TABLE OF CONTENTS
To stream music via Bluetooth from your mobile device (e.g., smartphone or tablet) to your WiiM Mini, you need to pair your mobile device with the WiiM Mini first. This tutorial will guide you through the steps for Bluetooth pairing.
Initial Bluetooth Pairing
Step 1: Initiate Bluetooth Pairing Mode on WiiM Mini
Choose the most convenient method for you:
- Option 1: Press and hold the Volume + and Volume - buttons on the WiiM Mini simultaneously for 2 seconds.
- Option 2: Switch to Bluetooth input using the WiiM Home app.
Tip: When the WiiM Mini enters Bluetooth pairing mode, its LED indicator will flash slowly in green.
Step 2: Complete Pairing on Your Mobile Device
- Go to Settings > Bluetooth on your mobile device and turn on Bluetooth. Your mobile device will search for available Bluetooth devices.
- Tap your WiiM Mini in the available devices list to pair.
- Once paired, the WiiM Mini's LED indicator will turn solid green.
Bluetooth Re-pairing with a New Mobile Device
If you want to pair your WiiM Mini with a new mobile device, follow these steps:
- Put the WiiM Mini into pairing mode using one of the options below:
- Option 2: Turn off Bluetooth on the previously paired mobile device, then switch the WiiM Mini to Bluetooth input using the WiiM Home app.
- Option 3: Use Enter Pairing Mode in the WiiM Home app. For details, see Use "Enter Pairing Mode" to Quickly Pair a New Bluetooth Device.
- Complete pairing on your new mobile device as described in Step 2: Complete Pairing on Your Mobile Device.
Bluetooth Connection Management
Once your WiiM Mini is paired with a mobile device, you can disconnect or reconnect using any of these methods:
- Option 1: Use the Enter Pairing Mode option in the WiiM Home app. For details, see Use "Enter Pairing Mode" to Quickly Pair a New Bluetooth Device.
- Option 2: Switch your WiiM Mini's input via the WiiM Home app:
- Switching the input to AUX In will disconnect the Bluetooth connection.
- Switching the input back to Bluetooth will automatically try to connect with the paired mobile device.
- Option 3: Disconnect or reconnect from the mobile device's Bluetooth settings.
