements
1.
Local files: Automatically skips unplayable tracks to continue playback.
2.
Seeking: Fixed next-track failures when seeking in the last 5 seconds.
3.
Stability: Reduced intermittent dropouts via synchronization optimizations.
4.
Resumption: Music now returns to the foreground after alarms or timers.
5.
Queue: Fixed crashes related to queue management and multiroom group naming.
6.
Radio: Resolved failures for certain station formats.
Bug Fixes
1.
USB Out: Fixed a power issue that blocked standby while using USB output.
2.
EQ: Fixed a rare exception that caused no sound.
5.2.736552
Release date: November 24, 2025
What's New
1.
Now Playing: Added Audio Spectrum visualization. Requires WiiM Home app v3.4.0+.
2.
Queue: Better track order retention in shuffle and faster queue operations across NAS/USB/Samba/Local, TIDAL, Qobuz, Radio Paradise, YouTube, Deezer, and SoundCloud.
3.
Multi room: Improved multicast logic for more reliable discovery/connectivity; reduced stutter when using Bluetooth input.
Bug Fixes
1.
Google Cast: Device now retains its assigned room after reboot.
2.
Spotify Presets: Start on first press (no second trigger needed)
3.
Playback Stability: Fixes for TuneIn Radio and certain FLAC files.
4.
USB Library: Resolved missing albums when indexing large collections.
5.
USB Out: Playback now auto resumes.
6.
Screen/UI: Fixed overlay artifacts and occasional failures to load Now Playing or Standby screens.
7.
VU Meter: Restored operation with Dolby audio in multi room playback.
5.2.734250
Release date: November 1, 2025
Bug Fixes
1.
Alarm: Corrected behavior in Daylight Saving Time zones.
2.
3.
Qobuz Connect: Fixed a crash that could occur after seeking.
4.
Amazon Music: Fixed unexpected stops when using Amazon Music Cast.
5.2.733343
Release date: October 23, 2025
What's New
1.
Headphone Out: “Fixed Volume” is now off by default.
2.
Alarms: Custom labels and up to 32 alarms(requires the upcoming app update)
3.
Logitech Media Server (LMS): Disabled by default; enable in Device Settings in the WiiM Home app.
4.
12V Trigger: Status now shown in the app; supports a one time on/off toggle from the app(requires the upcoming app update)
5.
USB Media Library: Create, delete, and manage playlists (add/remove tracks) on USB storage(requires the upcoming app update)
6.
TuneIn: Faster start when playing Apple Music stations.
Bug Fixes
1.
Playback: Corrected playback state display in certain cases.
2.
Bluetooth: Restored auto reconnect after reboot in Bluetooth mode.
3.
Sub Output: Fixed missing bass when the wireless WiiM Sub Pro was disconnected.
4.
Qobuz Connect: Resolved a blocking issue that prevented playback.
5.
Spotify: Fixed failures to play from the Spotify app’s Recommended lists and Recently Played; also fixed presets that would not start playback.
6.
Amazon Music: Fixed occasional track skips after seeking and a progress bar desync (bar reached the end while audio continued)
7.
Multi-room: After ungrouping, metadata no longer syncs to previously grouped (child) speakers.
8.
Gapless Player: Fixed a near track end race condition that could trigger overlapping/simultaneous playback.
9.
Local Files: Fixed an issue where the app progress bar reached the end before playback finished.
5.2.730566
Release date: September 28, 2025
What's New
1.
Smarter VU Meter
  • More accurate readout of your output levels.
2.
Amazon Music
  • Faster resume after long pauses and improved casting stability from the Amazon Music app.
Bug Fixes
1.
Dolby Audio
  • Eliminated playback noise and fixed subwoofer no-sound cases.
2.
USB Library
  • Refined image resizing for crisper album art.
3.
Pandora
  • Resolved track skipping after resume and login failures.
4.
Alarms
  • Station-based alarms now trigger reliably.
5.
TuneIn
  • Apple Music radio via TuneIn now resumes after long pauses; reduced radio playback failures.
6.
LMS
  • Correct bitrate display for radio streams.
7.
KKBOX
  • Fixed playback interruptions and corrected bitrate reporting.
8.
General
  • Stability, performance, and other minor fixes.
5.2.728233
Release date: September 3, 2025
What's New
1.
Enhanced VU Meter: Smoother and more responsive visual performance.
2.
TuneIn: Automatically selects the highest-quality stream.
3.
  • Added Spotify Connect support in Recently Played.
  • Presets now visible even without internet.
  • Device name displayed on the Home page.
  • Bluetooth connection status added.
  • Enlarged playback control button touch area.
4.
Audio Input Enhancements: Provided the plugged-in status and audio detection to the app for real-time display.
5.
Headphone Output: Disabled RoomFit™ profile when using headphone output.
6.
Smart DNS Enhancement: Improved Smart DNS by checking server accessibility for smoother streaming.
Bug Fixes
1.
YouTube Music: Fixed playback noise and incorrect metadata.
2.
TIDAL Connect: Corrected metadata display.
3.
Qobuz Connect: Fixed the issue where gapless playback was not working.
4.
Google Cast: Fixed occasional no-sound issues.
5.
HDMI ARC: Fixed unexpected switching to ARC during music playback.
6.
USB Indexing: Fixed garbled Chinese character display.
7.
SoundTrack: Fixed missing audio during the first two seconds of announcements.
8.
YouTube Music Group Playback: Fixed no-sound issue when switching to group playback.
5.2.726135
Release date: August 13, 2025
What's New
1.
YouTube Music: Native, seamless streaming support.(requires the upcoming app version 3.3.1)
2.
Soundtrack SDK Upgrade: Under-the-hood improvements for a smoother, more consistent listening experience.
Bug Fixes
1.
Bluetooth Output: Fixed a no-audio issue after switching outputs.
2.
NAS & USB Playback: Playback now correctly restarts from the beginning after the last track finishes.
3.
Playback Speed: Resolved rare cases where songs played at accelerated speed.
4.
Dolby Digital: Corrected low volume when playing Dolby Digital content.
5.2.725647
Release date: August 8, 2025
What's New
1.
Room Correction & EQ Integration: Room Correction and EQ now work together to provide an optimized listening experience. Learn More >>
2.
3.
  • Corrected highlight behavior for Local Radio and Recently Played.
  • Expanded the tap area for easier Preset selection.
  • Ensured full display of Presets and Recently Played content.
4.
Amazon Music: Bitrate information is now displayed when streaming Amazon Music Prime.
5.
Sub Pro Intergartion: Improved pairing experience and overall functionality when using the Sub Pro.
Bug Fixes
1.
Alarm Fixes:
  • Resolved an issue where weekly alarms occasionally failed to trigger.
  • Fixed a bug where only the default tone played for Pandora alarm.
2.
Dolby Audio Fixes:
  • Fixed no-sound issues when playing Dolby audio in multiroom setups.
  • Corrected volume balance behavior for Dolby audio.
3.
USB Indexing Fix: Corrected garbled character display for Chinese.
4.
USB Output Fixes:
  • Resolved no-sound issues after reconnecting a USB DAC device when using Google Cast, TIDAL Connect, Spotify Connect, or Qobuz Connect.
  • Fixed audio stuttering when playing at 44.1kHz or 48kHz sample rates.
5.
Playing Status: Corrected the playback status indicator when no music is playing.
6.
Qobuz: Now displays the correct artist name in the app during playback.
5.2.723250
Release date: July 15, 2025
What's New
1.
Smart DNS Enhancement: Improved Smart DNS behavior by checking the legitimacy of the DNS server returned by the router.
2.
HDMI ARC Upgrade:
  • Eliminated pop/crackle noises.
  • Added Auto-Sensing for instant TV-audio pickup.
  • Improved the stability of ARC connections.
3.
Advanced Parametric EQ: High-Pass & Low-Pass filters now available (App v3.2.6+ required)
4.
Deezer: "Play Next / Play Last" options added.
5.
Bluetooth: Adjustable latency for perfectly synced audio.
Bug Fixes
1.
Soundtrack Pairing: Fixed an issue preventing successful soundtrack pairing.
2.
Gapless Playback: Fixed an issue causing incomplete audio playback.
3.
USB Indexing: Corrected the extraction of PNG format covers from MP3 files and fixed a crash issue that caused playback to stop.
4.
Qobuz Connect: Fixed an issue where playback would automatically resume after pausing when using USB output.
5.
Phono Input: Resolved a no-sound issue when editing input mode via the app.
5.2.721349
Release date: June 27, 2025
What's New
1.
Time Sync: More robust NTP timing for music service login.
Bug Fixes
1.
USB Search and Indexing: Resolved compatibility issues causing incorrect album indexing and search failures in the WiiM Home app.
2.
Empty Radio Fix: Resolved the issue where no radio stations were displayed on the Radio widget on the device screen.
5.2.720535
Release date: June 19, 2025
What's New
1.
Smart DNS: Enables faster playback startup and smoother streaming.
2.
3.
Playback Screen Options: Added 3 new styles with large title display (requires upcoming app update)
4.
Playback Enhancements:
  • Faster startup for Amazon Music.
  • Reduced interruptions on HDMI ARC and Optical inputs.
5.
Screen Updates:
  • Displays full artwork for certain MP3s.
  • Shows album name on playback screen.
  • Fixed alias name display on VU Meter.
6.
USB Indexing: Now uses album artist metadata for better organization.
7.
System Optimization: Reduced CPU load during simultaneous Sub and USB output.
5.2.719248
Release date: June 6, 2025
What's New
1.
Soundtrack SDK Enhancement: Upgraded for a better listening experience.
2.
Screen Enhancement: Always displays current playback metadata while playing radio.
3.
TIDAL Playback Enhancement: Improved playback stability and smoother performance for TIDAL and TIDAL Connect.
5.2.718554
Release date: May 30, 2025
What's New
1.
Pandora Thumbs Up/Down: Instantly like or dislike tracks from your WiiM Ultra (requires app v3.2.2+)
2.
Enhanced Display UI:
  • Access the complete BBC Radio station list seamlessly.
  • Fixed empty local radio station issue in specific regions.
3.
Dolby 5.1 Improvements: Support the center speaker and easily route .1 sub-channel audio to your subwoofer.
4.
Spotify Connect Continuity: Seamlessly resume Spotify playback after switching inputs.
5.
Upgraded Soundtrack SDK: Enhanced audio processing for superior sound quality.
Bug Fixes & Enhancements
1.
Resolved playback freezing with large Deezer playlists.
2.
Improved sync and loop modes for LMS and Qobuz Connect.
3.
Eliminated unexpected playback stops on Qobuz.
4.
Reduced CPU usage during EQ adjustments and subwoofer output.
5.
Input switching order now matches WiiM Home app.
6.
General stability and performance enhancements.
5.2.717053
Release date: May 15, 2025
What's New
1.
New Radio Widget: Quickly select and play a radio station directly from the screen.
2.
Audio Input Management: Choose which audio inputs to display and switch between them easily.
3.
Improved Group Playback Sync: Fixed synchronization issues that occurred after applying subwoofer and main speaker delay calibration.
4.
Enhanced DSD Playback: Resolved stuttering during multi-channel DSD file playback for smoother high-res listening.
5.
Group Mute/Unmute via Group Lead Device: Instantly mute or unmute the entire speaker group directly from the group lead device for seamless group control.
6.
Device Discovery Enhancements: Improved stability and connectivity for WiiM Home, Spotify and TIDAL apps.
7.
Knob Volume Step: Adjust the volume step when rotating the knob (requires the upcoming app update)
Bug Fixes
1.
A/V Sync Optimization: Enhanced audio/video synchronization for HDMI ARC to improve lip-sync accuracy.
2.
Plex Playback Fix: Resolved playback failure when Secure Connections is set to "Required".
3.
Standby Mode Fix: Resolved an issue preventing the device from entering standby mode when in follower mode.
4.
TIDAL Connect Fix: Addressed the issue of track skipping delay and corrected track duration when using the HTTP API.
5.
General Performance: Stability improvements and behind-the-scenes optimizations.
5.2.715362
Release date: April 29, 2025
Bug Fixes
1.
Reverted HDMI behavior: auto-switches to HDMI when other inputs stop. Power-off CEC option to be added in next release for standby mode.
2.
Playing Queue Fix: Now displays full queue for playlists over 1000 tracks (previously limited to 50)
5.2.714249
Release date: April 18, 2025
What's New
1.
Smarter HDMI ARC: Your WiiM Ultra will no longer act as a TV speaker when not in HDMI mode—giving you more control. Learn More >>
2.
DLNA Casting: Stream audio to any DLNA-enabled speaker for flexible whole-home listening. (Let us know if you run into compatibility issues!). Learn More >>
3.
Track-End Sleep Timer: New option to pause playback at the end of a track—perfect for winding down. (Requires app update: iOS 3.1.9 / Android 3.1.8)
4.
Auto-Resume Playback for Soundtrack: Playback resumes automatically after OTA updates, reboots, or network reconnections.
5.
Enhanced VU Meter: Smoother, more responsive visual performance.
6.
Group Volume via TV Remote: Control group volume directly using your TV remote.
7.
Screen Display Improvements: Input alias names now display correctly on the device screen.
8.
Wi-Fi Boost: Faster network scanning and connection times.
9.
Roon Sync: Improved multi-room sync for Roon users.
Bug Fixes
1.
Amazon Music: Fixed playback issues for Prime users.
2.
Spotify Presets: Resolved unexpected ungrouping during group playback.
3.
TIDAL: Fixed skipping, playback errors, and incorrect quality cap on 24-bit/96kHz optical/coax outputs.
4.
Qobuz: Fixed track-start issues after skipping and unexpected playback jumps.
5.
Radio Paradise Enhancements: Resolved issues with track repetition during playback and fixed login failures caused by special characters.
6.
Alarm Fix: Resolved issues affecting alarms in Daylight Saving Time zones.
7.
5.2.711448
Release date: March 21, 2025
What's New
1.
HDMI ARC & Optical In Improvements: Now correctly displays bit-depth information for HDMI ARC and Optical In sources.
2.
TIDAL Queue Enhancements: Improved shuffle functionality with track order retention and faster queue performance.
3.
TIDAL Auto Play: Now supports auto-play; enable it in the WiiM Home App.
4.
Spotify Loudness Normalization: Added support for Spotify's Loudness Normalization (requires WiiM Home App v3.1.5 for iOS, v3.1.6 for Android)
5.
Enhanced Radio Paradise: Added Serenity, Radio 2025, and My Favorites Mix stations with track-skipping support.
6.
Optimized CPU Performance: Reduced CPU usage for EQ processing and USB output, improving efficiency.
7.
Improved Presets in Group Playback: Presets now function correctly when the device is in follower mode.
8.
Device Discovery Enhancements: Improved stability and connectivity for WiiM Home, Spotify, and TIDAL apps.
9.
Soundtrack SDK Upgrade: Enhanced performance for a smoother listening experience.
10.
Playback Fixes: Resolved multi-room audio crashes and fixed a skipping issue at the end of some MP3 files.
11.
  • Improved VU Meter: Smoother and more accurate visual response.
  • Smarter Display Behavior: Screen stays off when turned off, unless tapped.
  • Extended Auto-Switch Time: Playback screen now appears after 15 seconds of inactivity.
Bug Fixes
1.
KKBox Playback Fix: Resolved the playback skipping issue.
2.
General Fixes: Made several performance improvements and fixed miscellaneous bugs.
5.2.709956
Release date: March 6, 2025
What's New
1.
Dolby 5.1 Surround: Enjoy wireless, low-latency Dolby 5.1 surround sound for an immersive audio experience. Learn More >>
2.
Recently Played Widget: Quickly access your listening history directly from your device screen.
3.
Soundtrack SDK Enhancement: Upgraded for smoother performance and an improved listening experience.
4.
Headphone Output Level Adjustment: Customize the headphone output level to match your headphones (requires an upcoming app update)
5.
Device Discovery Improvements: Enhanced stability for WiiM Home, Spotify, and TIDAL apps, improving device detection and connectivity.
6.
Wi-Fi Update: Updated Wi-Fi drivers for better router compatibility and improved connectivity stability.
7.
USB Indexing Enhancements: Improved album indexing for a better browsing experience (requires an upcoming app update)
8.
Clock Position Customization: Adjust the clock position on your device screen to suit your preference (requires an upcoming app update)
9.
VU Meter Mode: Choose whether the VU Meter reflects the original signal or output signal level (requires an upcoming app update)
Bug Fixes & Performance Improvements
1.
Preset Playback Fix: Resolved an issue where playback stopped unexpectedly when selecting an empty preset.
2.
Qobuz Login Fix: Fixed an intermittent issue preventing Qobuz logins.
3.
USB Output Detection: Addressed a bug where the USB sound card was not being detected.
4.
Deezer Alarm Fix: Fixed an issue where Deezer Mix alarms were not functioning properly.
5.
General Enhancements: Improved overall stability, performance, and bug fixes.
5.2.708441
Release date: February 22, 2025
What's New
1.
Per-Source Group Audio Delay: Adjust group delay independently for each input source in multiroom audio.
2.
Preset Enhancements:
  • Move presets (requires app v3.1.4)
  • Presets now work in follower mode.
3.
  • Smoother HDMI ARC playback.
  • Fixed incorrect playback status and Replay Gain issues after seeking.
  • Resolved Audible playback issue via Alexa.
4.
Display & UI Updates:
  • New VU Meter designs (requires app v3.1.4)
  • Added remote pairing and Wi-Fi disconnect indicator.
5.
My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4)
6.
Prompt Sound Option: Ability to disable system sounds (requires app v3.1.4)
7.
Wi-Fi Stability: Improved connection reliability, especially for mesh networks.
8.
USB Output Enhancements: Reduced playback stuttering, improved subwoofer sound quality, and added the ability to select either maximum or fixed resolution (requires app version 3.1.4 or later)
Bug Fixes
1.
LMS Fix: Fixed LMS reconnection issue.
2.
USB Indexing: Resolved USB scanning interruptions for M4A files.
3.
Pop Noise Reduction: Reduced pop noises when switching inputs or adjusting subwoofer settings.
4.
Radio Paradise Fix: Corrected a playback failure issue.
5.
Optical-in/HDMI ARC Playback Correction: Fixed swapped audio channel issue for optical and HDMI inputs.
6.
General Fixes: General performance and stability improvements.
5.2.705437
Release date: January 23, 2025
What's New
1.
Smart Preset Enhancement: Added support for the Sub Output option in Smart Presets for greater customization (requires app version 3.1.1+)
2.
G apless Playback Enhancement: Fixed an issue that caused skipping when playing tracks shorter than 10 seconds.
3.
Playback Enhancements: Fixed playback crashes and resolved a 2-second playback loss issue with the APE audio format.
4.
Resample Algorithm Enhancement: Upgraded the resample algorithm to ensure high sound quality when resampling to 96 kHz or lower.
Bug Fixes
1.
Subwoofer & Main Speakers Auto-Timing Alignment: Fixed an issue that prevented auto-timing alignment after disconnecting from USB Out.
2.
General Fixes: Various performance improvements and bug fixes.
5.2.704665
Release date: January 15, 2025
Bug Fixes
1.
Screen Display Enhancements: Improved the reliability of album cover display.
2.
USB Out Fix: Fixed an issue preventing standby mode and resolved a no-sound issue with certain DACs when using USB Out.
3.
Google Cast Enhancements: Fixed an occasional issue that prevented bit-perfect playback on Google Cast Audio when using USB out.
5.2.704152
Release date: January 10, 2025
What's New
1.
Smart Preset: Create scenes for your favorite setups, including Input, Output, Playback, Volume, EQ, and Shuffle. Activate your scene with a single tap (requires app version 3.1.0). Learn More >>
2.
Simultaneous USB and Sub Output: Enjoy simultaneous USB and subwoofer output for an enhanced audio experience.
3.
Low-Delay Multi-Room Audio: Stream multi-room audio with low latency and perfect audio/video sync (requires app version 3.1.0). Learn More >>
4.
Remote Volume Step Customization: Adjust the volume step for each press of the remote’s volume buttons (requires app version 3.1.0)
5.
Replay Gain Enhancements: Replay Gain now supported for USB, NAS, Samba, and local libraries (requires app version 3.1.0)
6.
Remote Troubleshooting Improvements: Remote exception status is now provided to the app to assist with troubleshooting (requires app version 3.1.0)
7.
Screen Enhancements: Added reboot options on the screen.
8.
Bluetooth & Network Pairing: In Setup mode, hold the play/pause button for 3 seconds to cancel pairing and network setup.
Bug Fixes
1.
Playback Enhancements: Fixed playback status after seeking, resolved artwork issues via Google Cast, and added sample rate/bit depth display on Alexa.
2.
USB Indexing: Addressed issues with artist and metadata display for certain music files.
3.
5.2.703434
Release date: January 3, 2025
What's New
1.
Google Cast SDK Update: Enhanced playback support for multiple music streaming platforms, including Roon, Plex, SiriusXM and BubbleUPnP.
2.
Persistent Group Support: Enhanced quick selection and synchronization for multi-room audio across devices. Learn More >>
3.
USB Indexing Enhancements: Added support for APE audio tracks, corrected artist name display, and resolved unexpected interruptions during USB scans.
4.
Playback Improvements: Enhanced metadata accuracy for local storage music and optimized memory usage for improved stability.
5.
6.
TIDAL Connect SDK Update: Upgraded for improved playback stability and resolved crash issues.
7.
Enhanced DHCP Compatibility: Improved stability and reliability across various routers.
Bug Fixes
1.
Alarm Fix: Easily stop the default alarm tone using remote buttons or the app's play/pause button.
2.
LMS Volume Control: Resolved an issue where Fixed Volume settings were lost for LMS Volume Control.
3.
5.2.639135
Release date: December 19, 2024
What's New
1.
Enhanced OTA Downloads: Support added for resuming interrupted OTA updates.
Bug Fixes
1.
Audio Switching: Resolved no sound issues and ensured seamless Roon playback after input changes.
2.
Bluetooth Stability: Improved connection reliability for Bluetooth.
3.
Alarm Fix: Alarms now stop correctly, even when the selected music is unavailable.
4.
Screen Stability: Fixed screen flashes on startup and random Remote Pairing page appearances.
5.
Remote Control: Addressed memory issues causing remote malfunctions.
6.
KKBox Sign-In: Fixed automatic sign-out of KKBox accounts.
7.
Playback Stability: Enhanced Roon playback during audio input changes.
8.
General Improvements: Performance enhancements and various bug fixes.
5.2.638250
Release date: December 10, 2024
Bug Fixes
1.
Remote Pairing: Resolved issues preventing WiiM Remote from connecting to devices.
2.
USB Indexing: Fixed unexpected interruptions during USB scans.
3.
  • Enhanced switching between Qobuz and AVS.
  • Improved Roon playback stability when USB Audio Out is disconnected.
5.2.637652
Release date: December 4, 2024
What's New
1.
Room Correction with Independent L/R Channels: Fine-tune each audio channel independently for a richer, more immersive sound experience. (Requires app version 3.0.3 or higher)
2.
K KBox Integration: Enjoy seamless streaming with KKBox, now fully supported within the app. (Requires app version 3.0.4 or higher)
3.
LMS Server Selection: Select your preferred LMS ( Lyrion Media Server) based on IP for more flexibility in playback. (Requires app version 3.0.4 or higher)
4.
Enhanced Alarm Functionality: If your chosen music isn't available, fallback sounds will ensure you never miss your alarm.
5.
Playback Enhancements: Enjoy more accurate metadata, resolved skipping issues, and smoother playback for TuneIn.
6.
Qobuz Queue Enhancements: Experience improved playback with Qobuz, featuring track order retention during shuffle, Replay Gain support, and faster queue performance.
Bug Fixes
1.
BBC Radio Bitrate Display: Now correctly shows the bitrate for BBC Radio streams.
2.
General Improvements: Various performance enhancements and bug fixes for an overall better experience.
5.2.636045
Release date: November 19, 2024
What's New
1.
Playback Fixes: Improved metadata handling, resolved skipping/seeking issues, added WMA Lossless support, fixed Icecast playback, and reduced Preset latency.
2.
Replay Gain: Added support for TIDAL, Qobuz and Plex (requires app version 3.0.0+). Learn More >>
3.
USB Disk Ejection: Added manual ejection functionality (requires app version 3.0.0+)
4.
Bluetooth Control: Disabled connection notifications.
5.
Volume Indicator: Stays active for 10 seconds after adjustments, then dims.
6.
SoundMachine Preset: Added support for SoundMachine Preset (coming in the next app update)
7.
USB Indexing: Resolved artwork and metadata display issues for specific music files.
8.
LMS Enhancements: Fixed volume indicator flashing during playback.
9.
Standby Wallpaper Customization: Personalize standby wallpapers to match your style (coming in the next app update)
Bug Fixes
1.
Offline Responsiveness: Improved performance without internet.
2.
Amazon Music: Resolved playback not resuming after extended pauses.
3.
Analog Clock Display: Resolved an issue causing the analog clock to display incorrectly.
4.
5.2.634946
Release date: November 8, 2024
Bug Fixes
1.
DLNA Discovery: Fixed an issue preventing device detection via DLNA.
2.
Playback: Fixed playback issues for certain Icecast streams.
5.2.634663
Release date: November 5, 2024
What's New
1.
Auto Timing Alignment: Syncs main speakers and subwoofer automatically for optimal audio timing (requires app version 2.12.2+)
2.
USB Disk Ejection: Added manual USB ejection (coming in next app update)
3.
Bluetooth Sound Control: Disabled connection notifications when not in Bluetooth input mode.
4.
Google Cast Upgrade: Fixed Output Resolution support and improved sync with Google Speaker Groups.
5.
New Clock Faces: Two clock face options for display (coming in next app update)
6.
Playback Fixes: Improved metadata, fixed skipping issues, added WMA lossless support, and reduced Preset latency.
Bug Fixes
1.
Offline Responsiveness: Improved response without internet.
2.
General Enhancements: Various performance boosts and bug fixes.
5.2.633165
Release date: October 21, 2024
What's New
1.
Fixed Output Resolution for Coaxial and Optical Out: Added an option to set fixed output resolution to prevent pop noises when changing sample rates. Find it under Device Settings -> Audio Settings -> Optical/Coax Output Resolution.
2.
Improved Alarm Behavior for Plex: Default alarm sound will now play if Plex server is unavailable.
Bug Fixes
1.
  • Fixed playback crash for Deezer alarms and presets.
  • Fixed noise issue when resuming Amazon Music.
  • Fixed no sound when switching between Bluetooth, Line or Optical inputs.
2.
Group Enhancement: Fixed unexpected device removal from group.
5.2.632547
Release date: October 15, 2024
What's New
1.
Google Cast Enhancements: Added bit-perfect playback support and reduced pop noise on Google Cast Audio.
2.
Control 4 Integration: Seamlessly integrate with Control4 systems for enhanced smart home control. Learn More >>
3.
USB Output Enhancement: Added support for multiple USB soundcards.
4.
USB Indexing Enhancement: Supports m3u and m3u8 playlist formats. Learn More >>
5.
  • Corrected metadata display issues for custom radio stations caused by special characters.
  • Corrected the default VU meter value when no content is playing.
  • Addressed various other screen issues for a smoother and more reliable experience.
Bug Fixes
1.
  • Fixed an issue where playback could not resume after Wi-Fi reconnection.
  • Fixed an issue preventing Audible Books from playing through Alexa.
2.
HDMI Input Issue: Resolved an occasional no sound issue.
3.
Alarm Time Fix: Corrected rare incorrect alarm issue.
4.
S ync Audio Fix: Fixed an occasional error for Sync Audio.
5.
General Enhancements: Various performance improvements and bug fixes to enhance overall operation.
5.2.630835
Release date: September 29, 2024
Bug Fixes
1.
Display App Crash Fix: Resolved an issue that was causing the display to crash.
5.2.630635
Release date: September 27, 2024
What's New
1.
Advanced Subwoofer Controls (requires app version 2.11.7 or later):
  • Subwoofer Bypass Mode: Allows main speakers to output bass even when the subwoofer is active. Learn More >>
  • Full-Range Subwoofer Audio: Sends full-range audio to the subwoofer without applying a crossover. Learn More >>
2.
  • Displays high-quality artwork for NAS and Samba files.
  • Added support for Vietnamese font display.
  • Address various other screen issues for a smoother and more reliable experience.
Bug Fixes
1.
USB Index Fix: Fixed an issue that stopped full music scans for some WAV files.
2.
General Enhancements: Various bug fixes and performance improvements for a smoother experience.
5.2.629945
Release date: September 20, 2024
What's New
1.
USB Output (S24_3LE): Added support for S24_3LE audio format output via USB.
2.
Plex Support (Beta): Integrated Plex for direct music access and playback in the WiiM Home app (iOS 2.11.6 required; Android support coming soon). Learn More >>
3.
  • Fixed occasional no sound issues with Alexa Multi-room and Bluetooth Input.
  • Corrected metadata for custom radio stations and reduced cracking noise in some MP3 files.
  • Improved real-time playback after resuming from radio streams.
4.
Google Cast SDK Update: Improved playback for multiple music streaming platforms and Google Speaker Groups (ensure Google Home is up-to-date)
5.
Screen Enhancements: Addressed issues with brightness adjustment, VU meter, and UI during OTA updates.
Bug Fixes
1.
USB Media Library: Fixed missing metadata for certain WAV files.
2.
General Enhancements: Various bug fixes and performance improvements.
5.2.628942
Release date: September 10, 2024
What's New
1.
USB Indexing Enhancement: Resolve a file system issue that interrupted the USB scan process and improve the overall scan speed.
2.
Multi-Channel Audio Playback: Add support for 5.1 and 7.1 multi-channel audio playback, which will be converted to stereo audio during playback.
3.
  • Introduce management for paired Bluetooth input devices.
  • Display current playback metadata in follower mode in real-time.
Bug Fixes
1.
Roon Ready Metadata: Fix an issue where playing Radio via Roon Ready did not display the correct metadata.
2.
Phono Input Enhancement: Ensured the Phono stage type is retained after reboot.
3.
DLNA Playback Enhancement: Correct an issue that caused tracks to be skipped during DLNA playback via Bubble UPnP.
4.
5.2.627753
Release date: August 30, 2024
What's New
1.
  • Resolve issues with Amazon Music, including skipping during playback and inability to start playback.
  • Fix an issue where TIDAL playback wouldn’t start when switching from Amazon Music.
  • Correct metadata now displays when seeking frequently.
  • Resolve an issue preventing Audible Books from playing through Alexa.
  • Fix playback issues with certain M3U8 formats.
  • Address occasional Bluetooth playback crashes.
  • Reduce playback stuttering for HDMI and Optical input sources.
2.
Screen Improvements:
  • Added support for Hebrew font display.
  • Correct EQ selection is now shown when EQ settings are changed.
Bug Fixes
1.
USB Media Library Fix: Resolve an issue where artwork was not displaying.
2.
5.2.627135
Release date: August 23, 2024
What's New
1.
LMS Enhancements: Add power control to manage the device's standby mode via LMS.
2.
Playback enhancements:
  • Add artwork display for Radio Paradise on the screen and app.
  • Resolve a crash issue that caused unexpected playback stops on Google Cast.
  • Fix playback issues affecting certain custom radios.
  • Fix an issue where the first track was skipped during DLNA playback.
Bug Fixes
1.
12V Trigger Out Behavior: Improve to maintain the status of 12V Trigger Out after rebooting.
2.
5.2.626448
Release date: August 16, 2024
What's New
1.
Group Enhancement: Resolved an issue that prevented multiple devices from being grouped together.
2.
USB Scan Enhancement: Resolved an issue that prevented the USB scan process from completing and improved the scan speed.
5.2.626261
Release date: August 14, 2024
What's New
1.
  • Fixed TIDAL playback skipping and stopping issues.
  • Resolved Bluetooth playback distortion over long periods.
  • Reduced playback latency by 100ms.
2.
  • Improved VU meter responsiveness.
  • Fixed time display issue in the Mexico timezone.
Bug Fixes
1.
Bluetooth Enhancements: Resolved issue preventing switching to Bluetooth.
2.
5.2.625658
Release date: August 8, 2024
What's New
1.
  • Update Google Cast SDK for a better listening experience.
  • Resolved playback stuttering on certain speakers via digital outputs.
2.
Bluetooth Playback Upgrade: Enhanced Bluetooth playback to reduce latency and eliminate stuttering issues.
3.
Pre-Gain Feature: Added logic for Pre-Gain functionality. Available in the next app update. Learn More >>
4.
  • Addressed an issue where Amazon Music and Deezer playback unexpectedly stopped.
  • Fixed a bug preventing Amazon Music and Audible from playing via Alexa.
5.
SSL Certificates Update: Updated SSL Certificates to resolve the TuneIn playback issue in Alexa Multi-room audio.
6.
Voice Control: Added support for switching to Phono input via Alexa for WiiM voice remote.
Bug Fixes
1.
USB Output Improvement: Resolved the playback distortion issue with the S24_3LE format.
2.
5.2.625360
Release date: August 5, 2024
What's New
1.
Enhanced Stability: Fixed crashes with Spotify Connect and TIDAL Connect.
2.
Playback Improvement: Reduced latency by 1 second.
3.
HDMI Playback: Fixed intermittent pauses and resumes.
4.
Squeezelite: Resolved unexpected volume increases when unmuting.
5.2.625032
Release date: August 2, 2024
What's New
1.
Roon Ready:Official Roon Ready certification achieved, enhancing audio integration and performance.
  • Note: Should the WiiM Ultra not appear as 'Roon Ready' in the Roon app, please restart the app for accurate display.
2.
Per-Channel EQ: Set parametric EQ settings for left and right channels individually (requires app version 2.10.7 or later)
3.
USB Disk Manual Scan: Improved USB media library scanning process. Learn More >>
4.
DSD Playback Enhancement: Now supports playing DSD audio tracks in DFF format.
5.
Screen Display Enhancements: USB output is now shown on the Input screen for easier control.
6.
USB Output Behavior: Device remains in USB Output mode when a USB sound card is connected.
Bug Fixes
1.
Pop Noise Fix: Reduced pop noise for Spotify Connect and TIDAL Connect.
2.
General Improvements: Various bug fixes and performance enhancements for a smoother experience.
5.2.624365
Release date: July 26, 2024
What's New
1.
USB Audio: Supports two-channel USB audio output (requires app version 2.10.2 or later). Refer to this tutorial for details. Learn More >>
2.
Refined Input Auto-Sensing: Enhanced for smoother audio transitions with reduced delay.
3.
4.
Output Change Enhancement: Preserves the playing queue when switching audio outputs.
5.
Line Out Sound Quality Improvement: Reduced jitter at 12k to enhance analog sound quality via Line Out.
6.
DSD Format Support for USB Disks: Adds the ability to play DSD audio tracks in DSF and DST formats directly from a USB disk.
7.
  • Screen now turns off/on with the remote's power button.
  • Correct 12-hour time display.
  • Option to turn off screen display in standby mode (requires app version 2.10.7)
  • Fixed issue preventing the screen from turning on.
  • All tracks displayed for large playlists.
  • Various other screen issues addressed for a smoother experience.
Bug Fixes
1.
Pop Noise Fix: Reduced pop noise for Spotify Connect.
2.
Playback Enhancement: Minimized playback latency.
3.
Squeezelite Enhancements: Resolved issues with artwork display and connectivity with the latest Lyrion Media Server (LMS)
4.
Amazon Music Playback: Fixed intermittent no sound issues.
5.
5.2.623336
Release date: July 16, 2024
What's New
1.
  • Highlighted the currently playing Preset.
  • Playlists with over 200 songs are now shown across multiple pages.
  • Album covers are displayed without stretching.
  • Custom EQ options are now available for selection.
2.
Shared Folder: Now supports Samba protocol for music playback, including DSD audio files. Compatible with Android app version 2.10.4+ and the upcoming iOS update.
Bug Fixes
1.
Bitrate Display for Optical In and HDMI: The correct bitrate for Optical In and HDMI is now shown on the WiiM Home app and screen display.
2.
Bluetooth Playback Improvement: Resolved playback stuttering when the WiiM Ultra is connected to 2.4G Wi-Fi.
3.
Dolby Audio Playback Improvement: Resolved Dolby Audio playback stuttering via HDMI when the output resolution is 44.1kHz.
4.
5.2.622235
Release date: July 5, 2024
What's New
1.
DLNA Behaviors Enhancement: Added support for loop and shuffle modes in DLNA playback. Also, enables seamless DSD audio file playback via DLNA.
2.
TIDAL Connect Enhancements: Fixed playback stops, loop and shuffle issues, and incorrect playing status. Correct metadata now displays in multi-room audio.
3.
Subwoofer Output Enhancement: Optimized mono output for enhanced subwoofer sound quality.
4.
HTTP API Update: Updated to provide browse and control Presets.
5.
Enhanced Energy Efficiency: Improved power consumption when entering standby mode.
6.
  • Updated the animation for Source Inputs during playback
  • Fixed the issue where the volume indicator was always displayed
  • Resolved the crash caused by large playlists
  • Corrected the playback status display for Source Inputs
  • Fixed incorrect artwork display for Amazon Music
  • Screen display now automatically turns off when entering standby mode
Bug Fixes
1.
Alarm Behavior for Spotify Connect: Fixed alarm not stopping automatically when duration ended.
2.
Pop Noise Reduction: Resolved occasional popping noises occurring at 16-bit/44.1 kHz or 16-bit/48 k Hz.
3.
5.2.734250
