The WiiM Amp and WiiM Amp Pro feature three distinct audio input ports:
  • Line In
  • Optical In
  • HDMI ARC
You can connect devices like CD players, TVs, PCs, or turntables to your WiiM Amp or WiiM Amp Pro via these input ports for high-quality playback with reduced latency.
Supported Audio Format and Quality for HDMI ARC and Optical In
The following table shows the supported audio formats and quality for the HDMI ARC and Optical In ports on both the WiiM Amp and WiiM Amp Pro:
Device Ports Supported Audio Formats Supported Audio Quality
WiiM Amp HDMI ARC and Optical In PCM Up to 24-bit/192 kHz
WiiM Amp Pro HDMI ARC and Optical In PCM, Dolby Digital Up to 24-bit/192 kHz
Please note that neither the WiiM Amp nor the WiiM Amp Pro supports other TV audio formats like Dolby Atmos or DTS.
To ensure proper sound output and compatibility, set the audio format to PCM in your TV or Blu-ray player's settings when using the WiiM Amp.
How to Use the Line In Port
The Line In interface on the WiiM Amp and WiiM Amp Pro is typically used to connect to a CD player or PC to receive analog audio input.
This example shows how to use the Line In port to connect a CD player:
  1. Use an RCA cable to connect the Line In port on your WiiM Amp or WiiM Amp Pro to the Line Out port on a CD player.
  2. Select the source input as Line In in the WiiM Home app, or enable Auto-sensing of Line In. For details, see How to Select Audio Input on Your WiiM Device.
  3. Play music on the CD player. The music will stream to your WiiM Amp or WiiM Amp Pro.
Similarly, you can connect other audio devices to your WiiM Amp or WiiM Amp Pro via the Line In port in the same process.
How to Use the Optical In Port
The Optical In port on the WiiM Amp and WiiM Amp Pro is typically used to connect to a TV or PC to receive digital audio input.
This example shows how to use the Optical In port to connect a TV:
  1. Use an optical cable to connect the Optical In port on your WiiM device to the Optical Out port on a TV.
  2. Go to your TV's audio settings and select the optical or digital audio output. The exact setting names vary by TV model.
  3. Set your TV's digital audio format to Stereo PCM for the WiiM Amp. For the WiiM Amp Pro, select Stereo PCM or Dolby Digital.
  4. Select the source input as Optical In in the WiiM Home app, or enable Auto-sensing of Optical In. For details, see How to Select Audio Input on Your WiiM Device.
  5. The audio on the TV will play on your WiiM Amp or WiiM Amp Pro.
Note: When using the Stereo PCM format, if your TV has a Digital Audio Out Volume setting (or a similar option), make sure to set it to Max. Otherwise, the connected WiiM device may output very low or no sound. For instructions, see General Guide to Setting Digital Audio Output to PCM for Various TV Brands.
Similarly, you can connect other audio devices to your WiiM Amp or WiiM Amp Pro via the Optical In port in the same process.
How to Use the HDMI ARC Port
The HDMI ARC port on the WiiM Amp and WiiM Amp Pro is typically used to connect to a TV to receive digital audio input.
This example shows how to use the HDMI ARC port to connect a TV:
  1. Use an HDMI cable to connect the HDMI ARC port on your WiiM device to the HDMI ARC port on your TV.
    Note: Ensure you use the HDMI ARC port on your TV. Other HDMI ports won't transmit sound to the WiiM devices.
  2. Go to your TV's audio settings, enable HDMI ARC, and select the HDMI ARC or external audio system output. The exact setting names vary by TV model.
  4. Select the source input as TV in the WiiM Home app, or enable Auto-sensing of HDMI. For details, see How to Select Audio Input on Your WiiM Device.
To play audio from a PC, Blu-ray player, or another HDMI source device, connect it to your TV first. Then send the TV's audio to your WiiM Amp or WiiM Amp Pro via HDMI ARC.
If you encounter no sound issues with your TV, refer to HDMI ARC Troubleshooting.
How to Use Audio Input Ports with Multi-room
The WiiM Amp and WiiM Amp Pro support all types of audio inputs—Wi-Fi/Ethernet, Bluetooth, Line In, Optical In, and HDMI ARC—as sources for your multi-room system. By connecting an audio source device (e.g., a CD player or TV) to your WiiM Amp or WiiM Amp Pro, you can stream audio to any other WiiM devices on the same network.
For detailed instructions, refer to the following articles:
  • When connecting your TV to your WiiM Amp or WiiM Amp Pro via an HDMI cable, ensure you use the HDMI ARC/eARC port on your TV. Connect a Blu-ray player to the TV rather than directly to the WiiM device's HDMI ARC port. Other HDMI ports on the TV won't transmit sound to the WiiM device.
  • If you experience no sound, ensure that the HDMI ARC output on your TV is activated. For details, see Troubleshooting No Sound Issues with HDMI TV Input on WiiM Devices.
  • If there are control issues between your TV and your WiiM Amp or WiiM Amp Pro, verify that HDMI-CEC control is enabled on your TV.
  • If your TV lacks an HDMI ARC port, connect the Optical Out port of your TV to the Optical In port of your WiiM Amp or WiiM Amp Pro.
