The WiiM Mini offers the Aux In audio input port. You can connect devices like CD players, TVs, PCs, or turntables to your WiiM Mini via this port for analog audio input.
How to Use the Aux In Port
This example shows how to use the Aux In port to connect a CD player:
  1. Plug the 3.5mm connector of the cable into the Aux In port on the WiiM Mini.
  2. Plug the other end of the cable into the Aux Out or Line Out port on your audio source (CD player or PC).
  3. Select the source input as Aux In in the WiiM Home app, or enable Auto-sensing of Aux In. For details, see How to Select Audio Input on Your WiiM Device.
  4. Play music on the CD player. The music will stream to your WiiM Mini.
Similarly, you can connect other audio devices to your WiiM Mini via the Aux In port in the same process.
How to Use the Aux In Port with Multi-room
The WiiM Mini supports all its audio inputs—Wi-Fi, Bluetooth, and Aux In—as sources for your multi-room system. By connecting an audio source device (e.g., a CD player or TV) to your WiiM Mini, you can stream audio to any other WiiM devices on the same network.
For detailed instructions, refer to How to Play WiiM Multi-Room Music from Your CD Player, Turntable, or PC.
