The firmware update is performed in batches such that the devices take turns getting updated. All the devices will be updated during the next few days.
Please find the list of known issues here that we're working around the clock to fix and release a solution by the ETA.
Please note the device firmware version is different from the version of the WiiM Home App. You can check your device's firmware version on the WiiM Home App. Please select the Device tab > Tap the device setting gear icon (i.e., the Cog Wheel) > Speaker Info > Firmware Version.
4.8.833748 (In Progress)
Release date: October 27, 2026
What's New
1.
Google Cast: Added support for WiiM multi-room playback and wireless WiiM Sub Pro output.
2.
Presto Music: Added support for Presto Music (requires the latest app version).
Music & Streaming
1.
TIDAL Connect: Reduced playback stuttering.
2.
Spotify Connect: Reduced playback stuttering.
3.
Alexa Multi-Room Music: Reduced CPU usage.
4.
Squeezelite: Updated the SDK to improve playback stability.
General Improvements
1.
Network: Improved Ethernet stability and IPv6 address handling.
4.8.827634
Release date: August 28, 2026
Audio & Playback
1.
Multi-Room Playback: Improved synchronization and playback stability during multi-room playback.
2.
Spotify Connect: Fixed pop noise when skipping tracks and prevented certain speakers from leaving the group when starting playback.
4.8.826751
Release date: August 19, 2026
What's New
1.
Auto Headroom: Added automatic headroom adjustment to help prevent audio clipping. You can disable this feature via the latest WiiM Home App. Learn More >>
2.
Multi-Room Audio: Improved audio quality during multi-room playback.
3.
Soundtrack: Updated the SDK to improve playback stability and performance.
4.
iHeartRadio: Added FLV support for additional radio stations.
5.
Qobuz Connect: Updated the SDK to improve playback stability.
6.
WiiM Radio: Added support for WiiM Radio.
Bug fixed
1.
AirPlay: Improved playback stability.
2.
Sound Machine: Fixed an issue where playback could stop unexpectedly.
3.
Open Network Stream: Fixed an issue where playback might not resume after a long pause.
4.
Bluetooth: Reduced playback stuttering and fixed an issue where the Bluetooth name did not update after renaming the device.
5.
4.8.814756
Release date: April 23, 2026
New Features & General Improvements
1.
2.
3.
EQ: Faster response when adjusting or switching EQ settings; now supports EQ for Dolby 5.1 playback.
4.
5.
Radio & Streaming Services
1.
2.
3.
4.
Live Metadata: Added ICY support for richer “now playing” info on TuneIn, iHeartRadio.
5.
Qobuz: Added Track Radio / Artist Radio / Album Radio.
6.
vTuner: Improved reliability with backup stream URL fallback.
7.
SoundCloud: Added third-party login support.
8.
iHeartRadio / Pandora: Fixed intermittent stops and unexpected skipping.
9.
Plex: Fixed alarm progress display, station history playback failures, and occasional early skips.
10.
Amazon Music: Fixed interruptions when playing short playlists.
11.
Playback & Audio
1.
Optical In: Fixed dropouts caused by input stream format changes.
2.
Short-Track Transitions: Improved near-end handling to prevent skipping or audio “leakage.”.
3.
Track Skips: Resolved multiple cases of unexpected skipping / premature track changes across services.
4.
Line In: Fixed distortion during extended playback sessions.
5.
Audio Sync: Improved sync accuracy at microsecond level for better group playback.
4.8.805729
Release date: January 26, 2026
Playback & Audio
1.
Input Switching: Reduced occasional delays when switching input modes.
2.
Playback Queue: Fixed an issue where the queued next track might not start playing.
3.
High-Resolution Playback: Reduced playback stuttering (up to 192kHz/24-bit) when EQ/Room Correction and Wireless Sub Pro are enabled.
4.
Playback State: Improved playback state accuracy when switching between inputs and Spotify.
Multiroom & Discovery
1.
Multiroom: Improved stability with certain routers.
2.
Service Discovery: Improved Spotify/Qobuz/TIDAL Connect discovery reliability after IP address changes.
Streaming Services
1.
Amazon Prime Music: Prevented logout after startup.
2.
Qobuz Connect: Improved stability and app sync when changing playback mode.
3.
vTuner Radio: Added a backup stream URL fallback to improve playback reliability.
Sync & Platform
1.
Sync Audio: Improved low-volume accuracy.
2.
Platform Networking: Improved HTTP performance by upgrading to a modern HTTP server.
4.8.738046
Release date: December 8, 2025
What's New
1.
Alarms: Custom labels and up to 32 alarms.
2.
Logitech Media Server (LMS): Disabled by default; enable in Device Settings in the WiiM Home app.
3.
12V Trigger: Status now shown in the app; supports a one time on/off toggle from the app.
4.
TuneIn: Faster start when playing Apple Music stations.
5.
Multi-room: Improved multicast logic for more reliable discovery/connectivity; reduced stutter when using Bluetooth input.
Bug Fixes
1.
Playback:
- Corrected playback state display in certain cases.
- Fixes for TuneIn Radio and certain FLAC files.
2.
Sub Output: Fixed missing bass when the wireless WiiM Sub Pro was disconnected.
3.
Qobuz Connect:
- Resolved a blocking issue that prevented playback.
- Fixed a crash that could occur after seeking.
4.
Spotify: Fixed failures to play from the Spotify app’s Recommended lists and Recently Played; also fixed presets that would not start playback.
5.
Amazon Music: Fixed occasional track skips after seeking and a progress bar desync (bar reached the end while audio continued)
6.
Multi-room: After ungrouping, metadata no longer syncs to previously grouped (child) speakers.
7.
Gapless Player: Fixed a near track end race condition that could trigger overlapping/simultaneous playback.
8.
Local Files: Fixed an issue where the app progress bar reached the end before playback finished.
9.
10.
Amazon Music: Fixed unexpected stops when using Amazon Music Cast.
4.8.731953
Release date: October 10, 2025
What's New
1.
TuneIn: Automatically selects the highest-quality stream.
Bug Fixes
1.
YouTube Music: Fixed playback noise and incorrect metadata.
2.
TIDAL Connect: Corrected metadata display.
3.
Qobuz Connect: Fixed the issue where gapless playback was not working.
4.
Google Cast: Fixed occasional no-sound issues.
5.
SoundTrack: Fixed missing audio during the first two seconds of announcements.
6.
YouTube Music Group Playback: Fixed no-sound issue when switching to group playback.
4.8.726839
Release date: August 20, 2025
Bug Fix
1.
No Bass Audio: Fixed an issue that caused bass audio not to output.
4.8.726230
Release date: August 14, 2025
What's New
1.
Room Correction & EQ Integration: Room Correction and EQ now work together to provide an optimized listening experience.
2.
3.
Amazon Music: Bitrate information is now displayed when streaming Amazon Music Prime.
4.
Sub Pro Intergartion: Improved pairing experience and overall functionality when using the Sub Pro.
5.
YouTube Music: Native, seamless streaming support. (requires the upcoming app version 3.3.1)
6.
Soundtrack SDK Upgrade: Under-the-hood improvements for a smoother, more consistent listening experience.
Bug Fixes
1.
Alarm Fixes:
- Resolved an issue where weekly alarms occasionally failed to trigger.
- Fixed a bug where only the default tone played for Pandora alarm.
2.
Playing Status: Corrected the playback status indicator when no music is playing.
3.
Qobuz: Now displays the correct artist name in the app during playback.
4.
Bluetooth Output: Fixed a no-audio issue after switching outputs.
5.
NAS Playback: Playback now correctly restarts from the beginning after the last track finishes.
6.
Playback Speed: Resolved rare cases where songs played at accelerated speed.
4.8.724036
Release date: July 23, 2025
What's New
1.
Advanced Parametric EQ: High-Pass & Low-Pass filters now available (App v3.2.6+ required)
2.
Deezer: “Play Next / Play Last” options added.
3.
Bluetooth: Adjustable latency for perfectly synced audio.
Bug Fixes
1.
Soundtrack Pairing: Fixed an issue preventing successful soundtrack pairing.
2.
Gapless Playback: Fixed an issue causing incomplete audio playback.
3.
General Fixes: General performance and stability improvements.
4.8.721260
Release date: June 26, 2025
What's New
1.
Time Sync: More robust NTP timing for music service login.
2.
Pandora Thumbs Up/Down: Instantly like or dislike tracks from your device.
3.
Spotify Connect Continuity: Seamlessly resume Spotify playback after switching inputs.
4.
Audio Input Management: Choose which audio inputs to display and switch between them easily.
5.
Upgraded Soundtrack SDK: Enhanced audio processing for superior sound quality.
6.
HotMix Preset: Added support for HotMix Preset.
Bug Fixes
1.
Deezer Enhancement: Resolved playback freezing with large Deezer playlists.
2.
Optimized CPU Performance: Reduced CPU usage during EQ adjustments.
3.
Optical-in Playback Correction: Fixed swapped audio channel issue for optical input.
4.
4.8.717049
Release date: May 15, 2025
What's New
1.
Queue Limit Update: Playback queue is now capped at 3,000 tracks to improve performance. Further optimizations are in progress.
2.
Enhanced DSD Playback: Resolved stuttering during multi-channel DSD file playback for smoother high-res listening.
3.
Stabilized Wi-Fi Connection: Updated the Wi-Fi driver to enhance connection stability.
4.
Device Discovery Enhancements: Improved stability and connectivity for WiiM Home, Spotify and TIDAL apps.
Bug Fixes
1.
Plex Playback Fix: Resolved playback failure when Secure Connections is set to "Required".
2.
TIDAL Connect Fix: Addressed the issue of track skipping delay and corrected track duration when using the HTTP API.
3.
General Performance: Stability improvements and behind-the-scenes optimizations.
4.8.714841
Release date: April 24, 2025
What's New
1.
Auto-Resume Playback for Soundtrack: Playback resumes automatically after OTA updates, reboots, or network reconnections.
2.
Wi-Fi Boost: Faster network scanning and connection times.
3.
Roon Sync: Improved multi-room sync for Roon users.
Bug Fixes
1.
Amazon Music: Fixed playback issues for Prime users.
2.
Spotify Presets: Resolved unexpected ungrouping during group playback.
3.
TIDAL: Fixed skipping, playback errors, and incorrect quality cap on 24-bit/96kHz optical/coax outputs.
4.
Qobuz: Fixed track-start issues after skipping and unexpected playback jumps.
5.
Radio Paradise Enhancements: Resolved issues with track repetition during playback and fixed login failures caused by special characters.
6.
Alarm Fix: Resolved issues affecting alarms in Daylight Saving Time zones.
7.
4.8.712747
Release date: April 3, 2025
What's New
1.
TIDAL Queue Enhancements: Improved shuffle functionality with track order retention and faster queue performance.
2.
TIDAL Auto Play: Now supports auto-play; enable it in the WiiM Home App.
3.
Spotify Loudness Normalization: Added support for Spotify’s Loudness Normalization.
4.
Enhanced Radio Paradise: Added Serenity, Radio 2025, and My Favorites Mix stations with track-skipping support.
5.
Improved Presets in Group Playback: Presets now function correctly when the device is in follower mode.
6.
Device Discovery Enhancements: Improved stability and connectivity for WiiM Home, Spotify, and TIDAL apps.
7.
Playback Fixes: Resolved multi-room audio crashes and fixed a skipping issue at the end of some MP3 files.
8.
End-of-Track Option for Sleep Timer: Automatically pause playback at the end of a track (requires upcoming app update)
9.
Media Player Enhancements:
- Improved support for certain m3u8/HLS formats.
- Now displays original album artwork when streaming from NAS.
- Fixed SiriusXM playback via Alexa.
Bug Fixes
1.
Amazon Music: Resolved playback issues for Amazon Prime users.
2.
Spotify Presets: Fixed issue where group playback would unexpectedly ungroup.
3.
KKBox Playback Fix: Resolved the playback skipping issue.
4.
Performance: General optimizations and stability improvements.
4.8.709965
Release date: March 6, 2025
What's New
1.
My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4)
2.
Preset EnhancemPents:
- Move presets (requires app v3.1.4)
- Presets now work in follower mode.
3.
Soundtrack SDK Enhancement: Upgraded for a better listening experience.
4.
Wi-Fi Stability: Improved connection reliability, especially for mesh networks.
5.
Gapless Playback Enhancement: Fixed an issue that caused skipping when playing tracks shorter than 10 seconds.
6.
Playback Enhancements: Fixed playback crashes, resolved a 2-second audio loss issue with APE format, and improved Bluetooth playback stability.
7.
Smart Preset Enhancement: Added support for the Sub Output option in Smart Presets for greater customization.
8.
Resample Algorithm Enhancement: Upgraded the resample algorithm to ensure high sound quality when resampling to 96 kHz or lower.
Bug Fixes
1.
Radio Paradise Fix: Corrected a playback failure issue.
2.
Pop Noise Reduction: Reduced pop noises when switching inputs.
3.
LMS Fix: Fixed LMS reconnection issue.
4.8.704531
Release date: January 14, 2025
Bug Fixes
1.
Room Correction Fix: Resolved an issue that prevented the completion of Room Correction.
4.8.704151
Release date: January 10, 2025
What's New
1.
Persistent Group Support: Enhanced quick selection and synchronization for multi-room audio across devices. Learn More >>. Learn More >>
2.
Replay Gain Enhancements: Replay Gain now supported for USB, NAS, Samba, and local libraries (requires app version 3.1.0)
3.
4.
TIDAL Connect SDK Update: Upgraded for improved playback stability and resolved crash issues.
5.
Remote Volume Step Customization: Adjust the volume step for each press of the remote’s volume buttons (requires app version 3.1.0)
6.
Remote Troubleshooting Improvements: Remote exception status is now provided to the app to assist with troubleshooting (requires app version 3.1.0)
7.
Network Setup: In Setup mode, hold the play/pause button for 3 seconds to cancel the setup.
Bug Fixes
1.
Playback Enhancements: Fixed playback status after seeking, resolved artwork issues via Google Cast, and added sample rate/bit depth display on Alexa.
2.
Alarm Fix: Alarms now stop correctly, even when the selected music is unavailable.
3.
LMS Volume Control: Resolved an issue where Fixed Volume settings were lost for LMS Volume Control.
4.
General Fixes: Various performance improvements and bug fixes.
4.8.639134
Release date: December 19, 2024
What's New
1.
Room Correction with Independent L/R Channels: Fine-tune each audio channel independently for a richer, more immersive sound experience. (Requires app version 3.0.3 or higher)
2.
KKBox Integration: Enjoy seamless streaming with KKBox, now fully supported within the app. (Requires app version 3.0.4 or higher)
3.
LMS Server Selection: Select your preferred LMS (Lyrion Media Server) based on IP for more flexibility in playback. (Requires app version 3.0.4 or higher)
4.
Enhanced Alarm Functionality: If your chosen music isn't available, fallback sounds will ensure you never miss your alarm.
5.
Replay Gain: Added support for TIDAL, Qobuz and Plex (requires app version 3.0.0+).
6.
Bluetooth Sound Control: Disabled connection notifications.
Bug Fixes
1.
Remote Pairing: Resolved issues preventing WiiM Remote from connecting to devices.
2.
Playback Fixes: Improved metadata handling, resolved skipping/seeking issues, added WMA Lossless support, fixed Icecast playback, and reduced Preset latency.
3.
General Enhancements: Various performance boosts and bug fixes.
4.8.634146
Release date: October 31, 2024
What's New
1.
Improved Alarm Behavior for Plex: Default alarm sound will now play if Plex server is unavailable.
2.
- Fixed an issue where playback could not resume after Wi-Fi reconnection.
- Fixed an issue preventing Audible Books from playing through Alexa.
- Fixed noise issue when resuming Amazon Music.
- Fixed playback crash for Deezer alarms and presets.
- Corrected metadata for custom radio stations.
- Fixed no sound when switching between Bluetooth, Line or Optical inputs.
3.
Improved Input Auto-Sensing: Optimized for smoother audio transitions with minimized delay.
Bug Fixes
1.
Sync Audio Fix: Fixed an occasional error for Sync Audio.
2.
Alarm Time Fix: Corrected rare incorrect alarm issue.
3.
Group Stability: Fixed unexpected device removal from group.
4.
General Enhancements: Various performance improvements and bug fixes to enhance overall operation.
4.8.630831
Release date: October 11, 2024
What's New
1.
Plex Support (Beta): Integrated Plex for direct music access and playback in the WiiM Home app (requires app version 2.11.6 or later)
2.
- Fixed occasional no sound issues with Alexa Multi-room and Bluetooth Input.
- Corrected metadata for custom radio stations and reduced cracking noise in some MP3 files.
- Reduce playback stuttering for various input sources.
- Improved real-time playback after resuming from radio streams.
3.
Graphic EQ Optimization: Reduced CPU usage for improved performance.
Bug Fixes
1.
2.
General Enhancements: Various bug fixes and performance improvements.
4.8.628343
Release date: September 4, 2024
Playback Improvements
1.
Resolve issues with Amazon Music, including skipping during playback and inability to start playback.
2.
Correct metadata now displays when seeking frequently.
3.
Resolve an issue preventing Audible Books from playing through Alexa.
4.
Fix playback issues with certain M3U8 formats.
5.
Address occasional Bluetooth playback crashes.
Bug Fixes
1.
Roon Ready Metadata: Fix an issue where playing Radio via Roon Ready did not display the correct metadata.
2.
DLNA Playback Enhancement: Correct an issue that caused tracks to be skipped during DLNA playback via Bubble UPnP.
3.
General Enhancements: Various bug fixes and performance improvements for a smoother experience.
4.8.626448
Release date: August 16, 2024
What's New
1.
Per-Channel EQ: Set parametric EQ settings for left and right channels individually (requires app version 2.10.7 or later)
2.
Pre-Gain Feature: Added logic for Pre-Gain functionality. Compatible with app version 2.11.0 and above.
3.
Enhanced Stability: Fixed crashes with Spotify Connect and TIDAL Connect.
4.
Refined Input Auto-Sensing: Enhanced for smoother audio transitions with reduced delay.
5.
Output Change Enhancement: Preserves the playing queue when switching audio outputs.
6.
7.
Bluetooth Playback Upgrade: Enhanced Bluetooth playback to reduce latency and eliminate stuttering issues.
8.
DSD Playback Enhancement: Now supports playing DSD audio tracks in DFF format.
9.
10.
Playback Improvements:
- Fixed TIDAL playback skipping and stopping issues.
- Resolved Bluetooth playback distortion over long periods.
- Provide the correct playback index for the app to display.
Bug Fixes
1.
Playback Enhancement: Minimized playback latency.
2.
Squeezelite Enhancements: Resolved issues with artwork display and connectivity with the latest Lyrion Media Server (LMS)
3.
Pop Noise Fix: Reduced pop noise for Spotify Connect and TIDAL Connect.
4.
4.8.623428
Release date: July 17, 2024
What's New
1.
Samba Protocol: Now supports Samba for music playback, including DSD audio files. Requires Android app version 2.10.4 or later and the upcoming iOS update (2.10.6)
2.
Media Player Optimization:
- Fixed issues with certain m3u8/HLS format audio.
- Displays original album artwork in the WiiM Home app when playing from a NAS.
- Resolved the issue preventing Sirius XM playback via Alexa.
Bug Fixes
1.
Pop Noise Fix: Reduced pop noise for Google Cast Audio.
2.
Resampling Accuracy: Improved resampling accuracy in fixed sample rate resampling.
3.
4.8.622165
Release date: July 4, 2024
What's New
1.
DLNA Behaviors Enhancement: Added support for loop and shuffle modes in DLNA playback.
2.
TIDAL Connect Enhancements: Fixed playback stops, loop and shuffle issues, and incorrect playing status. Correct metadata now displays in multi-room audio.
3.
HTTP API Update: Updated to provide browse and control Presets.
Bug Fixes
1.
Alarm Behavior for Spotify Connect: Fixed alarm not stopping automatically when duration ended.
2.
Pop Noise Reduction: Resolved occasional popping noises occurring at 16-bit/44.1 kHz or 16-bit/48 kHz.
3.
4.8.620450
Release date: June 18, 2024
What's New
1.
Room Correction: Optimize your speakers to match your room's acoustics with the new Room Correction feature, compatible with the upcoming iOS app update.
2.
Qobuz Login Enhancement: Updated Qobuz OAuth2 login to support third-party login.
3.
Refined Input Auto-Sensing: Enhanced behavior ensures seamless audio transitions.
4.
HTTP API Update: Updated to provide complete current playback information.
Bug Fixes
1.
EQ Issues: Fixed EQ adjustments in inactive modes and ensured EQ works for Bluetooth sources.
2.
Soundtrack Memory: Optimized memory usage for better performance.
3.
TIDAL Connect: Fixed incorrect artwork display.
4.
Bluetooth Latency: Resolved increased playback latency via Bluetooth.
4.8.619258
What's New
1.
Control 4 Integration: Seamlessly integrate with Control4 systems for enhanced smart home control.
2.
Refined Input Auto-Sensing: Enhanced auto-sensing ensures smooth audio transitions without interruptions, automatically switching inputs only when there is no active playback.
3.
Enhanced Alarm Behavior: Alarms now increase smoothly to the set volume without interrupting ongoing playback.
4.
Fixed optical or coaxial output resolution: Resolved the pop noise issue when changing the sample rate. Find the settings in Device Settings -> Audio Settings -> SPDIF/COAX Output Resolution.
Bug Fixes
1.
Pandora Login Issue: Resolved an issue causing frequent re-logins.
2.
EQ Toggle Issue: Corrected a bug preventing toggling EQ settings on or off.
3.
Spotify Connect Progress Tracking: Fixed inaccuracies in playback progress for Spotify Connect.
4.
Spotify Connect Artwork Display: Resolved an intermittent issue where the incorrect artwork was occasionally displayed.
5.
4.8.616634
Release date: May 11, 2024
What's New
1.
10-band PEQ: Tailor sound with the new Parametric Equalizer, fully supported in the upcoming app update (Ver 2.9.7)
2.
Enhanced DHCP Compatibility: Improved stability and reliability across various routers.
3.
Refined Input Auto-Sensing: Updated technology for seamless audio transitions.
4.
Faster Optical Detection: Quicker audio signal recognition from optical inputs.
5.
Soundtrack SDK Enhancement: Upgraded for an improved listening experience.
Bug Fixes
1.
TIDAL Connect Stability: Fixed crashes and bitrate display issues.
2.
Optical-in Playback Correction: Addressed swapped audio channels in optical input.
3.
General Enhancements: Various performance improvements and bug fixes for smoother operation.
4.8.614042
Release date: April 16, 2024
What's New
1.
Per-Source EQ (App version 2.9.0+ required): Customize EQ settings for each input source individually.
2.
Faster Optical Detection: Quicker detection of audio from Optical inputs.
3.
Enhanced DHCP Stability: Upgraded DHCP service for improved network stability and connectivity.
Bug Fixes
1.
Track Metadata XML Fix: Resolved an issue with missing xmlns:song namespace in Track Metadata XML for better metadata management.
2.
AAC/ALAC Bitrate Display Fix: Accurately displays the correct bitrate for AAC and ALAC formats.
3.
Remote Pairing Stability: Improved the pairing process of the WiiM Voice Remote for more reliable connectivity.
4.8.612733
Release date: April 3, 2024
What's New
1.
Soundtrack SDK Enhanced: We've upgraded the Soundtrack SDK to improve your listening experience.
Bug Fixes
1.
Resolved Pandora Crash Issue: The issue causing Pandora to crash has been fixed, ensuring uninterrupted listening.
4.8.612036
Release date: March 28, 2024
Bug Fixes
1.
Pandora Stability: Fixed the issue with Pandora for a smoother listening experience.
2.
AirPlay Fade-in/Fade-out: Fixed the Fade-in and Fade-out settings for AirPlay streaming.
4.8.611135
Release date: March 18, 2024
Bug Fixes
1.
12V Trigger Output Stability: Fixed a bug that ensures the 12V Trigger stays active with the device, eliminating accidental shutdowns.
2.
Bluetooth Playback Improvement: Addressed and resolved stuttering during playback with certain Bluetooth headphones and earphones, providing a seamless audio experience.
3.
Preset Management Enhancement: Corrected an issue that prevented preset replacement, enhancing the feature's reliability and user experience.
4.8.609136
Release date: February 29, 2024
What's New
1.
Custom Radio Metadata: Now with dynamic track information, compatible with our latest app.
2.
Soundtrack Your Brand Integration: Transform your business ambiance with Soundtrack Your Brand. Gain legal access to an unparalleled commercial music catalog boasting over 100 million songs, designed to enrich your commercial space effortlessly.
3.
New Wi-Fi Disconnection Indicator: The device status light now glows yellow to signal Wi-Fi disconnection, replacing the previous solid red indicator.
4.
Improved 12V Trigger Output:
- Standby Mode Synchronization: The 12V Trigger now reflects the device’s Standby status, activating with device use and deactivating in idle mode.
- Improved Standby Efficiency: For devices set to remain always on, the 12V Trigger will now automatically shut off after 5 minutes of inactivity, enhancing energy efficiency.
4.8.606344
Release date: February 1, 2024
What's New
1.
12V Trigger Out Enhancement: The trigger will now turn on or off immediately when the power is switched on or off via the Remote. Additionally, it will automatically shut off after 5 minutes if the device is inactive.
Bug Fixes
1.
Improved Remote Connection Stability: Enhanced the stability of the connection between the WiiM Voice Remote and your WiiM device.
2.
TIDAL Connect Stability: Resolved unexpected crashes when using TIDAL Connect, ensuring a more reliable streaming experience.
4.8.605650
Release date: January 24, 2024
What's New
1.
Per-Source Volume Control: Introducing individual volume control with memory for Optical In, Line In, Wi-Fi, and Ethernet input sources , allowing for a tailored listening experience on your device. (Compatible with the upcoming app update in a few days.)
Bug Fixes
1.
Stabilized Wi-Fi Connection: Addressed and fixed a Wi-Fi exception issue, significantly enhancing Wi-Fi stability.
2.
Continuous Volume Increase Issue Resolved: Corrected a problem where volume would continuously increase when using Spotify Connect.
3.
LMS Playback Distortion Resolved: Addressed and corrected the distortion issue encountered during playback through the Lyrion Media Server (LMS)
4.
Multi-Room Audio Stabilization for Line-in: Fixed the stuttering issue observed in multi-room audio playback when using the Line-in input source.
5.
Enhanced Playback Status Accuracy: Resolved a problem in the WiiM Home app to accurately display the playback status when switching to Line-in or Optical-in input sources.
6.
General Enhancements: Various other bug fixes and performance improvements for a smoother experience.
4.8.604350
Release date: January 11, 2024
What's New
1.
Enhanced Volume Balance (Compatible with the Latest App): We've introduced a Volume Balance feature, allowing you to fine-tune the audio levels between the left and right channels for a more personalized listening experience.
2.
Optimized Wi-Fi Connectivity with Mesh Network: Enjoy uninterrupted connectivity as your device intelligently selects the strongest Wi-Fi access point, ensuring a stable and robust connection.
3.
Qobuz Autoplay Integration: When your music queue ends, Qobuz takes over by playing similar tracks, keeping the music flowing without interruption.
Bug Fixes
1.
2.
4.8.540047
Release date: December 30, 2023
Bug Fixes
1.
Qobuz Playback Improvement: Implemented a feature to automatically skip to the next track if the current one is unavailable, maintaining a seamless listening flow.
2.
3.
Update Behavior Correction: Corrected an issue where updates would inadvertently initiate during playback from Line-in or Optical-in. Updates will now occur at more appropriate times to avoid disruption.
4.
Google Cast Playback Issue: Fixed a bug that resulted in no sound when using Google Cast . Users can now seamlessly transition to Google Cast without audio interruptions.
4.8.539349
Release date: December 21, 2023
What's New
1.
SPDIF Input Enhancement: Upgraded our SPDIF input with an advanced anti-drift mechanism and a refined resampling algorithm, ensuring smoother and more stable playback.
Bug Fixes
1.
2.
Spotify Connect Stability: Fixed the unresponsiveness issue in Spotify Connect for a smoother user experience.
3.
Deezer Playback Improvement: Implemented a feature to automatically skip to the next track if the current one is unavailable, maintaining a seamless listening flow.
4.
Volume Adjustment Stability: Fixed a crash issue related to volume adjustment, enhancing overall system stability.
5.
Enhanced Squeezelite Playback Stability: Fixed intermittent popping sounds after track seeking, improving playback quality.
6.
4.8.537952
Release date: December 7, 2023
What's New
1.
Distinct Status Light Indicators for Input Sources:
- Optical-in sources now display an orange light.
- Line-in sources are indicated with a light green light.
- Bluetooth sources are represented by a pure green light.
Bug Fixes
1.
Enhanced EQ Experience: Resolved an issue where playback would stop when switching between PEQ (Parametric EQ) and GEQ (Graphic EQ). Reduced CPU usage during EQ operations for more efficient performance.
2.
TIDAL Connect Stability Enhancements: Addressed and fixed unexpected crashes when using TIDAL Connect, ensuring a more reliable streaming experience.
3.
Calm Radio Login Fix: Resolved an issue preventing login to Calm Radio accounts containing the "$" character.
4.
Google Cast Playback Control with Spotify: Fixed an issue where playback controls were unresponsive when streaming Spotify via Google Cast.
4.8.537050
Release date: November 29, 2023
What's New
1.
TIDAL Hi-Res FLAC in WiiM Home App: We've introduced TIDAL Hi-Res FLAC support, allowing you to stream directly up to 24-bit/192kHz.
2.
Napster API Upgrade: We've updated to the latest Napster API for enhanced and more reliable streaming.
Bug Fixes
1.
TuneIn Custom URL Preset Issue Resolved: Fixed the issue with TuneIn Custom URL presets.
2.
Bluetooth Streaming Reliability: Addressed occasional crashes during Bluetooth streaming.
3.
4.6.536237
Release date: November 20, 2023
Bug Fixes
1.
Enhanced Remote Pairing Stability: Improved the pairing stability of the WiiM Voice Remote, ensuring a more reliable and seamless connection experience.
2.
TIDAL Connect Stability Improvements: Fixed problems with TIDAL Connect, including unplayable tracks and unexpected crashes, for a smoother streaming experience.
3.
Spotify Connect Playback Optimization: Resolved the brief silence encountered during the first half-second of song playback on Spotify Connect, ensuring uninterrupted audio from the very start of each track.
4.8.534064
Release date: October 29, 2023
What's New
1.
TIDAL Hi-Res FLAC Support: Introducing support for TIDAL Hi-Res FLAC via TIDAL Connect, enabling direct streaming up to 24-bit/192kHz from TIDAL App.
2.
Spotify Connect Upgrade: Transitioned to the latest Spotify Connect ESDK for an enhanced user experience.
Bug Fixes
1.
Service Access: Resolve a rare issue where incorrect system time settings prevented users from accessing services.
2.
Other bug fixes and performance improvements.
4.8.532836
Release date: October 18, 2023
What's New
1.
Enhanced Amazon Music HD Streaming: Memory optimization now allows for smoother 24-bit/192kHz audio streaming on Amazon Music HD.
Bug Fixes
1.
TuneIn Radio Playback: Resolved issues that were blocking playback on select TuneIn radio stations.
2.
WiiM Voice Remote Pairing: Fixed intermittent pairing issues with the WiiM Voice Remote for a more reliable connection.
3.
Bluetooth EQ Settings: Corrected EQ settings for enhanced audio output in Bluetooth mode.
4.8.530554
Release date: September 26, 2023
What's New
1.
Improved in-App Deezer experience: Deezer update with new API and functions. Please re-login to Deezer via the WiiM Home app.
2.
Optical Input Boost: Now enjoy multi-room audio over 48 kHz/16-bit on optical input.
Bug Fixes
1.
Enhanced EQ Stability: Maintain Line-in or Optical-in input when switching between PEQ and GEQ.
2.
Enhanced Stability: Fix occasional crashes during volume adjustment.
3.
Alexa TTS: Fix noise distortion in Alexa TTS when using BT source mode.
4.
Radio Paradise Artwork on Squeezelite: Fix artwork display for the Radio Paradise on Squeezelite.
5.
Roon on Squeezelite: Fix the silence when casting audio via Squeezelite.
6.
Play Queue
- Corrected track ordering when adding multiple Amazon albums.
7.
TIDAL Access: Resolved issues with third-party authentication for TIDAL access.
4.8.529056
Release date: September 11, 2023
This update includes
1.
New Feature
- Parametric EQ (Compatible with App version 2.5.5 or higher)
2.
New Feature
- Choose DAC‘s digital filter type on the WiiM Pro Plus (Compatible with the new app updated in a few days)
3.
Fixed
- DHCP improvement for IPv6 on certain routers.
4.
Fixed
- Unable to pair with the WiiM Remote occasionally.
5.
Fixed
- Multi-room audio for Line-in input of more than 48kHz input on the WiiM Pro Plus.
6.
Fixed
- Qobuz shuffle play.
7.
Fixed
- Occasional crash with Roon Ready.
8.
Fixed
- No metadata with AirPlay and Amazon Music in certain use cases.
9.
4.8.524431
Release date: July 27, 2023
1.
New Feature
- Support MQA core decoder for TIDAL in the WiiM Home App.
2.
New Feature
- Add entire album/playlist to the play queue for Amazon Music and Qobuz (Works with new App version 2.5.4)
3.
Improvement
- LED status light during the Out-of-box Experience (OOBE) process.
4.
Improvement
- Better audio quality of audio prompts.
5.
Fixed
- Unable to enter standby mode after receiving the AVS notification.
6.
Fixed
- Memory leak for Google Cast.
7.
Fixed
- Sound distortion for Roon when using it for long time.
8.
Fixed
- Metadata refresh issue for TuneIn.
9.
Fixed
- Playback stuttering on certain TuneIn radios.
10.
4.8.523533
Release date: July 19, 2023
1.
New Feature
- Support TuneIn pre-rolling.
2.
Improvement
- Various Qobuz improvements on favorites and queue management (Works with new App version 2.5.3)
3.
Improvement
- Update the new AirPlay SDK.
4.
Improvement
- Show the error description of the authentication and playback exceptions on the WiiM Home app when these happen.
5.
Fixed
- Unable to connect to the wireless network whose SSID contains the space character.
6.
Fixed
- Rare random crash of TIDAL Connect.
7.
Fixed
- Unable to sign in TuneIn using 3rd party services (Works with new App version 2.5.3)
8.
Fixed
- Playback stuttering for certain TuneIn or vTuner Radios.
9.
Fixed
- Unable to play the tracks whose format is AIFF/AIF.
10.
Fixed
- Random crash issues for Roon.
11.
4.8.522753
Release date: July 7, 2023
1.
Fixed
- Unexpected switch to Spotify Connect from another playing session.
2.
Fixed
- Unable to play certain podcasts from TuneIn.
3.
Fixed
- Unable to login Calm Radio account which contains space character.
4.
Fixed
- Track skipping on Napster when using 'Play Next'.
5.
Fixed
- Incorrect device description for UPnP/DLNA.
6.
Fixed
- Rare random crash for Roon.
7.
4.8.521547
Release date: June 30, 2023
1.
New Feature
- Roon Ready.
2.
Improvement
- Unable to connect when using Spotify Connect.
3.
Fixed
- Rare random crash of Spotify Connect.
4.
Fixed
- Pop noise when changing tracks with different endian (Little and big-endian)
5.
Fixed
- Unable to mute when using BT Source Mode.
6.
4.8.520133
Release date: June 15, 2023
This update involves the following
1.
Improvement
- Pop noise optimization for the certain DACs when the optical signal switches on/off quickly (Need to adjust sample rate switch latency with WiiM Home app)
2.
Improvement
- Power consumption of WiiM Voice Remote.
3.
Fixed
- 3S sound delay when resuming from pause for SPDIF input.
4.
Fixed
- Pop noise and incorrect metadata display for Apple AirPlay.
5.
Fixed
- Pop noise and freeze issues when seeking to the beginning of the playing track with TIDAL Connect for tracks under Normal and High quality.
6.
Fixed
- Initial sound cut with SPDIF output.
4.8.518747
Release date: June 1, 2023
1.
Improvement
- Cycle through all the non-empty presets by tapping the preset button on the WiiM Pro.
2.
Improvement
- Support flc and m3u8 extension, and AIFF format for DLNA.
3.
Improvement
- Reduces the latency of SPDIF input when auto-sensing is enabled.
4.
Improvement
- The volume control of the voice remote adjusts the group volume instead of the volume of the group lead speaker when using LinkPlay multiroom.
5.
Fixed
- L/R channel swap for SPDIF-in input mode in the rare case.
6.
Fixed
- Random crash issues for Calm Radio Preset.
7.
4.8.517862
Release date: May 23, 2023
1.
New Feature
- Add separate auto-sensing of Line-in or SPDIF-in (Need to turn it on at the latest app )
2.
Improvement
- 12V trigger out when the device is idle.
3.
Improvement
- Connection stability for Spotify Connect.
4.
Improvement
- AirPlay playback smoothness.
5.
Fixed
- Pop noise with LinkPlay multiroom when using analog output.
6.
Fixed
- Pop noise with SPDIF out and Line out when exiting from idle.
7.
Fixed
- Incorrect Bluetooth reconnection.
8.
Fixed
- Rare random crash issues for the TIDAL Connect.
9.
Fixed
- Pop noise when playing iHeartRadio with Amazon Alexa multi-room.
10.
Fixed
- Incorrect playback progress after seeking when playing Podcast with Spotify Connect.
11.
Fixed
- Incorrect MIME type issue for DLNA.
12.
Fixed
- Incorrect metadata display for DLNA.
13.
Fixed
- Unexpected stop when playing DLNA content.
14.
Fixed
- LED can't be turned off.
15.
4.8.515159
Release date: April 27, 2023
1.
New Feature. Learn More >>
- Support input source switch via Alexa for WiiM voice remote.
2.
Improvement
- Always connect to the latest one if the device has been paired with multiple Wi-Fi networks.
3.
Improvement
- Update new Spotify Connect ESDK (Preset of Spotify is invalid due to the SDK change, please use the WiiM Home companion App to save it again)
4.
Fixed
- Pop noise with SPDIF out.
5.
Fixed
- Unable to play the tracks whose address contains space characters in some media servers such as Kodi etc.
6.
Fixed
- Random crash issues for Amazon Music.
7.
Fixed
- Unable to logout TuneIn.
8.
Fixed
- Pop noise with LinkPlay multiroom.
9.
Fixed
- The playback progress is not inaccurate at the end of the playing track.
4.8.513047
Release date: April 6, 2023
1.
New feature
- Support dynamic track metadata information for Radio Paradise.
2.
Improvement
- Add sample rate switch latency to prevent the pop noise on the certain DACs when the optical signal switches on/off quickly (Adjust it with the latest app updated in a few days)
3.
Fixed
- Wrong volume control for Google Cast.
4.
Fixed
- Random crash issues for AirPlay and TIDAL Connect.
5.
Fixed
- Unable to play music after playing ad with Amazon Music Free.
6.
Fixed
- Random crash issue when using voice control to play music with the WiiM Remote.
7.
Fixed
- No sound issue with LinkPlay multiroom on Bluetooth input.
8.
4.8.511631
Release date: March 23, 2023
1.
New Feature
- Support preset from Radio Paradise and custom URL.
2.
Improvement
- Connection stability of Spotify Connect.
3.
Improvement
- On-device LED prompt when pressing the button on the WiiM Voice Remote.
4.
Fixed
- EQ clipping when using the fixed volume option or playing music with high volume.
5.
Fixed
- Random crash issues for TIDAL Connect, Amazon Music, Qobuz and Sound Machine.
6.
Fixed
- Random crash issues in Bluetooth output mode.
7.
Fixed
- Track is skipped constantly when switching Google Cast to Bluetooth mode.
8.
Other improvements and bug fixes.
4.8.511042
Release date: March 16, 2023
1.
Fixed
- Random crash issues for Bluetooth input.
2.
Fixed
- Unexpected stop when playing Amazon Music HD.
3.
4.8.510764
Release date: March 14, 2023
1.
Improvement
- TIDAL playback smoothness.
2.
Fixed
3.
Fixed
- Unable to log in to TIDAL and Qobuz on the WiiM Home app (in the rare cases)
4.
Fixed
- No sound when switching Google Cast to Bluetooth mode.
5.
Fixed
- One-second sound cut when changing tracks for TIDAL.
6.
Fixed
- Pop noise with the SPDIF input for certain TVs.
7.
Fixed
- Voice Control doesn't work sometimes with the WiiM Voice Remote.
8.
Fixed
- Display wrong EQ setting for custom EQ on the WiiM home App.
9.
4.8.509547
Release date: March 1, 2023
1.
New Feature
- Support WiiM voice remote.
2.
Improvement
- Wi-Fi connection stability.
3.
Improvement
- Reduce the SPDIF-in latency to 50ms.
4.
Fixed
- Unable to play music from preset in some rare cases.
5.
Fixed
- Unable to go to standby for COAX output.
6.
Fixed
7.
Fixed
- Random crash issues for Amazon Alexa multi-room.
8.
4.8.507636
Release date: February 14, 2023
1.
Improvement
- Support 10-band graphic EQ and 24 preset EQ for Google Cast.
2.
Improvement
- Support Mono mode for Google Cast.
3.
Improvement
- Dim the brightness of the status light when device goes standby.
4.
Fixed
- SPDIF in a distortion from certain TVs.
5.
Fixed
- Ethernet disconnection from some routers.
6.
Fixed
- Unexpected stop when playing AMHD.
7.
Fixed
- Unable to use the TIDAL Connect after seeking and skipping multiple times.
8.
Fixed
- Unexpected logout for Amazon Music account when the internet is inaccessible.
9.
Fixed
- Rare random crash issues for the TIDAL Connect and Spotify Connect.
10.
Fixed
- Unable to mute with Amazon Alexa.
11.
Fixed
- Play with wrong speed for the TIDAL Connect in rare cases.
12.
Fixed
- Track is skipped occasionally when playing AMHD from Amazon Music app.
13.
Fixed
- Unable to enter standby mode after pausing playback from Google Cast.
14.
Important note on this release
1.
To let the E thernet fix take effect, please unplug and plug the device power supply. You don't need do this if the Ethernet.
4.8.504937
Release date: January 18, 2023
1.
New feature
- Support dynamic track metadata information for vTuner.
2.
Improvement
- Pop noise for Hi-Res audio.
3.
Improvement
- Make MQA enabled by default.
4.
Fixed
5.
Fixed
6.
Fixed
- Deezer API bug.
7.
Fixed
- Multi-room audio for SPDIF input of 44.1kHz input.
8.
Other bug fixes and improvements.
4.8.503558
Release date: January 4, 2023
1.
New feature
- Support mono mode (for the outdoor or mono speakers)
2.
Improvement
- Support the new requirement of Amazon Prime Music (Not Amazon Music Unlimited)
3.
Improvement
- Use 8.8.8.8 as the default DNS Server (Can be turned off with the App)
4.
Improvement
- Keep the LED on when entering the standby mode.
5.
Improvement
- Reduce the Line-in/SPIDF-in latency to 20+ ms to improve A/V sync for TV audio.
6.
Improvement
- Wi-Fi connection stability on certain routers.
7.
Improvement
- Reduce the brightness of the LED when the device is idle.
8.
Fixed
- Playback stuttering with TIDAL Master when turning on MQA Core Decoder.
9.
Fixed
- No sound or sound distortion when using Google Cast with the Bluetooth transmitter mode.
10.
Fixed
- OTA failure for certain cases.
11.
Fixed
- Blurry album artwork for Qobuz.
12.
Fixed
13.
4.8.438466
Release date: December 12, 2022
1.
New Feature
- Support dynamic track information in TuneIn.
2.
- Support auto-sensing of the audio input (Only detect when the device is idle and needs turn it on with the latest App)
3.
Improvement
- Bitrate display on app.
4.
Fixed
- No sound issue when switching Google Cast to Bluetooth mode.
5.
Fixed
- Unable to find the device as the AirPlay receiver for certain cases.
6.
Fixed
- AirPlay for YouTube Music.
7.
Fixed
- Auto audio sync.
8.
Fixed
- Pop noise and un-expected stop with the SPDIF input.
9.
Fixed
- Ethernet disconnection on certain routers.
10.
Fixed
- Wrong volume after unmute.
11.
4.8.437046
Release date: November 29, 2022
1.
New Feature
- EQ for Google Cast (Need use Google Home app to adjust EQ)
2.
Improvement
- Playback stuttering when resampling.
3.
4.8.435659
Release date: November 15, 2022
1.
Fixed
- Can't reset factory settings issue.
2.
