TABLE OF CONTENTS
The WiiM Vibelink Amp is a high-quality amplifier with RCA, Optical, and Coaxial inputs, designed to seamlessly integrate with a variety of WiiM streamers for superior audio performance. Whether you’re using the WiiM Mini, WiiM Pro, WiiM Pro Plus, or WiiM Ultra, this guide will walk you through the integration process.
How to Use WiiM Ultra with WiiM Vibelink Amp
Before You Begin
  • Ensure that the WiiM Vibelink Amp is connected to passive speakers and powered on.
  • Ensure that the WiiM Ultra is properly set up.
The WiiM Ultra offers Line Out, Optical Out, and COAX Out interfaces, which can be connected to the RCA In, Optical In, and COAX In interfaces on the WiiM Vibelink Amp, respectively.
You can choose any of these interfaces to connect the WiiM Ultra to the WiiM Vibelink Amp.
  • Option 1: Use a RCA cable to connect the WiiM Ultra's Line Out port to the WiiM Vibelink Amp's RCA In port.
For Option 1, the WiiM Vibelink Amp sends the analog audio input directly to the amplifier, bypassing ADC conversion to preserve audio quality.
  • Option 2: Use an optical cable to connect the WiiM Ultra's Optical Out port to the WiiM Vibelink Amp's Optical In port.
  • Option 3: Use an coaxial cable to connect the WiiM Ultra's COAX Out port to the WiiM Vibelink Amp's COAX In port.
2. Set Audio Output on WiiM Ultra
  1. Open the WiiM Home app.
  2. Go to Now Playing.
  3. Tap theicon at the bottom, then select the output interface that corresponds to the one used to connect to the WiiM Vibelink Amp.
Press the Mode Switch button on the front panel of the WiiM Vibelink Amp to select the input mode that matches the interface used to connect to the WiiM Ultra. For details, refer to WiiM Vibelink Amp Controls, Interfaces, and Lights.
How to Use WiiM Pro/WiiM Pro Plus with WiiM Vibelink Amp
Before You Begin
  • Ensure that the WiiM Pro or WiiM Pro Plus is properly set up.
The WiiM Pro and WiiM Pro Plus offer Line Out, Optical Out, and COAX Out interfaces, which can be connected to the RCA In, Optical In, and COAX In interfaces on the WiiM Vibelink Amp, respectively.
You can choose any of these interfaces to connect the WiiM Pro or WiiM Pro Plus to the WiiM Vibelink Amp.
  • Option 1: Use a RCA cable to connect the WiiM Pro/WiiM Pro Plus's Line Out port to the WiiM Vibelink Amp's RCA In port.
  • Option 2: Use an optical cable to connect the WiiM Pro/WiiM Pro Plus's Optical Out port to the WiiM Vibelink Amp's Optical In port.
  • Option 3: Use an coaxial cable to connect the WiiM Pro/WiiM Pro Plus's COAX Out port to the WiiM Vibelink Amp's COAX In port.
2. Set Audio Output on WiiM Pro/WiiM Pro Plus
Press the Mode Switch button on the front panel of the WiiM Vibelink Amp to select the input mode that matches the interface used to connect to the WiiM Pro or WiiM Pro Plus. For details, refer to WiiM Vibelink Amp Controls, Interfaces, and Lights.
How to Use WiiM Mini with WiiM Vibelink Amp
Before You Begin
  • Ensure that the WiiM Mini is properly set up.
The WiiM Mini offers Aux Out and Optical Out interfaces, which can be connected to the RCA In and Optical In interfaces on the WiiM Vibelink Amp, respectively.
You can choose one of these interfaces to connect the WiiM Mini to the WiiM Vibelink Amp.
  • Option 1: Use an optical cable to connect the WiiM Mini's Optical  Out port to the WiiM Vibelink Amp's Optical In port.
Option 1 is recommended as it can take advantage of the premium DAC on the WiiM Vibelink Amp, ensuring optimal sound quality.
  • Option 2: Use an Aux-to-RCA cable to connect the WiiM Mini's Aux Out port to the WiiM Vibelink Amp's RCA In port.
For Option 2, the WiiM Vibelink Amp sends the analog audio input directly to the amplifier, bypassing ADC conversion to preserve audio quality.
2. Set Audio Output on WiiM Mini
Press the Mode Switch button on the front panel of the WiiM Vibelink Amp to select the input mode that matches the interface used to connect to the WiiM Mini. For details, refer to WiiM Vibelink Amp Controls, Interfaces, and Lights.
