Creating a speaker group using Google Cast is a fantastic way to amplify your audio experience. Before diving into the setup process, ensure that your mobile device and WiiM device are connected to the same Wi-Fi network for seamless device integration.
Google Cast groups support only network audio input and cannot transmit audio from other inputs (e.g., Line In, Optical In, HDMI ARC, or Bluetooth) to devices in the group over Wi-Fi. In contrast, WiiM groups created in the WiiM Home app support all these audio inputs.
Before You Begin
Before adding WiiM devices to a Google Cast speaker group, make sure that they are assigned to any room in the Google Home app.
For detailed instructions, see How to Add a WiiM Device to a Room in the Google Home App.
Step-by-Step Guide
Watch the video tutorial below to complete the setup:
Alternatively, follow the steps below to complete the setup:
  1. Launch the Google Home App: Start by opening the Google Home app on your mobile device. Make sure you are signed in with your Google account.
  2. Access Settings: In the Google Home app, tap on the 'Settings' tab. This is where you can manage your devices and groups.
  3. Navigate to Devices, Groups & Rooms: Within the Settings menu, look for the 'Devices, groups & rooms' section. You'll find this by clicking on the arrow icon located to the right of the section title.
  4. Select Your Devices: You will see a list of available devices. Go through this list and choose each device you wish to include in your speaker group. As you select a device, a tick mark will appear next to it, indicating your selection.
  5. Create Your Group: After selecting the desired devices, tap 'Next'. You will then be prompted to give your new speaker group a name. Choose a name that is easily recognizable and relevant to its use.
  6. Save and Enjoy: Finally, tap 'Save' to complete the setup of your new speaker group. Your devices are now linked, allowing you to enjoy a synchronized audio experience across multiple speakers.
Remember, you can always modify your speaker group later by adding or removing devices through the Google Home app. Enjoy your enhanced audio setup!
