This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
It's important to note that the device's firmware version is distinct from the WiiM Home App version. To check your device's firmware version, open the WiiM Home App, go to the 'Device' tab, tap the 'gear icon (Cog Wheel)' for device settings, select 'Device Info', and then view 'Firmware Version'.
5.2.833833 (In Progress)
Release date: October 28, 2026
What's New
1.
Presto Music: Added support for Presto Music.
2.
Input Scene: Automatically applies your saved group, volume, and subwoofer settings when switching inputs. Learn More
3.
Squeezelite: Updated the SDK to version 2.0.0-1609 to improve playback stability.
4.
Parametric EQ: Added support for saving up to 20 custom EQ presets.
5.
Spotify Connect: Updated the Spotify SDK to reduce playback interruptions.
Audio & Playback
1.
Deezer: Added support for adding tracks to the playback queue.
2.
TuneIn: Fixed playback issues with TuneIn presets and alarms.
3.
TIDAL Connect & Qobuz Connect: Fixed an issue that prevented playback from resuming after seeking.
4.
CPU Optimization: Reduced CPU usage during Google Cast and Alexa Multi-Room Music playback.
5.
iHeartRadio: Fixed a crash during playback.
6.
Alexa Multi-Room Music: Fixed a crash during playback.
5.2.829663
Release date: September 17, 2026
What's New
1.
SoundCloud: Added support for seeking within tracks.
2.
Google Cast: Added support for WiiM multi-room playback and wireless WiiM Sub Pro output.
General Improvements
1.
Network: Improved Ethernet stability and IPv6 address handling.
2.
TIDAL Connect: Reduced playback stuttering.
5.2.827565
Release date: August 27, 2026
Audio & Playback
1.
Soundtrack: Updated the SDK to improve playback stability and performance.
2.
Multi-Room Playback: Improved synchronization and playback stability during multi-room playback.
3.
Spotify Connect: Fixed pop noise when skipping tracks and Prevented certain speakers from leaving the group when starting playback.
5.2.826130
Release date: August 13, 2026
New Features
1.
Auto Headroom: Added automatic headroom adjustment to help prevent audio clipping. Turn it on or off in the latest WiiM Home app. Learn More >>
2.
Amazon Alexa: Added an on-screen animation when interacting with Alexa.
3.
Standby Display: Added the option to select a standby wallpaper by touching and holding it on the device screen. Learn More >>
4.
Subwoofer Calibration: Automatically aligns the subwoofer’s volume level with the main speakers at the listening position. Learn More >>
Audio & Playback
1.
Multi-Room Audio: Improved audio quality during multi-room playback.
2.
3.
Google Cast: Updated the SDK to improve playback compatibility across music streaming services.
4.
iHeartRadio: Added FLV support to enable playback for certain radio stations.
5.
Sound Machine: Fixed an issue where playback could stop unexpectedly.
6.
Open Network Stream: Fixed an issue where playback might not resume after a long pause.
7.
Bluetooth: Reduced playback stuttering and ensured the Bluetooth name updates after renaming the device.
8.
Spotify Connect: Reduced playback stuttering.
Bug Fixes
1.
Date Display: Fixed an issue where an incorrect date could appear on the device screen.
2.
USB Media Library: Fixed an issue where newly added files might not be detected during a rescan.
3.
Standby Source Mode: Prevented switching to HDMI when no HDMI cable is connected.
4.
Qobuz: Fixed playback stopping when loading high-resolution artwork.
5.2.820839
Release date: June 22, 2026
New Features
1.
WiiM Radio: Added support for WiiM Radio.
2.
TV Remote Volume Step: Allows volume step adjustment when using a TV remote, configurable in the WiiM Home app.
3.
Automatic Updates: Adds support for delaying automatic firmware updates, configurable in the WiiM Home app.
Audio & Playback
1.
Audio Input Latency: Reduces audio input latency to approximately 35–40 ms.
2.
VU Meter & Spectrum Display: Fixes stuttering when switching display modes.
3.
Playback Stuttering: Reduces stuttering during music playback.
4.
USB Library: Fixes special character display issues; Improves scanning speed and stability.
5.
Qobuz: Fixes a crash issue when using Qobuz.
6.
Amazon Music: Fixed an issue where Amazon Music could skip tracks unexpectedly.
1.
OOBE Setup Status: Displays the setup mode status during OOBE.
2.
Time Display: Fixes incorrect Egypt daylight saving time display.
3.
Audio Input Switching: Improves the speed of switching between audio inputs.
5.2.813343
Release date: April 9, 2026
Highlights
1.
Sub & Main Speaker Sync: Automatically aligns subwoofer and main speakers for improved timing at the listening position.
2.
Per-Input Screen Control: Enable or disable the screen display for each input mode.
3.
4.
Surround Setup: Simplified setup with full backward compatibility. (requires upcoming app update)
Screen
1.
Playback Screen: Added a vinyl-style playback screen for a more immersive experience.
2.
Localization: Added French language support.
Playback & Audio
1.
2.
EQ: Improved responsiveness when adjusting and switching EQ settings.
3.
Line In: Fixed distortion during extended playback sessions.
4.
Bass Output: Fixed low bass levels for Apple TV (Dolby 5.1)
Radio & Streaming Services
1.
2.
3.
4.
Deezer: Fixed unexpected playback interruptions.
1.
2.
HDMI ARC: Disabling automatic audio output now correctly keeps WiiM in standby and defaults to the TV speakers.
3.
4.
Audio Input: Fixed playback crash issues.
5.
Remote: Fixed occasional disconnection and unexpected max volume issues.
6.
Alarm: Fixed incorrect alarm and preset volume behavior.
7.
Roon: Fixed occasional crash issues.
8.
EQ: Enables EQ for Dolby 5.1 playback.
9.
Alarm: Fixes BBC and vTuner alarms defaulting to the chime.
10.
Spectrum Display: Improves dynamic visualization.
11.
5.2.809633
Release date: March 3, 2026
Display & UI
1.
Per-Input Now Playing: Customize the Now Playing screen for each input source.
2.
New Cover Layouts: Added larger album-art views for a more immersive playback screen, with Home and Music Source icons hidden.
3.
Dolby Visuals: VU Meter and Audio Spectrum now work during Dolby playback.
4.
Localization: Added German language support for the device screen.
Playback & Audio
1.
Optical In: Fixed dropouts caused by input stream format changes.
2.
Short-Track Transitions: Improved near-end handling to prevent skipping or audio “leakage.”.
3.
Track Skips: Resolved multiple cases of unexpected skipping / premature track changes across services.
1.
Live Metadata: Added ICY support for richer “now playing” info on TuneIn, iHeartRadio.
2.
Qobuz: Added Track Radio / Artist Radio / Album Radio.
3.
vTuner: Improved reliability with backup stream URL fallback.
4.
SoundCloud: Added third-party login support.
5.
TuneIn: Fixed alarms occasionally starting late or failing to start playback.
6.
iHeartRadio / Pandora: Fixed intermittent stops and unexpected skipping.
7.
Pandora: Fixed an issue that could cause unexpected track skipping.
8.
Napster: Fixed My Music playback failures, incorrect station controls, and a disconnect-on-no-internet crash.
9.
Plex: Fixed alarm progress display, station history playback failures, and occasional early skips.
10.
Amazon Music: Fixed interruptions when playing short playlists.
11.
TIDAL Connect: Updated the SDK to fix an issue that could cause random playback stops.
12.
Roon Ready:Updates the SDK for improved security.
- Note: If the device does not appear in the Roon app on your PC, please update your Roon app to the latest version.
USB & NAS
1.
USB Notifications: Added connect/disconnect pop-ups.
2.
Faster Browsing: Reduced app timeouts when browsing USB drives.
3.
NAS Playback: Fixed playback and display issues for NAS sources.
5.2.739555
Release date: December 23, 2025
1.
Wi-Fi: Stronger connection stability; improved compatibility with Wi-Fi 7 routers.
2.
Audio Spectrum: Added Audio Spectrum visualization. Better timing alignment with playback.
3.
Queue: Better track order retention in shuffle and faster queue operations across NAS/USB/Samba/Local, TIDAL, Qobuz, Radio Paradise, YouTube, Deezer, and SoundCloud.
4.
Multi-room: Improved multicast logic for more reliable discovery/connectivity; reduced stutter when using Bluetooth input.
Music Services
1.
Qobuz: Stabilized progress bar; fixed shuffle dropouts, playback-mode mismatch, and missing artist/track metadata.
2.
Soundtrack: Updated SDK; fixed disconnects when renaming the device during playback.
3.
Amazon Music: Fixed position reset after back-to-back seeks.
4.
USB Library: Fixed disappearing album art.
5.
TIDAL Connect: Fixed playback interruptions after ~1 hour.
6.
7.
Radio: Resolved failures for certain station formats.
Bug Fixes
1.
Google Cast: Device now retains its assigned room after reboot.
2.
VU Meter: Restored operation with Dolby audio in multi-room playback.
5.2.734250
Release date: November 1, 2025
Highlights
1.
Real-time input status, smarter DNS for reliability, customizable DAC filter, and smoother streaming across services.
What's New
1.
Input status at a glance: The app now shows when Line In and HDMI ARC are physically connected.
2.
Smart DNS reliability: Validates the DNS server provided by your router for more dependable service access.
3.
DAC filter selection: Choose your preferred DAC filter type to tailor the sound.
4.
Alarms: Custom labels and up to 32 alarms.
5.
Lyrion Media Server (LMS): Disabled by default; enable in Device Settings in the WiiM Home app.
6.
USB Media Library: Create, delete, and manage playlists (add/remove tracks) on USB storage.
7.
TuneIn: Faster start when playing Apple Music stations.
Bug Fixes
1.
Playback: Corrected playback state display in certain cases.
2.
3.
Sub Output: Fixed missing bass when the wireless WiiM Sub Pro was disconnected.
4.
Qobuz Connect: Resolved a blocking issue that prevented playback.
5.
Spotify: Fixed failures to play from the Spotify app’s Recommended lists and Recently Played; also fixed presets that would not start playback.
6.
Alarm: Corrected behavior in Daylight Saving Time zones.
7.
Multi-room: After ungrouping, metadata no longer syncs to previously grouped (child) speakers.
8.
Gapless Player: Fixed a near track end race condition that could trigger overlapping/simultaneous playback.
9.
Local Files: Fixed an issue where the app progress bar reached the end before playback finished.
10.
Amazon Music: Smoother seeking and playback—fixed occasional skips after seeking, progress bar desync, repeated playback of the same track after seeking, and unexpected stops when using Amazon Music Cast.
5.2.730559
Release date: September 26, 2025
What's New
1.
Amazon Music – Faster resume after long pauses and improved casting stability from the Amazon Music app.
Bug Fixes
1.
Dolby Audio – Eliminated playback noise and fixed subwoofer no-sound cases.
2.
USB Library – Refined image resizing for crisper album art.
3.
Pandora – Resolved track skipping after resume and login failures.
4.
Alarms – Station-based alarms now trigger reliably.
5.
TuneIn – Apple Music radio via TuneIn now resumes after long pauses; reduced radio playback failures.
6.
KKBOX – Fixed playback interruptions and corrected bitrate reporting.
7.
General – Stability, performance, and other minor fixes.
5.2.729135
Release date: September 12, 2025
What's New
1.
Enhanced VU Mete r: Smoother and more responsive visual performance.
2.
TuneIn: Automatically selects the highest-quality stream.
3.
Screen Enhancements:
- Added Spotify Connect support in Recently Played.
- Presets now visible even without internet.
- Device name displayed on the Home page.
- Bluetooth connection status added.
- Enlarged playback control button touch area.
Bug Fixes
1.
YouTube Music: Fixed playback noise and incorrect metadata.
2.
TIDAL Connect: Corrected metadata display.
3.
Qobuz Connect: Fixed the issue where gapless playback was not working.
4.
Google Cast: Fixed occasional no-sound issues.
5.
HDMI ARC: Fixed unexpected switching to ARC during music playback.
6.
USB Indexing: Fixed garbled Chinese character display.
7.
SoundTrack: Fixed missing audio during the first two seconds of announcements.
8.
YouTube Music Group Playback: Fixed no-sound issue when switching to group playback.
5.2.726631
Release date: August 18, 2025
What's New
1.
Room Correction & EQ Integration: Room Correction and EQ now work together to provide an optimized listening experience. Learn More >>
2.
3.
- Corrected highlight behavior for Local Radio and Recently Played.
- Expanded the tap area for easier Preset selection.
- Ensured full display of Presets and Recently Played content.
4.
Amazon Music: Bitrate information is now displayed when streaming Amazon Music Prime.
5.
Sub Pro Intergartion: Improved pairing experience and overall functionality when using the Sub Pro.
6.
YouTube Music: Native, seamless streaming support. (requires the upcoming app version 3.3.1)
7.
Soundtrack SDK Upgrade: Under-the-hood improvements for a smoother, more consistent listening experience.
Bug Fixes
1.
Alarm Fixes:
- Resolved an issue where weekly alarms occasionally failed to trigger.
- Fixed a bug where only the default tone played for Pandora alarm.
2.
Dolby Audio Fixes:
- Fixed no-sound issues when playing Dolby audio in multiroom setups.
- Corrected volume balance behavior for Dolby audio.
- Corrected low volume when playing Dolby Digital content.
3.
USB Output Fixes:
- Resolved no-sound issues after reconnecting a USB DAC device when using Google Cast, TIDAL Connect, Spotify Connect, or Qobuz Connect.
- Fixed audio stuttering when playing at 44.1kHz or 48kHz sample rates.
4.
Playing Status: Corrected the playback status indicator when no music is playing.
5.
Qobuz: Now displays the correct artist name in the app during playback.
6.
Bluetooth Output: Fixed a no-audio issue after switching outputs.
7.
NAS & USB Playback: Playback now correctly restarts from the beginning after the last track finishes.
8.
Playback Speed: Resolved rare cases where songs played at accelerated speed.
5.2.723250
Release date: July 15, 2025
What's New
1.
Roon Ready Certified: Seamless bit-perfect streaming from Roon. Tip: if Amp Ultra doesn't appear in Roon after updating, simply restart the Roon app.
2.
HDMI ARC Upgrade:
- Eliminated pop/crackle noises.
- Added Auto-Sensing for instant TV-audio pickup.
- Improved the stability of ARC connections.
3.
Advanced Parametric EQ: High-Pass & Low-Pass filters now available (App v3.2.6+ required)
4.
Deezer: “Play Next / Play Last” options added.
5.
Bluetooth: Adjustable latency for perfectly synced audio.
Bug Fixes
1.
S oundtrack Pairing: Fixed an issue preventing successful soundtrack pairing.
2.
Gapless Playback: Fixed an issue causing incomplete audio playback.
3.
USB Indexing: Corrected the extraction of PNG format covers from MP3 files and fixed a crash issue that caused playback to stop.
4.
Qobuz Connect: Fixed an issue where playback would automatically resume after pausing when using USB output.
