This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
For a list of known issues currently being addressed, please refer to the provided link. Our team is diligently working to resolve these and aims to release fixes as per the estimated time of arrival (ETA).
It's important to note that the device's firmware version is distinct from the WiiM Home App version. To check your device's firmware version, open the WiiM Home App, go to the 'Device' tab, tap the 'gear icon (Cog Wheel)' for device settings, select 'Device Info', and then view 'Firmware Version'.
5.2.822445 (Latest)
Release date:
Jul 7, 2026
New Features:
- WiiM Radio: Added support for WiiM Radio.
- Automatic Updates: Adds support for delaying automatic firmware updates, configurable in the WiiM Home app.
Audio & Playback:
- Playback Stuttering: Reduces stuttering during music playback.
- Qobuz: Fixes a crash issue when using Qobuz.
- Amazon Music: Fixed an issue where Amazon Music could skip tracks unexpectedly.
5.2.740129
Release date:
Dec 29, 2025
General Improvements:
- Wi-Fi: Stronger connection stability; improved compatibility with Wi-Fi 7 routers.
- Queue: Better track order retention in shuffle and faster queue operations across NAS/USB/Samba/Local, TIDAL, Qobuz, Radio Paradise, YouTube, Deezer, and SoundCloud.
- Multi-room: Improved multicast logic for more reliable discovery/connectivity; reduced stutter when using Bluetooth input.
Music Services:
- Qobuz: Stabilized progress bar; fixed shuffle dropouts, playback-mode mismatch, and missing artist/track metadata.
- Soundtrack: Updated SDK; fixed disconnects when renaming the device during playback.
- Amazon Music: Fixed position reset after back-to-back seeks.
- TuneIn: Now consistently selects the highest available stream quality.
- Radio: Resolved failures for certain station formats.
5.2.727354
Release date:
8 / 25 / 2025
What's New:
- Roon Ready Certified: Seamless bit-perfect streaming from Roon. Tip: if A10/C10 doesn't appear in Roon after updating, simply restart the Roon app.
- Amazon Music: Bitrate information is now displayed when streaming Amazon Music Prime.
- Sub Pro Intergartion: Improved pairing experience and overall functionality when using the Sub Pro.
- Soundtrack SDK Upgrade: Under-the-hood improvements for a smoother, more consistent listening experience.
5.2.725449
Release date:
8 / 6 / 2025
What's New:
- Room Correction & EQ Integration: Room Correction and EQ now work together to provide an optimized listening experience. Learn More
- Stabilized Wi-Fi Connection: Enhanced connection reliability, especially for mesh network environments.
Bug Fixes:
- Alarm Fixes:
- Resolved an issue where weekly alarms occasionally failed to trigger.
- Fixed a bug where only the default tone played for Pandora alarm.
- Playing Status: Corrected the playback status indicator when no music is playing.
- Qobuz: Now displays the correct artist name in the app during playback.
5.2.721629
Release date:
6 / 30 / 2025
What's New:
- Time Sync: More robust NTP timing for music service login.
- Pandora Thumbs Up/Down: Instantly like or dislike tracks from your device.
- Spotify Connect Continuity: Seamlessly resume Spotify playback after switching inputs.
- Audio Input Management: Choose which audio inputs to display and switch between them easily.
- Upgraded Soundtrack SDK: Enhanced audio processing for superior sound quality.
- HotMix Preset: Added support for HotMix Preset.
Bug Fixes:
- Deezer Enhancement: Resolved playback freezing with large Deezer playlists.
- Optimized CPU Performance: Reduced CPU usage during EQ adjustments.
- General Fixes: General performance and stability improvements.
5.2.718334
Release date:
5 / 27 / 2025
What's New:
- Preset Enhancements:
- Move presets (requires app v3.1.4).
- Presets now work in follower mode.
- Playback Enhancements:
- Fixed incorrect playback status and Replay Gain issues after seeking.
- Resolved multi-room audio crashes and fixed a skipping issue at the end of some MP3 files.
- My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4).
- TIDAL Queue Enhancements: Improved shuffle functionality with track order retention and faster queue performance.
- TIDAL Auto Play: Now supports auto-play; enable it in the WiiM Home App.
- Spotify Loudness Normalization: Added support for Spotify’s Loudness Normalization.
- Enhanced Radio Paradise: Added Serenity, Radio 2025, and My Favorites Mix stations with track-skipping support.
- Device Discovery Enhancements: Improved stability and connectivity for WiiM Home, Spotify, and TIDAL apps.
- Soundtrack SDK Upgrade: Enhanced performance for a smoother listening experience.
- Track-End Sleep Timer: New option to pause playback at the end of a track—perfect for winding down.
- Auto-Resume Playback for Soundtrack: Playback resumes automatically after OTA updates, reboots, or network reconnections.
- Pandora Thumbs Up/Down: Added support for thumbs up and thumbs down functionality on Pandora (requires app version 3.2.2+).
- Spotify Connect Playback Continuity: Spotify Connect playback context now remains intact for easy resumption when switching between inputs.
Bug Fixes & Performance Improvements:
- Qobuz Login Fix: Fixed an intermittent issue preventing Qobuz logins.
- Spotify Presets: Resolved unexpected ungrouping during group playback.
- Qobuz: Fixed track-start issues after skipping and unexpected playback jumps.
- Plex Playback Fix: Resolved playback failure when Secure Connections is set to "Required".
- TIDAL Connect Fix: Addressed the issue of track skipping delay and corrected track duration when using the HTTP API.
- General Performance: Stability improvements and behind-the-scenes optimizations.
