Using the WiIM Home app to set up
- Plugin one audio receiver or speaker on your device and connect it to power.
- Download the WiiM Home App for iOS or Android and open it.
- Press the "Play" button on your device until the LED is white and blinking.
- Tap the "Connect" button on the popup showing your device.
- Follow the steps in the App to set up your device.
- See the video on the right for more detailed information.
Using Ethernet to set up
- Connect the Ethernet cable to WiiM Pro and continue the setup in the app.
- Note: If you have already configured the Wi-Fi connection, when Ethernet is plugged in it will automatically switch to Ethernet. And when you unplugged the Ethernet, it will switch back to WiFi. You can also leave the WiFi disconnected if you prefer using the Ethernet.
Using AirPlay to set up
- Download the WiiM Home app for iOS or Android and open it.
- Press the "Play" button on your WiiM device until the LED is white and blinking.
- Enter Settings -> Wi-Fi screen on your iPhone
- Select your unit as the AirPlay speaker on the Wi-Fi screen.
- Follow the steps on the Wi-Fi screen to set up your device.
Using iOS Home App to set up
- Open the Home app and tap Add Accessory or Scan App.
- Please tap yellow "More options...?".
- Tap your device which MUST be listed under "Select an Accessory to Add".
- Tap the "Allow" to allow your device to connect with your Wi-Fi network.
