TABLE OF CONTENTS
This tutorial will introduce you how to set up and use the WiiM Persistent Group feature in the WiiM Home App.
WiiM Persistent Group Overview
The WiiM Persistent Group feature makes it easy to set up and manage multi-room audio across multiple WiiM devices. You can also select either a group or an individual device to play music directly from the Spotify app.
The WiiM Persistent Group feature brings the following benefits:
  • Convenience and Speed: Preset groups let you quickly select and play music on multiple devices with a single tap, saving your time.
  • Customization: Create different persistent groups tailored to various occasions or moods, such as a party group, a relaxation group, or one for focused work.
  • Multi-Room Synchronization: Effortlessly group speakers across multiple rooms for synchronized audio, ensuring a seamless, immersive listening experience throughout your home.
  • User-Friendly: Simplifies managing multiple speakers, making it easy for everyone in the household to enjoy the music listening experience.
The WiiM persistent group is accessible only through the WiiM Home app or Spotify app. It does not appear in other apps such as AirPlay, TIDAL, Amazon Alexa, or Google Home.
How to Set Up a WiiM Persistent Group
Follow these steps to set up a WiiM Persistent Group:
  1. Open the WiiM Home app.
  2. Navigate to the Device tab, tap Groups.
  3. Tap Create Group to start setting up a persistent group.
  4. Choose the devices to include in the persistent group and tab Next.
  5. Enter a group name and then tap Next to complete the setup.
  6. Once created, the group will be displayed on the Device tab.
Use a WiiM Persistent Group in WiiM Home App
You can access the WiiM Persistent Group in the WiiM Home app using one of these two ways:
Option 1: Access a WiiM Persistent Group from Now Playing
Tap the Output Selector iconat the bottom of the Now Playing page to choose the persistent group and play music on multiple devices seamlessly.
Navigate to the Device tab and tap the link iconon a device to select a group, making it easy to play music on multiple devices.
Access a WiiM Persistent Group from Spotify
All persistent groups and individual devices will be shown in the device list on the Spotify app, allowing you to conveniently switch playback between a group or a specific device.
For detailed setup instructions, watch the video below.
