Overview
WiiM device is designed primarily for audio and does not support video casting. This means you cannot cast audio directly from the YouTube app to the WiiM device.
However, there is an alternative method that allows you to cast audio from YouTube and other various apps on Android to the WiiM device.
Before You Begin
Before adding WiiM devices to a Google Cast speaker group, make sure that they are assigned to any room in the Google Home app.
For detailed instructions, see How to Add a WiiM Device to a Room in the Google Home App.
Instructions
Video Tutorial
Follow the video tutorial below:
Step-by-Step Guide
Alternatively, follow the text instructions below:
  1. Connect to the Same Wi-Fi Network: Make sure your Android device and WiiM device are connected to the same Wi-Fi network.
  2. Open the Google Home App: Tap on the Google Home app on your Android device to open it.
  3. Play a Video (or Song): Start playing the video or song you want to cast on the YouTube app.
  4. Tap the Devices tab on the Google Home app.
  5. Select Your WiiM Device: A list of available devices will appear. Tap on your WiiM device to which you want to cast.
  6. Tap the Cast my audio to stream audio to WiiM device:
  7. Control Playback: You can now control playback (play, pause, skip, adjust volume) directly from your Android device.
  8. Stop Casting: To stop casting, tap on the cast icon again and then tap on "Stop Casting."
Note: Ensure that both your YouTube app and WiiM device are updated to their latest versions to ensure optimal performance and compatibility.
