By integrating WiiM into your smart home, you can enjoy hands-free voice control and automate music based on your daily routines.
WiiM works with the most popular smart home systems on the market. Whether you are a DIY enthusiast or using a professionally installed system, connecting your audio is simple.
Explore our supported integrations and setup guides below to unlock the full potential of your smart home.
Professional Automation Systems
Control4
By integrating WiiM with Control4, you can seamlessly manage music playback, access presets, group multiple WiiM devices for synchronized multi-room audio, and more.
For detailed instructions, see Integrating WiiM Devices with Control4.
RTI
By integrating WiiM with RTI, you can manage music playback, access your favorite playlists, group WiiM devices for synchronized multi-room audio, and more.
For detailed instructions, see Integrating WiiM Devices with RTI.
NICE
By using the official "WiiM by Linkplay" driver in the NICE Marketplace, you can easily add WiiM devices to the system for playback control, preset access, multi-room grouping, mode switching, and more.
For detailed instructions, see Integrating WiiM Devices with NICE.
Open Source Systems
Home Assistant
WiiM is now officially supported by Home Assistant, allowing you to seamlessly integrate your audio into custom automations. Once connected, you can control playback, access presets, switch inputs, and more.
For detailed instructions, see Integrating WiiM Devices with Home Assistant.
Voice Assistants
Amazon Alexa
Add your WiiM device to the Amazon Alexa app, then control your music using Alexa voice commands via your Echo devices or the WiiM Voice Remote. This integration also allows you to group WiiM devices with other Alexa-enabled speakers for synchronized whole-home audio.
For detailed instructions, see How to Use Alexa with Your WiiM Device.
Google Assistant
Add your WiiM device to the Google Home app, then control your music using Google Assistant voice commands via the app or Nest smart speakers. This integration also allows you to group WiiM devices with other Google-Cast-enabled speakers for whole-home audio.
For detailed instructions, see How to Control WiiM Device via Google Assistant.
Siri
Add your WiiM device to the Apple Home app and then use Siri voice assistant on any Apple device to control music playback. This integration also allows you to group WiiM devices with other AirPlay-enabled speakers for whole-home audio.
For detailed instructions, see Using Siri to Play Music on Your WiiM Device.
