If you're experiencing issues with discovering WiiM devices on your network using a TP-Link Deco series router, follow these steps to set up IP Address Reservation. This can help ensure stable connectivity for your devices.
Setting Up IP Address Reservation for a WiiM Device
1. Access Advanced Settings:
- Open the Deco app on your device.
- Navigate to the 'More' tab.
- Select 'Advanced'.
2. Initiate Address Reservation:
- Within the Advanced menu, find and select 'Address Reservation'.
3. Add a New Reservation:
- Tap the '+' icon located at the top right corner of the Address Reservation screen.
- Choose 'Select from Client List' to view connected devices.
4. Select and Save:
- From the list, find and select your WiiM device.
- Confirm by tapping 'Save' to reserve the IP address for your WiiM device.
By following these steps, your WiiM devices should maintain a consistent connection to your TP-Link Deco router, improving overall network stability.
