If your WiiM device doesn’t appear on Spotify Connect, follow the below troubleshooting steps to resolve the issue.
Troubleshooting Steps
1. Enable Local Network Access
If you see the following message on the Spotify screen, tap Go to Settings, and then enable the Local Network permission for the Spotify app.
2. Restart Devices
Unplug your WiiM device, wait a few seconds, then plug it back in.
3. Check Network Connection
Ensure both your WiiM device and mobile device are connected to the same Wi-Fi network.
4. Update Spotify App
Ensure the Spotify app is up to date. It's better to reinstall the app.
5. Update WiiM Firmware
Open the WiiM Home app and check for firmware updates.
6. Test Another Network
If the above steps don’t help, try switching to another Wi-Fi network to see if the issue persists.
If the issue persists, please contact us for further assistance.
