This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
It's important to note that the device's firmware version is distinct from the WiiM Home App version. To check your device's firmware version, open the WiiM Home App, go to the 'Device' tab, tap the 'gear icon (Cog Wheel)' for device settings, select 'Device Info', and then view 'Firmware Version'.
5.2.829356 (In Progress)
Release date: September 14, 2026
What's New
1.
SoundCloud: Added support for seeking within tracks.
General Improvements
1.
Surround Audio: Improved volume balance with WiiM Bar when used as surround speakers for a more immersive experience.
2.
Network: Improved Ethernet stability and IPv6 address handling.
3.
TIDAL Connect: Reduced playback stuttering.
5.2.828358
Release date: September 4, 2026
Audio & Playback
1.
Google Cast: Added support for WiiM multi-room playback and wireless WiiM Sub Pro output when using Google Cast.
2.
Spotify Connect: Reduced playback stuttering. And updated the playback screen to meet Spotify requirements; other screen styles are not supported.
3.
Multi-Room Audio: Improved audio quality during multi-room playback.
4.
Soundtrack: Updated the SDK to improve playback stability and performance.
5.
iHeartRadio: Added FLV support to enable playback for certain radio stations.
6.
Sound Machine: Fixed an issue where playback could stop unexpectedly.
7.
Open Network Stream: Fixed an issue where playback might not resume after a long pause.
8.
Bluetooth: Reduced playback stuttering and ensured the Bluetooth name updates after renaming the device.
9.
Google Cast: Updated the SDK to improve playback compatibility across music streaming services.
5.2.820956
Release date: June 23, 2026
What's New
1.
WiiM Radio: Added support for WiiM Radio.
2.
Automatic Updates: Adds support for delaying automatic firmware updates, configurable in the WiiM Home app.
3.
Playback Stuttering: Reduces stuttering during music playback.
4.
Qobuz: Fixes a crash issue when using Qobuz.
5.
Amazon Music: Fixed an issue where Amazon Music could skip tracks unexpectedly.
6.
Google Cast: Updated SDK to enhance playback support for multiple music streaming platforms.
5.2.813247
Release date: April 8, 2026
Highlights
1.
Stereo Pair: Simplifies stereo pair setup.
2.
3.
Screen: Added French language support.
Playback & Audio
1.
2.
EQ: Enables EQ for Dolby 5.1 playback. Improved responsiveness when adjusting and switching EQ settings.
3.
Aux In: Fixed distortion during extended playback sessions.
Radio & Streaming Services
1.
2.
3.
4.
Deezer: Fixed unexpected playback interruptions.
5.
1.
2.
3.
Remote: Fixed occasional disconnection and unexpected max volume issues.
4.
Alarm: Fixed incorrect alarm and preset volume behavior.
5.
Roon: Fixed occasional crash issues.
6.
Alarm: Fixes BBC and vTuner alarms defaulting to the chime.
5.2.809035
Release date: February 28, 2026
Playback & UI Improvements
1.
Supports per-input Now Playing screen customization.
2.
Improved handling of short tracks and near-end track transitions to prevent skipping or audio leakage.
3.
Fixed multiple cases of unexpected track skipping or premature track changes across services.
Smart Home & Connectivity
1.
Control 4 Integration: Seamlessly integrates with Control 4 systems for enhanced smart home control. Learn More >>
2.
Bluetooth Output: Allows audio to be streamed to Bluetooth devices (requires the upcoming app update)
1.
Radio: Enhanced live track metadata display with ICY support across TuneIn, iHeartRadio.
2.
Qobuz: Enabled Track Radio, Artist Radio, and Album Radio.
3.
vTuner Radio: Improved playback reliability with a backup stream URL fallback.
4.
SoundCloud: Added support for third-party login.
5.
TuneIn: Fixed an issue where alarms could fail to start playback on time.
6.
iHeartRadio: Fixed an issue where playback could stop unexpectedly.
7.
Pandora: Fixed an issue that could cause unexpected track skipping.
8.
Napster: Fixed My Music playback failures, incorrect station controls, and a crash when the internet connection is lost.
9.
Plex: Fixed incorrect track progress display for alarms, station history playback failures, and occasional early track skipping.
10.
Amazon Music: Fixed playback interruptions when playing short playlists.
11.
TIDAL Connect: Updated the SDK to fix an issue that could cause random playback stops.
5.2.806846
Release date: February 6, 2026
What's New
1.
Standby Wake-up: Fixed unintended screen wake-ups in standby.
2.
Playback: Improved playback smoothness with wireless Sub Pro.
5.2.804555
Release date: January 14, 2026
What's New
1.
Plex Remote Access: You can now stream from your Plex media server over a wide-area network (remote connection)
2.
Localization: Added German language support for the device screen.
User Experience & Interface
1.
Faster Setup: Optimized the Wi-Fi onboarding flow for reduced setup time. Added a "Cancel" option and clearer device name display during the process.
2.
Screen Enhancements:
  • Volume Feedback: The screen now wakes to show the volume bar when adjusting volume, even if the display was off.
  • Unexpected Screen Wake-up: Fixed unintended screen wake-ups in standby.
Audio & Stability
1.
Streaming Stability:
  • TIDAL Connect: Fixed an issue causing random playback stops.
  • Amazon Music: Resolved an issue where playback occasionally failed to start.
  • TuneIn: Fixed playback issues specific to NPR podcasts.
2.
Alarms: Fixed a bug where alarm presets would not stop playing after the set duration ended.
5.2.739557
Release date: December 23, 2025
Important Note
1.
Alexa Re-login Required: This update refreshes our Alexa integration (ID updated to WiiM_Sound). You will be automatically logged out after the update; please sign in again via the WiiM Home App to resume voice functionality.
What's New
1.
New Home Screen Widgets:
  • Radio: Select and play your favorite stations directly from the device screen.
  • Recently Played: Quickly access your listening history.
2.
VU Meter: Added support for the VU Meter display mode.
3.
Alexa Visual Interface: Added on-screen status indicators for Alexa (Listening, Thinking, Speaking) and prompts when not signed in.
4.
Wi-Fi: Stronger connection stability; improved compatibility with Wi-Fi 7 routers.
5.
Queue: Better track order retention in shuffle and faster queue operations across NAS/Samba/Local, TIDAL, Qobuz, Radio Paradise, YouTube, Deezer, and SoundCloud.
6.
Multi-room: Improved multicast logic for more reliable discovery/connectivity; reduced stutter when using Bluetooth input.
1.
Touch Controls: Smoother volume adjustment when long-pressing touch buttons.
2.
Performance: Faster switching speed when changing to Audio Input from other modes.
3.
Setup Experience: Optimized network configuration logic for a faster and more stable setup process.
Bug Fixes
1.
Qobuz: Stabilized progress bar; fixed shuffle dropouts, playback-mode mismatch, and missing artist/track metadata.
2.
Soundtrack: Updated SDK; fixed disconnects when renaming the device during playback.
3.
Plex: Added remote streaming over WAN.
4.
Amazon Music: Fixed position reset after back-to-back seeks.
5.
TIDAL Connect: Fixed playback interruptions after ~1 hour.
6.
7.
Radio: Resolved failures for certain station formats.
8.
Google Cast: Device now retains its assigned room after reboot.
5.2.736143
Release date: November 20, 2025
What's New
1.
Multi-Room: Improved multicast logic for more reliable device connectivity.
Bug Fixes
1.
Alexa: Fixed a login failure that blocked account sign-in.
2.
Google Cast: Resolved an issue where the device left its assigned room after reboot.
3.
Spotify: Fixed a bug where Spotify Presets required two triggers to start playback.
