Currently, there is no way to manually force a manual update to your device. All firmware updates occur automatically.
Automatic Updates
Available updates will be downloaded and installed automatically. There will be no notification or sound during this process. The scheduled time for updates is between 12:00 am and 12:00 pm.
Updates via WiiM Home App
The app will automatically check for available updates and display them for you.
To find the current device firmware version, please follow these steps:
1. Open the WiiM Home app.
2. Navigate to the Device tab.
3. Click on the Gear icon.
4. Select Device Info.
5. Look for the Firmware version.
