TABLE OF CONTENTS
Overview
Google Cast is a wireless streaming technology from Google. You can use a compatible app, such as YouTube Music, on your phone, tablet, or computer to stream music directly to a compatible WiiM device for playback. For instructions, see How to Stream YouTube Music to Your WiiM Devices.
Before you stream music with Google Cast, enable it on your WiiM device in the WiiM Home app.
Enable Google Cast
Use any of the following options to enable Google Cast:
Option 1: During WiiM Setup
Enable it when you set up the device with the WiiM Home app.
Option 2: From Device Settings
Go to the Devices tab > Device Settings
> Google Cast, then enable it.
Option 3: From the Browse Tab
Go to the Browse tab. Under the Voice and Streaming section, select Google Cast and enable it for your WiiM device.
Disable Google Cast
To disable Google Cast on the WiiM device, you need to reset the device.
To reset the device, press and hold the Play button on the WiiM device for 10 seconds until you hear the voice prompt "Restore to factory settings".
