Overview
Roon is a high-quality music player for streaming and managing your music library across multiple devices. WiiM devices are Roon Ready, meaning they can receive high-resolution audio directly from Roon. This tutorial will guide you through using Roon with your WiiM device.
Note: The WiiM Mini, WiiM Sub Pro, and WiiM Vibelink Amp do not support Roon Ready.
Before You Begin
  • Install the Roon app on your PC.
    Note: We recommend keeping Roon up to date to ensure successful discovery of your WiiM device.
  • Set up a compatible WiiM device.
  • Enable Roon Ready on your WiiM device. For detailed instructions, see How to Enable Roon Ready on the WiiM Device.
  • Make sure your WiiM device and PC are connected to the same network.
Step-by-Step Instructions
  1. Launch the Roon app on your PC.
  2. Click the icon in the top-left corner to open Settings.
  3. Select the Audio tab, and then scroll down the right-side panel to the Roon Ready section.
  4. Click Enable next to your WiiM device to add the device as an audio output.
  5. Go to the Now Playing bar at the bottom and click System Output to select your WiiM device(s) from the list.
    Note: You can group multiple WiiM devices to enjoy multi-room music playback.
Now, start playing music in Roon, and you'll hear it through your WiiM device(s).
Troubleshooting: Roon Server Can't See WiiM Device (macOS 27)
If you are running the Roon app on macOS 27, your WiiM device may not appear in Roon. This is because macOS 27 blocks the connection. For solutions, please refer to Roon Community Workaround.
