TABLE OF CONTENTS
To stream music via Bluetooth from your mobile device (e.g., smartphone or tablet) to your WiiM Sound, you need to pair your mobile device with the WiiM Sound first. This tutorial will guide you through the steps for Bluetooth pairing.
Initial Bluetooth Pairing
Step 1: Initiate Bluetooth Pairing Mode on WiiM Sound
Choose the most convenient method for you:
- Option 1: Press and hold the Volume + and Volume - buttons on the WiiM Sound's top panel simultaneously for 2 seconds.
- Option 2: Switch to Bluetooth input using the WiiM Home app, WiiM Sound's built-in screen, or WiiM Voice Remote 2 Lite.
- Option 3: Press and hold the Play/Pause button on your WiiM Voice Remote 2 Lite for 3 seconds.
Note: Make sure the remote is already paired with the WiiM Sound before using it.
Step 2: Complete Pairing on Your Mobile Device
- Go to Settings > Bluetooth on your mobile device and turn it on.
- Tap your WiiM Sound in the available devices list to pair.
- Once paired, a confirmation message will appear on the WiiM Sound's screen.
Bluetooth Re-pairing with a New Mobile Device
If you want to pair your WiiM Sound with a new mobile device, follow these steps:
- Put the WiiM Sound into pairing mode using one of the options below:
- Option 2: Use the Enter Pairing Mode option in the WiiM Home app or on the built-in screen. For details, see Use "Enter Pairing Mode" to Quickly Pair a New Bluetooth Device.
- Option 4: Turn off Bluetooth on the previously paired mobile device first, then switch the WiiM Sound to the Bluetooth input via the WiiM Home app, built-in screen, or WiiM Voice Remote 2 Lite.
Note: Since the WiiM Sound cannot find the previously paired device, it will automatically enter Bluetooth pairing mode.
- Complete pairing on your new mobile device.
Bluetooth Connection Management
Once your WiiM Sound is paired with a mobile device, you can manage the Bluetooth connection (e.g., disconnecting or reconnecting) using any of these methods:
- Option 1: Use the Enter Pairing Mode option in the WiiM Home app or on the built-in screen to disconnect the current mobile device and enter pairing mode. For details, see Use "Enter Pairing Mode" to Quickly Pair a New Bluetooth Device.
- Option 2: Switch your WiiM Sound's input via the WiiM Home app, built-in screen, or WiiM Voice Remote 2 Lite.
- Switching the input to AUX In will disconnect the Bluetooth connection.
- Switching the input back to Bluetooth will automatically try to connect with the paired mobile device.
- Option 3: Disconnect or reconnect from the mobile device's Bluetooth settings.
FAQ
Q: If I am in an environment without Wi-Fi, can I connect a new mobile device to the WiiM Sound?
A: Yes. You can put the WiiM Sound into Bluetooth pairing mode using its buttons, built-in screen, or WiiM Voice Remote 2 Lite. Then, complete the pairing on your new mobile device.
Refer to the corresponding instructions in Bluetooth Re-pairing with a New Mobile Device.
