WiiM devices feature two-way Bluetooth communication. This allows you to wirelessly send audio from your WiiM device to other Bluetooth-enabled devices, such as speakers, headphones, or Airpods.
WiiM devices support audio output to only one Bluetooth device at a time and cannot output to multiple Bluetooth devices simultaneously.
Video Tutorial
Watch the video below to learn how to connect your WiiM device to a Bluetooth speaker.
Steps to Connect Your WiiM Device to a Bluetooth Device
1. Access the WiiM Home App:
- Open the WiiM Home app on your smartphone or tablet.
- Navigate to the Devices tab, tap the Device Settings icon
for your WiiM device, and select Audio Output.
2. Initiate Bluetooth Connection:
- Tap Pair next to the Bluetooth Out option.
3. Select Your Bluetooth Device:
- Wait briefly as the app searches for nearby Bluetooth devices.
- Devices in pairing mode will appear on the screen. Ensure your desired Bluetooth speaker, headphone, or Airpod is in pairing mode.
4. Establish the Connection:
- Once your Bluetooth device appears, select it from the list to connect.
- Your WiiM device will now output its audio to the chosen Bluetooth device.
5. Troubleshooting:
- If your Bluetooth device doesn't appear on the list, tap the Refresh icon
in the top right corner of the screen to search again.
By following these steps, you can easily connect your WiiM device to a variety of Bluetooth-enabled audio devices for an enhanced listening experience.
