TABLE OF CONTENTS
Connection Modes
The WiiM Sub Pro is a wireless smart subwoofer designed to deliver deep, distortion-free bass to your audio system. The WiiM Sub Pro seamlessly integrates with WiiM devices to unlock wireless streaming capabilities and smart features for a personalized listening experience. It can also connect to specific WiiM devices or third-party audio systems via an RCA cable, offering flexible installation options.
This tutorial will walk you through the step-by-step setup guide to get your WiiM Sub Pro up and running.
What You'll Need
To integrate the WiiM Sub Pro with your WiiM system, you'll need:
- A WiiM Sub Pro
- A WiiM device
- A smartphone or tablet
- Wi-Fi connection
- (Optional) Ethernet connection
Step-by-Step Setup Guide
1. Unbox the WiiM Sub Pro
Open the box, and you'll find the following items inside.
2. Place the WiiM Sub Pro Properly
Start with the WiiM Sub Pro near your main speakers or soundbar, or try a corner for stronger bass. Adjust its position until the bass sounds balanced at your usual listening position.
For placement tips and reference diagrams, see the guide that matches your setup:
- Stereo setup: Tutorial: Tuning Subwoofer Settings on WiiM Devices for Optimal Sound Quality.
- Dolby 5.1 home theater: Expanding Your WiiM Amp Pro / Amp Ultra / Ultra into a 5.1 Home Theater System.
- WiiM Bar 5.1.2 home theater: Expanding Your WiiM Bar into a Complete 5.1.2 Surround Sound System.
3. Power on the WiiM Sub Pro
Connect the WiiM Sub Pro to a power source using the provided power cable. The WiiM Sub Pro will automatically power on and enter Wi-Fi setup mode. In setup mode, the LED indicator flashes white slowly.
If setup mode doesn't start automatically, try either method below:
- Press and hold the Reset button at the back for 3 seconds to enter setup mode.
- Press and hold the Reset button for 10 seconds to restore factory settings for a fresh setup. This erases all settings.
4. Download the WiiM Home App
Use your smartphone or tablet to scan the following QR code to download the WiiM Home app. The app will be used to set up and configure the WiiM Sub Pro.
5. Set Up the WiiM Sub Pro through the WiiM Home App
Wi-Fi Setup Instructions
- Open the WiiM Home app on your smartphone or tablet.
- When your device appears in the app, tap Set Up to start the process.
Note: If your WiiM device doesn't appear automatically, go to the Devices tab and tap Add Device in the top-right corner to trigger the setup page.
- Enter the Wi-Fi password and connect the WiiM Sub Pro to the same Wi-Fi network as your WiiM device.
- Check and update firmware.
- Rename the WiiM Sub Pro.
- Select the WiiM device you want to pair with the WiiM Sub Pro.
- Choose connection mode (wired or wireless) depending on your setup and preference. For details, see Connection Modes.
- Wired Mode: This connection mode is available for WiiM devices with a Sub Out port, such as the WiiM Ultra and WiiM Amp Ultra.
- Wireless Mode: This connection mode is available for all compatible WiiM devices.
- Complete the setup process.
Ethernet Setup Instructions
Connect the WiiM Sub Pro to your router with an Ethernet cable. It will automatically connect to your network. Then, open the WiiM Home app and follow the on-screen instructions to complete setup.
6. Play Music and Enjoy Deep Bass
Now, stream music to the paired WiiM device or directly play music from its connected audio input device. The WiiM Sub Pro will deliver deep, immersive bass for an enhanced listening experience.
Tune Your WiiM Sub Pro
After setup, fine-tune your WiiM Sub Pro for balanced bass that blends smoothly with your main speakers. Use the following guides:
- Audio path and DSP settings: For details on the audio path, audio settings, Sound Mode, and Subwoofer RoomFit™, see WiiM Sub Pro Audio Path and DSP Functions.
- Subwoofer tuning: For general tips on adjusting your subwoofer for optimal sound, see Tutorial: Tuning Subwoofer Settings on WiiM Devices for Optimal Sound Quality.
- Joint RoomFit™: For a WiiM Bar and WiiM Sub Pro pair, see How to Perform Joint RoomFit™ for the WiiM Bar and WiiM Sub Pro Pair.
Manage WiiM Sub Pro Pairing
After successfully pairing your WiiM Sub Pro, you can manage its pairing directly through the WiiM Sub Pro's Device Settings, such as unpairing the WiiM Sub Pro, moving the pairing to a different WiiM device, or switching the connection mode (wired or wireless) on the same device.
For details, see How to Manage Your WiiM Sub Pro Pairing and How to Pair a WiiM Subwoofer in the WiiM Home App.
Tips and Troubleshooting
- Wi-Fi Connection: Ensure your Wi-Fi signal is strong in the location where you set up the WiiM Sub Pro for a stable streaming experience.
- Ethernet Connection (Optional): For added stability, you can connect the WiiM Sub Pro to your network with an Ethernet cable instead of Wi-Fi.
- Device Not Connecting: If the WiiM Sub Pro is not connecting to your Wi-Fi, try restarting your router, WiiM Sub Pro, and WiiM device. For details, see Troubleshooting: How to Resolve Wi-Fi Connection Issue.
- No Sound Issue: If the WiiM Sub Pro isn't producing sound, refer to the relevant steps in Troubleshooting: How to Resolve Subwoofer No Sound Issues.
- Device Not Found: If the WiiM device is not found in the WiiM Home app, see Troubleshooting: WiiM Device Not Found in WiiM Home App.
Limitations (Wireless Mode Only)
Currently, when the WiiM Sub Pro is used in wireless mode, it may not produce bass during the following types of music playback:
- Alexa multi-room music
- Roon Ready
- LMS
- Google Cast
Note: Google Cast playback with a wirelessly paired WiiM Sub Pro is now supported on all WiiM streaming devices except the WiiM Amp and WiiM Mini. Update the paired WiiM device to the latest firmware to use this feature. Support for other WiiM products will be added in future updates.
