The WiiM Sound supports Roon Ready, allowing you to stream high-quality audio from Roon directly to your device. However, this feature is turned off by default. Before streaming music from Roon, follow the steps below to enable Roon Ready on your WiiM Sound.
Step-by-Step Instructions
  1. Open the WiiM Home app.
  2. Go to the Devices tab, and tap the Device Settings icon of your WiiM Sound.
  3. Navigate to the Voice And Streaming section, and toggle on Roon Ready.
You are now ready to stream music from Roon to your WiiM Sound. For detailed instructions, see How to Use Roon with Your WiiM Device.
