Overview
The WiiM Sound and WiiM Sound Lite are high-fidelity smart speakers engineered to deliver detailed, room-filling audio.
Thanks to their precise tuning and wide frequency response, these speakers are the perfect choice to pair with a hub device (e.g., WiiM Ultra/Amp Ultra/Amp Pro/Bar), serving as the Center, Surround Left (SL), and Surround Right (SR) speakers in your 5.1 home theater setup.
Tip: In addition to a 5.1 home theater system, you can flexibly configure 3.0, 3.1, 4.0, 4.1, or 5.0 systems, depending on whether a subwoofer is used and how the center and surround speakers are assigned.
Setting Up Center and Surround Speakers
Before You Begin
  • Set up a WiiM hub device, such as a WiiM Amp Pro, WiiM Amp Ultra, WiiM Ultra, or WiiM Bar
  • Connect the hub device to a TV and a subwoofer.
  • Set up three WiiM Sound/WiiM Sound Lite units. They will be assigned as Center and Surround speakers.
    Note: If the hub device is a WiiM Bar, only two units will be needed as Surround speakers.
  • Connect all WiiM devices to the same Wi-Fi network.
Step 1. Place Speakers Properly
For optimal sound, place all speakers according to the diagram below.
Step 2. Assign Center and Surround Speakers in the WiiM Home App
  1. Open the WiiM Home app.
  2. Go to Devices, then tap your hub device's Device Settings .
  3. Scroll down to the Home Theater section, then select Center and Surrounds to assign the center speaker and surround speakers, respectively.
    For details, see the following articles:
Tips and References
