If you're experiencing an IP address conflict, there are server steps you can take to fix the issue:
  1. Restart your router and WiiM device: This is the simplest way to fix the issue. If every device on your network is assigned a dynamic IP address, restarting the router should be able to fix the IP address conflict error.
  2. Assign a unique IP address to your WiiM device: You can manually assign a unique IP address to your WiiM device or set it to automatically obtain an IP address from the DHCP server.
  3. Update your network configuration: Updating your network configuration can help resolve conflicts by ensuring that all devices on the network are using the correct settings.
1. If
