TABLE OF CONTENTS
To stream music via Bluetooth from your mobile device (e.g., smartphone or tablet) to your WiiM Sound Lite, you need to pair your mobile device with the WiiM Sound Lite first. This tutorial will guide you through the steps for Bluetooth pairing.
Initial Bluetooth Pairing
Step 1: Initiate Bluetooth Pairing Mode on WiiM Sound Lite
Choose the most convenient method for you:
- Option 1: Press and hold the Volume + and Volume - buttons on the WiiM Sound Lite's top panel simultaneously for 2 seconds.
- Option 2: Switch to Bluetooth input using the WiiM Home app.
Step 2: Complete Pairing on Your Mobile Device
- Go to Settings > Bluetooth on your mobile device and turn on Bluetooth.
- Tap your WiiM Sound Lite in the available devices list to pair.
- Once paired, the WiiM Sound Lite's LED indicator will turn solid blue.
Bluetooth Re-pairing with a New Mobile Device
If you want to pair your WiiM Sound Lite with a new mobile device, follow these steps:
- Put the WiiM Sound Lite into pairing mode using one of the options below:
- Option 2: Use Enter Pairing Mode in the WiiM Home app. For details, see Use "Enter Pairing Mode" to Quickly Pair a New Bluetooth Device.
- Option 3: Turn off Bluetooth on the previously paired mobile device, then switch the WiiM Sound Lite to Bluetooth input using the WiiM Home app.
Note: Since the WiiM Sound Lite cannot find the previously paired device, it will automatically enter Bluetooth pairing mode.
- Complete pairing on your new mobile device.
Bluetooth Connection Management
Once your WiiM Sound Lite is paired with a mobile device, you can disconnect or reconnect using any of these methods:
- Option 1: Use the Enter Pairing Mode option in the WiiM Home app. For details, see Use "Enter Pairing Mode" to Quickly Pair a New Bluetooth Device.
- Option 2:Switch your WiiM Sound Lite's input via the WiiM Home app:
- Switching the input to AUX In will disconnect the Bluetooth connection.
- Switching the input back to Bluetooth will automatically try to connect with the paired mobile device.
- Option 3: Disconnect or reconnect from the mobile device's Bluetooth settings.
FAQ
Q: If I am in an environment without Wi-Fi, can I connect a new mobile device to the WiiM Sound Lite?
A: Yes. You can put the WiiM Sound Lite into Bluetooth pairing mode by pressing and holding the Volume + and Volume - buttons on the WiiM Sound Lite's top panel simultaneously for 2 seconds. Then, complete the pairing on your new mobile device.
