TABLE OF CONTENTS
- Learn More about WiiM Dolby 5.1 Surround System
- Device Requirements and Typical Configurations
- Before You Begin
- Steps to Set Up a 5.1 Surround Sound
- Tips
The WiiM Amp Pro, WiiM Amp Ultra, and WiiM Ultra support Dolby Digital Audio, making them perfect for building a 5.1 surround sound system. The 5.1 surround sound system creates an immersive audio experience by delivering sound from multiple directions. This setup is ideal for movies, gaming, and music, offering six channels:
- Five full-range audio channels (Front Left, Center, Front Right, Surround Left, Surround Right)
- One subwoofer channel for low-frequency effects (LFE)
With the 5.1 surround sound system, you'll feel enveloped in sound, enhancing the dynamics of your audio experience. You can achieve this immersive audio setup by connecting multiple WiiM devices in a multi-room configuration. This approach is flexible and cost-effective, allowing you to enjoy the full 5.1 channel experience. This guide will show you how to set up a typical 5.1 surround sound system using WiiM devices.
- Set up 2 to 4 WiiM devices. For details, see Device Requirements and Typical Configurations.
- Place the speakers properly.
- Connect all WiiM devices to the same Wi-Fi network.
Step 1. Connect the Group Lead WiiM Device to Your TV
- Use an HDMI cable to connect the group lead WiiM device to your TV.
- Set your TV to output audio to your group lead WiiM device.
- Set the audio output format on your TV to Auto, Dolby Digital Audio, or a similar option.
- Open the WiiM Home app on your mobile device.
- Go to the Browse tab and set the group lead WiiM device's Source Input to HDMI ARC.
Step 2. Connect the Group Lead WiiM Device to Your Subwoofer
Connect the group lead WiiM device to your subwoofer using an RCA cable, then adjust the subwoofer settings in the WiiM Home app to match your preferences.
For details, see How to Connect Your Subwoofer with the WiiM Amp or WiiM Amp Pro and How to Connect Your Subwoofer with the WiiM Ultra.
Step 3. Create a Multi-Room Setup in the WiiM Home App
- Go to the Devices tab in the WiiM Home app.
- Tap the Chain Link icon
on the group lead WiiM device which is connected to your TV.
- Select the other WiiM devices from the device list.
- Tap Done to group WiiM devices and set up a Dolby 5.1 surround audio system.
Step 4. Adjust Dolby 5.1 Surround Sound Settings
- Go to the Now Playing page in the WiiM Home app.
- Tap the
icon to enter the Dolby Surround 5.1 Audio settings page.
- Make the following settings:
- Enable Surround 5.1 Audio.
- Optionally, assign the center speaker. If you have a dedicated WiiM device for the center audio channel, assign it as the center speaker.
- Assign surround speakers:
- When using one WiiM device as surround speakers, set it to Surround Left&Right.
- When using two WiiM devices as surround speakers, set them to Surround Left and Surround Right, respectively. - Adjust Group Audio Delay. For details, refer to Using the Group Audio Delay Setting for WiiM Multi-Room Audio.
By leveraging multiple WiiM devices in a multi-room setup, you can achieve a 5.1 surround sound system and enjoy the immersive benefits of this audio format.
Tips
- Place the speakers around the listening area at ear level with front speakers near the TV, surround speakers slightly behind or to the sides, and the subwoofer near the center for optimal sound.
- The audio or video being played must support Dolby Digital Audio format; otherwise, achieving a 5.1 channel sound experience will not be possible.
