The device firmware update is performed in batches such that the devices are taking turns getting updated. All the devices will be updated during the next few days after the release date.
Please find the list of known issues here that we're working around the clock to fix and release a solution by the ETA.
Please note the device firmware version is different from the version of the WiiM Home App. You can check your device's firmware version on the WiiM Home App. Please select the Device tab > Tap the device setting gear icon (i.e., the Cog Wheel) > Speaker Info > Firmware Version.
4.6.830052 (In Progress)
Release date: September 21, 2026
New Features
1.
Presto Music: Added support for Presto Music (requires the latest app version).
General Improvements
1.
Multi-Room Playback: Reduced stuttering and improved synchronization across devices.
2.
Network: Improved IPv6 address handling.
4.6.819436
Release date: June 8, 2026
Bug Fixes
1.
AirPlay: Fixed occasional playback dropouts.
2.
WiiM Radio: Added support for WiiM Radio (requires the latest app version)
4.6.816943
Release date: May 14, 2026
New Features & General Improvements
1.
2.
3.
Radio & Streaming Services
1.
Audio Sync: Improved sync accuracy for better group playback.
2.
3.
Live Metadata: Added ICY support for richer “now playing” info on TuneIn, iHeartRadio.
4.
Qobuz: Added Track Radio / Artist Radio / Album Radio.
5.
vTuner: Improved reliability with backup stream URL fallback.
6.
SoundCloud: Added third-party login support.
7.
iHeartRadio / Pandora: Fixed intermittent stops and unexpected skipping.
8.
Plex: Fixed alarm progress display, station history playback failures, and occasional early skips.
9.
Amazon Music: Fixed interruptions when playing short playlists.
4.6.805929
Release date: January 28, 2026
Playback & Stability
1.
Input Switching: Reduced occasional delays when switching input modes.
2.
Seeking: Fixed next-track failures when seeking within the last 5 seconds of a track.
3.
Playback Stability: Reduced intermittent dropouts via synchronization optimizations.
4.
Playback State: Corrected playback state display in certain cases.
Streaming Services
1.
Amazon Music: Improved playback start/resume and casting stability.
2.
Spotify: Fixed failures playing from Recommended/Recently Played in the Spotify app.
3.
Qobuz: Fixed shuffle-related dropouts and playback-mode mismatch issues.
4.
Pandora: Resolved track skipping after resume and fixed login failures.
5.
vTuner Radio: Added a backup stream URL fallback to improve playback reliability.
6.
TuneIn Radio: Faster startup when playing Apple Music station.
4.6.730353
Release date: September 24, 2025
Bug Fixes
1.
Pandora: Resolved track skipping after resume and login failures.
2.
Alarms: Station-based alarms now trigger reliably.
3.
TuneIn: Apple Music radio via TuneIn now resumes after long pauses; reduced radio playback failures.
4.6.728831
Release date: September 9, 2025
What's New
1.
Smart Preset: Create scenes for your favorite setups, including Input, Output, Playback, Volume, EQ, and Shuffle. Activate your scene with a single tap.
2.
Bluetooth: Adjustable latency for perfectly synced audio.
3.
Deezer: "Play Next / Play Last" options added.
4.
TuneIn: Automatically uses the highest-quality stream for improved playback.
5.
6.
HotMix Preset: Added support for HotMix Preset.
7.
Sub Pro Intergration: Improved pairing experience and overall functionality when using the Sub Pro.
Bug Fixes
1.
Alarm Fix: Fixed a bug where only the default tone played for Pandora alarm.
4.6.719753
Release date: June 11, 2025
What's New
1.
TIDAL Playback Enhancement: Improved playback stability and smoother performance for TIDAL and TIDAL Connect.
2.
Pandora Thumbs Up/Down: Instantly like or dislike tracks from your WiiM Mini (requires app v3.2.2+)
3.
Spotify Connect Continuity: Seamlessly resume Spotify playback after switching inputs.
4.
Group Mute/Unmute via Group Lead Device: Instantly mute or unmute the entire speaker group directly from the group lead device for seamless group control.
5.
Enhanced DSD Playback: Resolved stuttering during multi-channel DSD file playback for smoother high-res listening.
Bug Fixes & Enhancements
1.
Plex Playback Fix: Resolved playback failure when Secure Connections is set to "Required".
2.
General Fixes: Made several performance improvements and fixed miscellaneous bugs.
4.6.713548
Release date: April 11, 2025
What's New
1.
Spotify Loudness Normalization: Added support for Spotify's Loudness Normalization.
2.
TIDAL Queue Enhancements: Improved shuffle functionality with track order retention and faster queue performance.
3.
TIDAL Auto Play: Now supports auto-play; enable it in the WiiM Home App.
4.
Preset Enhancement: Presets now work in follower mode.
5.
Device Discovery Improvements: Enhanced stability for WiiM Home, Spotify, and TIDAL apps, improving device detection and connectivity.
6.
Wi-Fi Vulnerability Improvement: Resolved issues to enhance Wi-Fi security.
7.
Enhanced Radio Paradise: Added Serenity, Radio 2025, and My Favorites Mix stations with track-skipping support.
8.
Track-End Sleep Timer: New option to pause playback at the end of a track—perfect for winding down. (Requires app update: iOS 3.1.9 / Android 3.1.8)
Bug Fixes & Performance Improvements
1.
Deezer Alarm Fix: Fixed an issue where Deezer Mix alarms were not functioning properly.
2.
Qobuz Fix: Resolved intermittent login issues; Fixed track start problems after skipping and unexpected playback jumps.
3.
Amazon Music: Fixed playback issues for Prime users.
4.
TIDAL Fix: Fixed skipping, playback errors, and incorrect quality cap on 24-bit/96kHz optical/coax outputs.
5.
Playback Fixes: Resolved multi-room audio crashes and fixed a skipping issue at the end of some MP3 files.
6.
General Enhancements: Improved overall stability, performance, and bug fixes.
4.6.708757
Release date: February 25, 2025
What's New
1.
Persistent Group Support: Enhanced quick selection and synchronization for multi-room audio across devices.
2.
Room Correction: Optimize your speakers to match your room's acoustics with the new Room Correction feature.
3.
Enhanced DHCP Compatibility: Improved stability and reliability across various routers.
4.
Replay Gain Enhancements: Replay Gain now supported for TIDAL, Qobuz, NAS, and local libraries.
5.
My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4)
6.
Preset Enhancements: Added support for moving presets (requires app v3.1.4)
7.
Playback Enhancements: Resolved Audible playback issues via Alexa and fixed playback problems affecting certain custom radio stations.
Bug Fixes
1.
Radio Paradise Fix: Corrected a playback failure issue.
2.
Gapless Playback Enhancement: Fixed an issue that caused skipping when playing tracks shorter than 10 seconds.
3.
4.6.639930
Release date: December 27, 2024
What's New
1.
Plex Enhancements: Added the ability to save Plex stations as Presets.
2.
Replay Gain: Added support for TIDAL, Qobuz and Plex.
3.
Enhanced Alarm Functionality: If your chosen music isn't available, fallback sounds will ensure you never miss your alarm.
4.
Qobuz Queue Enhancements: Experience improved playback with Qobuz, featuring track order retention during shuffle, Replay Gain support, and faster queue performance.
Bug Fixes
1.
Amazon Music: Resolved playback not resuming after extended pauses.
2.
General Fixes: Various performance improvements and bug fixes.
4.6.634732
Release date: November 6, 2024
What's New
1.
Improved Alarm Behavior for Plex: Default alarm sound will now play if Plex server is unavailable.
2.
  • Fixed an issue where playback could not resume after Wi-Fi reconnection.
  • Fixed an issue preventing Audible Books from playing through Alexa.
  • Fixed noise issue when resuming Amazon Music.
  • Fixed playback crash for Deezer alarms and presets.
  • Corrected metadata for custom radio stations.
Bug Fixes
1.
Sync Audio Fix: Fixed an occasional error for Sync Audio.
2.
Alarm Time Fix: Corrected rare incorrect alarm issue.
3.
Group Stability: Fixed unexpected device removal from group.
4.
Offline Responsiveness: Improved response without internet.
5.
General Enhancements: Various performance improvements and bug fixes to enhance overall operation.
4.6.629252
Release date: September 13, 2024
What's New
1.
Plex Support: Add Plex support for accessing and playing music directly within the WiiM Home app. Requires iOS app version 2.11.6. Android support will be available next week.
2.
Playback Improvements:
  • Resolve issues with Amazon Music, including skipping during playback and inability to start playback.
  • Resolve an issue preventing Audible Books from playing through Alexa.
  • Fix playback issues affecting certain custom radios.
  • Add artwork display for Radio Paradise on the app.
4.6.626453
Release date: August 15, 2024
Bug Fixes
1.
Spotify Connect Playback: Resolved an issue that caused playback stuttering when using Spotify Connect.
4.6.626153
Release date: August 13, 2024
Bug Fixes
1.
  • Fixed TIDAL playback skipping and stopping issues.
  • Resolved playback stuttering when streaming from NAS at 192kHz.
4.6.625648
Release date: August 8, 2024
What's New
1.
Media Player Optimization:
  • Fixed issues with certain m3u8/HLS format audio.
  • Resolved the issue preventing Sirius XM playback via Alexa.
2.
Stabilized Wi-Fi Connection: Updated the Wi-Fi driver to enhance connection stability.
Bug Fixes
1.
Pop Noise Fix: Reduced pop noise for Spotify Connect and TIDAL Connect.
2.
General Enhancements: Various bug fixes and performance improvements for a smoother experience.
4.6.622553
Release date: July 8, 2024
What's New
1.
DLNA Behaviors Enhancement: Added support for loop and shuffle modes in DLNA playback.
2.
TIDAL Connect Enhancements: Fixed playback stops, loop and shuffle issues, and incorrect playing status. Correct metadata now displays in multi-room audio.
3.
HTTP API Update: Updated to provide browse and control Presets.
Bug Fixes
1.
Alarm Behavior for Spotify Connect: Fixed alarm not stopping automatically when duration ended.
2.
Pop Noise Reduction: Resolved occasional popping noises occurring at 16-bit/44.1 kHz or 16-bit/48 kHz.
3.
4.6.620757
Release date: June 21, 2024
What's New
1.
10-band PEQ: Customize your sound with the new Parametric Equalizer.
2.
Qobuz Login Enhancement: Updated Qobuz OAuth2 login to support third-party login.
3.
Refined Input Auto-Sensing: Enhanced behavior ensures seamless audio transitions.
4.
HTTP API Update: Updated to provide complete current playback information.
Bug Fixes
1.
TIDAL Connect: Fixed incorrect artwork display.
4.6.618555
Release date: May 30, 2024
What's New
1.
Refined Input Auto-Sensing: Enhanced auto-sensing ensures smooth audio transitions without interruptions, automatically switching inputs only when there is no active playback.
2.
Enhanced Alarm Behavior: Alarms now increase smoothly to the set volume without interrupting ongoing playback.
Bug Fixes
1.
Pandora Login Issue: Resolved an issue causing frequent re-logins.
2.
EQ Toggle Issue: Corrected a bug preventing toggling EQ settings on or off.
4.6.616636
Release date: May 11, 2024
What's New
1.
2.
Refined Input Auto-Sensing: Updated technology for seamless audio transitions.
Bug Fixes
1.
TIDAL Connect Stability: Fixed crashes and bitrate display issues.
4.6.614047
Release date: April 16, 2024
What's New
1.
Per-Source EQ (Requires App version 2.9.0+): Customize EQ settings individually for each input source.
2.
Enhanced DHCP Stability: The DHCP service has been upgraded to enhance network stability and connectivity.
Bug Fixes
1.
Track Metadata XML Fix: We've corrected a problem with the Track Metadata XML missing the xmlns:song namespace, ensuring better metadata management.
2.
AAC/ALAC Bitrate Display Fixed: Now shows the correct bitrate for these formats.
3.
Remote Pairing Stability: Enhanced the WiiM Voice Remote's pairing process for a more reliable connection.
4.6.612653
Release date: April 2, 2024
Bug Fixes
1.
Resolved Pandora Crash Issue: The issue causing Pandora to crash has been fixed, ensuring uninterrupted listening.
4.6.612034
Release date: March 26, 2024
Bug Fixes
1.
Bluetooth Playback Improvement: Fixed stuttering issues with some Bluetooth headphones and earphones for smoother audio playback.
2.
Preset Management Enhancement: Resolved a bug that obstructed preset replacement, improving reliability and user experience.
3.
Enhanced Stability with Pandora: Resolved the issue affecting Pandora usage, ensuring a more seamless listening experience.
4.
AirPlay Fade-in/Fade-out: Fixed the Fade-in and Fade-out settings for AirPlay streaming.
4.6.609132
Release date: February 29, 2024
What's New
1.
Custom Radio Metadata: Now with dynamic track information, compatible with our latest app.
2.
New Wi-Fi Disconnection Indicator: The device status light now glows yellow to signal Wi-Fi disconnection, replacing the previous solid red indicator.
4.6.606643
Release date: February 4, 2024
What's New
1.
Per-Source Volume Control: Introducing individual volume control with memory for Aux In and Wi-Fi input sources, allowing for a tailored listening experience on your device. (Compatible with App version 2.8.4 and above)
Bug Fixes
1.
Improved Remote Connection Stability: Enhanced the stability of the connection between the WiiM Voice Remote and your WiiM device.
2.
TIDAL Connect Stability: Resolved unexpected crashes when using TIDAL Connect, ensuring a more reliable streaming experience.
4.6.605558
Release date: January 24, 2024
What's New
1.
Optimized Wi-Fi Connectivity with Mesh Network: Enjoy uninterrupted connectivity as your device intelligently selects the strongest Wi-Fi access point, ensuring a stable and robust connection.
2.
Qobuz & TIDAL Autoplay Integration: When your music queue ends, Qobuz & TIDAL takes over by playing similar tracks, keeping the music flowing without interruption.
Bug Fixes
1.
Stabilized Wi-Fi Connection: Addressed and fixed a Wi-Fi exception issue, significantly enhancing Wi-Fi stability.
2.
Improved Remote Connection Stability: We have made significant improvements to enhance the stability of the connection for the WiiM Voice Remote.
3.
General Enhancements: Various other bug fixes and performance improvements for a smoother experience.
4.6.603557
Release date: January 4, 2024
What's New
1.
Volume Balance: We've introduced a Volume Balance feature, allowing you to fine-tune the audio levels between the left and right channels for a more personalized listening experience. Please find the guidelines here. Learn More >>
Bug Fixes
1.
Update Behavior Correction: Corrected an issue where updates would inadvertently initiate during playback from Aux-in input. Updates will now occur at more appropriate times to avoid disruption.
2.
Qobuz Playback Improvement: Implemented a feature to automatically skip to the next track if the current one is unavailable, maintaining a seamless listening flow.
3.
Google Cast Playback Issue: Fixed a bug that resulted in no sound when using Google Cast. Users can now seamlessly transition to Google Cast without audio interruptions.
4.
5.
4.6.539351
Release date: December 21, 2023
Bug Fixes
1.
2.
Spotify Connect Stability: Fixed the unresponsiveness issue in Spotify Connect for a smoother user experience.
3.
Deezer Playback Improvement: Implemented a feature to automatically skip to the next track if the current one is unavailable, maintaining a seamless listening flow.
4.
4.6.537050
Release date: December 10, 2023
What's New
1.
Distinct Status Light Indicators for Input Sources:
  • Line-in sources are indicated with a light green light.
  • Bluetooth sources are represented by a pure green light.
Bug Fixes
1.
Enhanced EQ Experience: Resolved an issue where playback would stop when switching between PEQ (Parametric EQ) and GEQ (Graphic EQ). Reduced CPU usage during EQ operations for more efficient performance.
2.
TIDAL Connect Stability Enhancements: Addressed and fixed unexpected crashes when using TIDAL Connect, ensuring a more reliable streaming experience.
3.
Calm Radio Login Fix: Resolved an issue preventing login to Calm Radio accounts containing the "$" character.
4.6.537050
Release date: November 29, 2023
What's New
1.
TIDAL Hi-Res FLAC in WiiM Home App: We've introduced TIDAL Hi-Res FLAC support, allowing you to stream directly up to 24-bit/192kHz.
2.
Napster API Upgrade: We've updated to the latest Napster API for enhanced and more reliable streaming.
Bug Fixes
1.
TuneIn Custom URL Preset Issue Resolved: Fixed the issue with TuneIn Custom URL presets.
2.
Bluetooth Streaming Reliability: Addressed occasional crashes during Bluetooth streaming.
3.
4.6.536231
Release date: November 20, 2023
What's New
1.
TIDAL Hi-Res FLAC Support: Introducing support for TIDAL Hi-Res FLAC via TIDAL Connect, enabling direct streaming up to 24-bit/192kHz from TIDAL App.
2.
Spotify Connect Upgrade: Transitioned to the latest Spotify Connect ESDK for an enhanced user experience.
Bug Fixes
1.
Service Access: Resolve a rare issue where incorrect system time settings prevented users from accessing services.
2.
Enhanced Remote Pairing Stability: Improved the pairing stability of the WiiM Voice Remote, ensuring a more reliable and seamless connection experience.
3.
TIDAL Connect Stability Improvements: Fixed problems with TIDAL Connect, including unplayable tracks and unexpected crashes, for a smoother streaming experience.
4.
Spotify Connect Playback Optimization: Resolved the brief silence encountered during the first half-second of song playback on Spotify Connect, ensuring uninterrupted audio from the very start of each track.
4.6.532836
Release date: October 18, 2023
What's New
1.
Enhanced Amazon Music HD Streaming: Memory optimization now allows for smoother 24-bit/192kHz audio streaming on Amazon Music HD.
Bug Fixes
1.
TuneIn Radio Playback: Resolved issues that were blocking playback on select TuneIn radio stations.
2.
WiiM Voice Remote Pairing: Fixed intermittent pairing issues with the WiiM Voice Remote for a more reliable connection.
3.
Bluetooth EQ Settings: Corrected EQ settings for enhanced audio output in Bluetooth mode.
4.6.530553
Release date: September 26, 2023
What's New
1.
Improved in-App Deezer experience: Deezer update with new API and functions. Please re-login to Deezer via the WiiM Home app.
2.
Parametric EQ Support: Compatible with App version 2.5.5 and above.
Bug Fixes
1.
Enhanced Stability: Fix occasional crashes during volume adjustment.
2.
Alexa TTS: Fix noise distortion in Alexa TTS when using BT source mode.
3.
Play Queue
  • Corrected track ordering when adding multiple Amazon albums.
4.
TIDAL Access: Resolved issues with third-party authentication for TIDAL access.
4.6.528043
Release date: September 1, 2023
This update includes
1.
Improvement
  • Wi-Fi connection stability on certain routers.
2.
Fixed –DHCP improvement for IPv6 on certain routers.
3.
Fixed
  • Unable to pair with the WiiM Remote occasionally.
4.
Fixed
  • Qobuz shuffle play.
5.
Fixed
  • Play with the wrong speed for Bluetooth output with one-channel.
6.
Fixed
  • No metadata with AirPlay and Amazon Music in certain use cases.
7.
Other bug fixes and performance improvements.
4.6.526458
Release date: August 16, 2023
1.
New Feature
  • Volume limit (Compatible with the new App to be updated in a few days)
2.
New Feature
  • Add entire album/playlist to the play queue for TIDAL (Compatible with the new app updated in a few days)
3.
Fixed
  • Occasional failure to stop Amazon Alexa multi-room playback.
4.
Fixed
  • Pop noise with Amazon Alexa multi-room.
5.
Fixed
  • Fade-in/fade-out off.
6.
Fixed
  • Incorrect playback order with the large Qobuz play queue.
7.
4.6.524356
Release date: July 26, 2023
1.
New Feature
  • Support MQA core decoder for TIDAL in the WiiM Home App.
2.
New Feature
  • Add entire album/playlist to the play queue for Amazon Music and Qobuz (Works with new App version 2.5.4)
3.
Improvement
  • Update the new AirPlay SDK.
4.
Improvement
  • Better audio quality of audio prompts.
5.
Fixed
  • Unable to setup the device with Android 14 beta version.
6.
Fixed
  • Unable to enter standby mode after receiving the AVS notification.
7.
Fixed
  • Metadata refresh issue for TuneIn.
8.
Fixed
  • Playback stuttering for certain TuneIn radios.
9.
Fixed
  • Unable to play the AIFF/AIF format tracks.
10.
4.6.523147
Release date: July 14, 2023
1.
Improvement
  • Display Authentication and Playback exception on the WiiM Home app.
2.
Fixed
  • Unable to connect to the wireless network whose SSID contains the space character.
3.
Fixed
  • Rare random crash of TIDAL Connect.
4.
Fixed
  • Unable to sign in TuneIn using 3rd party services (Works with the latest app that will be updated in a few days)
5.
4.6.521630
Release date: June 30, 2023
1.
Fixed
  • Rare random crash issue for Spotify Connect.
2.
Fixed
  • Pop noise when changing tracks with different endian (Little or big-endian)
3.
Fixed
  • Unable to mute when using BT Source Mode.
4.
Fixed
  • Auto-sensing doesn't work in rare cases.
5.
4.6.520141
Release date: June 15, 2023
This update involves the following
1.
Improvement
  • Power consumption of WiiM Voice Remote.
2.
Improvement
  • Unable to connect to Spotify Connect.
3.
Fixed
  • Pop noise and incorrect metadata display for Apple AirPlay.
4.
Fixed
  • Pop noise and freeze issues when seeking to the beginning of the playing track with TIDAL Connect for tracks under Normal and High quality.
4.6.518747
Release date: June 1, 2023
1.
Improvement
  • Support flc and m3u8 extension and AIFF format for DLNA.
2.
Improvement
  • The volume control of the voice remote adjusts the group volume instead of the volume of the group lead speaker when using LinkPlay multiroom.
3.
Fixed
  • One-second sound cut when changing tracks for TIDAL (Need to go to the WiiM Home App, select Device tab > Device settings gear icon > Audio Input > Sample Rate Switch Latency, start to try 500ms)
4.
Fixed
  • Random crash issues for Calm Radio Preset.
5.
4.6.517454
Release date: May 19, 2023
1.
Improvement
  • Connection stability for Spotify Connect.
2.
Improvement
  • new Auto-sensing of Aux-in(Need to turn it on at the latest app to be released in a few days)
3.
Improvement
  • AirPlay playback smoothness.
4.
Fixed
  • Pop noise with LinkPlay multiroom when using analog output.
5.
Fixed
  • Pop noise with SPDIF out and Line out when exiting from idle.
6.
Fixed
  • Incorrect Bluetooth reconnection.
7.
Fixed
  • Rare random crash issues for the TIDAL Connect.
8.
Fixed
  • Pop noise when playing iHeartRadio with Amazon Alexa multi-room.
9.
Fixed
  • Incorrect playback progress after seeking when playing Podcast with Spotify Connect.
10.
Fixed
  • Incorrect MIME type issue for DLNA.
11.
Fixed
  • Incorrect metadata display for DLNA.
12.
Fixed
  • Unexpected stop when playing DLNA content.
13.
4.6.515159
Release date: April 27, 2023
1.
New Feature. Learn More >>
  • Support input source switch via Alexa for WiiM voice remote.
2.
Improvement
  • Always connect to the latest one if the device has been paired with multiple Wi-Fi networks.
3.
Improvement
  • Update new Spotify Connect ESDK (Preset of Spotify is invalid due to the SDK change, please use the WiiM Home companion App to save it again)
4.
Fixed
  • Pop noise with SPDIF out.
5.
Fixed
  • Unable to play the tracks whose address contains space characters in some media servers such as Kodi etc.
6.
Fixed
  • Random crash issues for Amazon Music.
7.
Fixed
  • Unable to logout TuneIn.
8.
Fixed
  • Pop noise with LinkPlay multiroom.
9.
Fixed
  • The playback progress is not inaccurate at the end of the playing track.
4.6.514253
Release date: April 18, 2023
1.
New Feature
  • Support dynamic track metadata information for Radio Paradise.
2.
New Feature
  • Support input source switch via Alexa.
3.
Improvement
4.
Fixed
  • Unable to play music after playing an ad for Amazon Music Free.
5.
Fixed
  • Random crash issues for AirPlay and TIDAL Connect.
6.
Fixed
  • Random crash issues for Amazon Alexa multi-room.
7.
Fixed
  • No sound issue with LinkPlay multiroom when using Bluetooth input.
8.
Fixed
  • Unable to play specific radio stations from TuneIn.
9.
4.6.512532
Release date: April 1, 2023
1.
Fixed
  • Random crash issues for TIDAL Connect.
2.
Fixed
  • Keep the IP address unchanged when reconnecting to certain routers.
3.
Improvement
  • 5G Wi-Fi connection stability.
4.
Improvement
  • Connection stability of TIDAL Connect.
4.6.511655
Release date: March 23, 2023
1.
New Feature
  • Support preset from Radio Paradise and custom URL.
2.
Improvement
  • Connection stability of Spotify Connect.
3.
Improvement
  • On-device LED prompt when pressing the button on the WiiM Voice Remote.
4.
Fixed
  • EQ clipping when using the fixed volume option or playing music with high volume.
5.
Fixed
  • Random crash issues for TIDAL Connect, Amazon Music, Qobuz and Sound Machine.
6.
Fixed
  • Random crash issues in Bluetooth output mode.
7.
Other improvements and bug fixes.
4.6.510763
Release date: March 14, 2023
1.
Improvement
  • TIDAL playback smoothness.
2.
Fixed
  • Unexpected stop when playing Amazon Music HD.
3.
Fixed
  • Unable to log in to TIDAL and Qobuz on the WiiM Home app (in the rare case)
4.
Fixed
  • One-second sound cut when changing tracks for TIDAL.
5.
Fixed
  • Voice Control doesn't work sometimes with the WiiM Voice Remote.
6.
Fixed
  • Display wrong EQ setting for custom EQ on the WiiM home App.
7.
4.6.509552
Release date: March 1, 2023
1.
New Feature
  • Support WiiM voice remote.
2.
Improvement
  • Wi-Fi connection stability.
3.
Improvement
  • Dim the brightness of the status light when the device goes to standby.
4.
Fixed
  • Unable to play music from preset in some rare cases.
5.
Fixed
  • Unable to go to standby when TIDAL connect is paused.
6.
Fixed
7.
4.6.507043
Release date: February 8, 2023
1.
Fixed
  • 5s delay to pause AMHD.
2.
Fixed
  • Unexpected stop when playing AMHD.
3.
Fixed
  • Unable to use the TIDAL Connect after seeking and skipping multiple times.
4.
Fixed
  • Unexpected logout for Amazon Music account when the internet is inaccessible.
5.
Fixed
  • Rare random crash issues for the TIDAL Connect and Spotify Connect.
6.
Fixed
  • Unable to mute with Amazon Alexa.
7.
Fixed
  • Play with the wrong speed for the TIDAL Connect in rare cases.
8.
Fixed
  • The track is skipped occasionally when playing AMHD from Amazon Music app.
9.
4.6.504752
Release date: January 16, 2023
1.
Fixed
  • Deezer API bug.
2.
Fixed
  • Unexpected stop when playing Amazon Prime music.
3.
New feature
  • Support dynamic track metadata information for vTuner.
4.6.503558
Release date: January 4, 2023
1.
Fixed
  • Playback stuttering with TIDAL Master when turning on MQA Core Decoder.
4.6.503249
Release date: January 1, 2023
1.
New Feature
  • Override the functionality of volume + and
  • buttons with playing previous and next track (Need turn it on with the latest app released in a few days)
2.
Improvement
  • Reduce the aux-in latency.
3.
Improvement
4.
Improvement
  • Add audio format data in SPDIF output channel status.
5.
Fixed
  • Blurry album artwork for Qobuz.
6.
Fixed
  • OTA failure for certain cases.
7.
Fixed
  • Occasional pop noise when changing tracks for Hi-Res content.
8.
Fixed
  • Unexpected stop when playing Amazon music HD.
9.
Fixed
  • 3S gap when switching a new track for TIDAL (both WiiM App and TIDAL Connect, bug introduced by last OTA)
10.
4.6.439150
Release date: December 19, 2022
1.
  • Auto sensing of the Aux-in signal (Only detect when the device is idle and need turn it on with the latest App)
2.
Improvement
  • Use 8.8.8.8 as the default DNS Server (Can be turned off with the App)
3.
Improvement
  • Support the new requirement of Amazon Prime Music (Not Amazon Music Unlimited)
4.
Improvement
  • BLE connection during the network setup.
5.
Improvement
  • Update new AirPlay SDK and improve the experience of YouTube Music over AirPlay.
6.
Fixed
7.
Fixed
  • Playback stuttering for Aux-in.
8.
4.6.437934
Release date: December 7, 2022
1.
Fixed
  • Temporarily remove auto sensing of the Aux-in signal to fix the music to be played in the wrong speed in some use cases.
4.6.437454
Release date: December 2, 2022
1.
New Feature
  • Auto sensing of the Aux-in signal (only detect when device is idle)
2.
Improvement
  • Unexpected stop when playing Amazon music station.
3.
Fixed
  • Wi-Fi reconnection failure on routers with the WPA3 encryption.
4.
Fixed
  • Pop noise with TIDAL Master when turning on MQA Core Decoder.
5.
4.6.435954
Release date: November 18, 2022
1.
New Feature
  • MQA Core Decoder beta (Need turn it on with the latest app released in a few days)
2.
Fixed
  • Unexpected playback stop of Amazon Music station.
3.
Fixed
  • Inability to play the preset of TuneIn and vTuner.
4.
Improvement
  • BT latency when used as the BT sink.
5.
Improvement
  • Amazon Music HD/UHD CPU usage.
6.
4.6.434955
Release date: November 10, 2022
1.
Fixed
  • Sound distortion issue caused by EQ.
2.
Fixed
  • Unable to resume the Amazon Music.
3.
Improvement
  • Select the best content from Qobuz based on SPDIF output resolution.
4.
4.6.434158
Release date: October 31, 2022
1.
New Feature
  • Pandora music service (Works with the latest app updated in a few days)
2.
Fixed
  • AirPlay bug on IP v6 network (Use App to disable IPV6 if it doesn’t work for you)
3.
Fixed
  • Unable to pause Amazon HD.
4.
Fixed
  • Incorrect play status for Amazon Music Gapless playback.
5.
New Feature
  • Add the entire album and playlist to the play queue for Amazon music.
6.
New Feature
  • Use the Aux-in content as the Alarm source.
7.
Other performance improvements.
4.6.432755
Release date: October 17, 2022
1.
Improvement
  • Amazon Music memory optimization for 24/192k audio.
2.
Improvement
  • Select the best AP for the mesh network.
3.
New Feature
  • Options to set the SPDIF idle timeout.
4.
New Feature
  • SoundCloud Beta.
4.6.432142
Release date: October 11, 2022
1.
Improvement
  • Spotify playback smoothness.
2.
Fixed
  • F ollower speaker volume issue for the Spotify multiroom.
3.
Fixed
  • EQ clipping when using the fixed volume option or playing music in high volume.
4.
New feature
  • Add movie and gaming EQ modes.
5.
Improvement
  • SPDIF output becomes idle when system stops play in two minutes.
6.
Improvement
  • Bit perfect output for LinkPlay multiroom for 48k Hz or lower, 16-bit content.
7.
Fixed
  • Keep the BT Source mode when the device reboots.
8.
4.6.430138
Release date: September 22, 2022
1.
Improvement
  • The memory optimization when playing AMHD.
2.
Fixed
  • Occasional track skip when playing AMHD from Amazon Music Casting.
3.
Fixed
  • “View album” and “View artist” bugs for Qobuz on playing now UI.
4.
Fixed
  • The unexpected playback pause with the UPnP/DLNA (introduced by gapless playback of DLNA)
5.
Fixed
  • Incorrect track duration and bit depth for AMHD on playing now UI.
6.
Fixed
  • Support the multiroom audio for the Amazon Music HD (no UHD)
4.6.429354
Release date: September 15, 2022
1.
New Feature
  • Support the gapless playback of Amazon music casting and DLNA.
2.
New Feature
  • Support Multiroom for the TIDAL Master content.
3.
Improvement
  • Enable the latest Qobuz API (Need re-login to your account with the latest app)
4.
Fixed
  • Occasional pop noise when changing tracks.
5.
Fixed
  • Audio output mode after power-on.
6.
4.6.428136
Release date: September 5, 2022
1.
Improvement
  • Gapless playback for Amazon Music Ultra HD on the WiiM Home App (by removing the fade in/out)
2.
Fixed
  • Taking 15-20 seconds to change song with TIDAL Connect in some rare cases.
3.
Fixed
  • Unable to resume the playback for the last song on Amazon Music Playlist.
4.
Fixed
  • Random crash when calling HTTP API for WiiM Mini.
5.
Fixed
  • Spotify Preset doesn't work on certain use cases.
6.
4.6.427455
Release date: August 26, 2022
1.
New Feature
  • Gapless playback for Amazon Music Ultra HD on WiiM Home App.
2.
New Feature
  • Increase the number of presets from 6 to 12.
3.
Improvement
  • TIDAL playback performance improvement on the WiiM App.
4.
Fixed
5.
Fixed
  • Random crash issues for the TuneIn.
6.
4.6.427031
Release date: August 22, 2022
1.
Disable Amazon Music UHD/HD by default for the multiroom of Alexa and Amazon music casting (can be turned on in WiiM App). It doesn't affect the Amazon Music HD/UHD in the WiiM App.
4.6.426454
Release date: August 16, 2022
1.
Fixed
  • The disconnection between the WiiM Mini and DLNA application after pausing the music.
2.
Fixed
  • Unexpected disconnection from the Bluetooth receiver when the WiiM Mini works as the BT transmitter.
4.6.426049
Release date: August 12, 2022
1.
New Feature
  • Amazon Ultra HD casting from Amazon Music App.
2.
New Feature
  • Two-way Bluetooth communication (Works with the latest app updated in a few days)
3.
New Feature
  • 10-band graphic EQ (iOS)
4.
New feature
  • New music service: Calm Radio.
5.
Improvement
  • Improve the Wi-Fi connection stability for the mesh network.
6.
Improvement
  • Bitrate display on app for TIDAL Connect.
7.
Fixed
  • Multiroom playback when Amazon Music UHD is turned on (when in group, only SD content is chosen to play)
8.
Fixed
  • ATMOS playback for TIDAL Connect (select HD content instead)
9.
Fixed
  • AUTO SYNC.
10.
Fixed
11.
4.6.424434
Release date: July 27, 2022
1.
Improvement
  • Enable Amazon Music HD/UHD with the WiiM Home App by default.
2.
Improvement
  • Rare playback stuttering for the TIDAL Connect and Spotify Connect.
3.
Fixed
  • Incorrect audio latency setting when using manual Audio Sync with the WiiM Home app.
4.
Fixed
  • Randomly, unable to play/pause TIDAL Connect when using the on-device button.
5.
Fixed
  • Incorrect bit depth display for Amazon Music HD/UHD on playing now UI.
6.
Fixed
  • Unable to resume the playback for Amazon Music HD/UHD in some use cases.
7.
Fixed
  • Incorrect album art for Amazon Music on playing now UI.
8.
*Known issues
1.
Amazon Music UHD won't work with the multiroom audio. Please disable the Amazon Music UHD when playing audio in group to resolve this issue. The step is to go to Browse tab -> Amazon Music > Setting > turn off the Amazon Music HD/UHD Beta on the WiiM App. We'll fix this issue by the end of August.
4.6.422564
Release date: July 8, 2022
1.
Fixed
  • Fix the audio clipping issue for certain preset EQ modes.
2.
Fixed
  • Inability to play TIDAL Master with the WiiM Home app.
3.
Fixed
  • Incorrect metadata display for Amazon Music on WiiM App.
4.
Fixed
  • The default audio latency setting for the AirPlay synchronization.
5.
Fixed
  • Incorrect audio quality display on the WiiM App for Deezer.
4.6.421831
Release date: June 30, 2022
1.
Fixed
  • WiFi disconnection when the device is idle for a day and using S/PDIF output.
2.
Fixed
  • Inability to resume playback in the TIDAL Connect when pausing for more than 2 hours.
3.
Fixed
  • Track is skipped occasionally when playing AMHD from WiiM app.
4.
Fixed
  • Only 4-5 tracks are played repeatedly when playing Amazon Music station from the WiiM app.
5.
Fixed
  • Shuffle playback for Amazon Music.
4.6.420439
Release date: June 17, 2022
1.
New Feature
  • Support Amazon Music HD, Ultra HD on the WiiM Home app (Public preview)
2.
Improvement
  • Wi-Fi connection stability by fixing to 5 Ghz band.
3.
Fixed
  • Bug in the TIDAL Connect when pausing for more than 2 hours.
4.
Fixed
  • Random playback stuttering for Spotify Connect.
5.
How to turn on Amazon Music HD/UHD in WiiM Home app? Learn More >>
6.
*Known issues for AMHD (Amazon Music HD/UHD):
  • AMHD with multiple Echo or Alexa-Enabled devices isn't supported.
  • Gapless playback of AMHD isn't supported.
  • Occasional pop noise when changing tracks with different sample rates on AMHD.
  • Occasionally casting a 24/192 track from the Amazon Music app is stopped unexpectedly.
  • When playing AMHD from WiiM app, track is skipped occasionally.
4.6.419430
Release date: June 8, 2022
1.
New Feature
  • Make 8.8.8.8 as the preferred DNS server (App can change it)
2.
Fixed
  • Wi-Fi disconnection when device is idle on certain routers.
3.
Fixed
  • Silence OTA.
4.6.418249
Release date: May 27, 2022
1.
New Feature
  • TIDAL Master support on TIDAL Connect (no MQA)
2.
Improvement
3.
Fixed
  • Device setup failure due to DHCP timeout.
4.
Fixed
  • SPDIF auto-off when device is idle.
5.
What type of TIDAL Master supported on WiiM Mini? Learn More >>
4.6.417855
Release date: May 23, 2022
1.
New feature
  • New music service: Sound Machine (Works with the latest app that will be updated in a few days)
2.
New feature
  • Bit perfect AirPlay.
3.
Fixed
  • Small gap for Qobuz hi-res and Amazon music with WiiM Home App.
4.
Fixed
  • WiFi disconnection when the device is idle for a day on certain routers.
5.
Fixed
  • Random no sound issue when casting music from Amazon Music App to WiiM Mini.
4.6.417160
Release date: May 16, 2022
1.
New Feature
  • Bit-depth and sample rate display on app for Spotify Connect and TIDAL Connect.
2.
Fixed
  • DLNA playback information on app due to incorrect UPnP metadata tag handling.
3.
Fixed
  • Incorrect voice prompt for Aux-in mode.
4.
Fixed
  • No TTS when Alexa plays 44.1 KHz music.
5.
Fixed
4.6.415357
Release date: April 29, 2022
1.
New Feature
  • Display sample rate and bit depth on the WiiM Home app.
2.
Fixed
  • Random playback stuttering (from 44.1k/16 up to 192k/24) not due to network bandwidth.
3.
Fixed
  • M4A decoding compatibility bug for TIDAL Connect.
4.
Fixed
  • Incorrect red color LED even the network is connected.
5.
Fixed
  • Random no sound issue for AirPlay during multiroom playback.
6.
Fixed
  • No sound issue when switching to ‘work with Alexa’ mode on certain use cases.
7.
Fixed
  • The connection loss of TIDAL Connect after playlist is complete (need one extra device selection)
4.6.412856
Release date: April 4, 2022
1.
Fixed
  • Random playback stuttering not due to network bandwidth.
2.
Fixed
  • No sound issue for AirPlay on certain Apple Device.
4.6.412161
Release date: March 28, 2022
1.
Fixed
  • Playback stuttering for TIDAL Connect and Spotify Connect.
2.
Improvement
  • Optical signal continuity when skipping a track.
4.6.410354
Release date: March 11, 2022
1.
Improvement
  • Improve Wi-Fi connection stability.
2.
Improvement
  • Preset volume for Spotify Connect won't be changed during the first connection.
3.
Improvement
  • Stabilized BLE connection during the network setup.
4.
Fixed
  • Fixed playback stuttering for TIDAL Connect and no sound issue for aux-in audio sometimes.
5.
Fixed
  • Fixed no sound issue when streaming from MAC via AirPlay.
4.6.408751
Release date: February 25, 2022
1.
Fixed
  • Qobuz can't sign in with Internet Security.
2.
Fixed
  • Stuttering issue with TIDAL Connect.
4.6.408142
Release date: February 19, 2022
1.
Fixed
4.6.407860
Release date: February 17, 2022
1.
New Feature
  • Bit perfect 24bit/192kHz output to optical SPDIF.
2.
New Feature
  • Fixed Volume Output, i.e., volume is fixed to 100% without digital attenuation.
4.6.408751
1.
Fixed
2.
Fixed
3.
To keep compatibility with the legacy optical audio receiver, we set the maximal output to 48 kHz/16 bit. You can follow the instruction on the app and adjust the output up to 192 kHz/24 bit from the updated WiiM Home App that can be available around Feb. 20th.
4.6.405853
Release date: January 28, 2022
1.
  • 24 Preset EQ.
2.
New Feature
  • Audio output selection between Aux out and SPDIF via WiiM Home app.
3.
Fixed
  • Amazon Music can't play music randomly.
4.6.405258
Release date: January 24, 2022
1.
New Feature
  • Gapless playback supported for all streaming content.
2.
Fixed
  • Login issue with Qobuz password containing special characters.
3.
Fixed
  • Changed the audio resample algorithm to improve output audio quality.
4.6.404536
Release date: January 17, 2022
1.
When the Aux-in cable is plugged in, the system automatically switches to Aux-in source input without need choosing the Aux-in as the input from the App. Also, the Aux-in capture quality is improved.
2.
Fixed
  • Make 2 Vrms as the default. For the headphone output, choose 1 Vrms on WiiM Home App.
4.6.340033
Release date: December 28, 2021
1.
Merged Wi-Fi kernel patch to improve Wi-Fi connection stability.
2.
Fixed
  • High memory issue when Spotify is playing.
4.6.338934
Release date: December 17, 2021
1.
New Feature
  • TIDAL Connect support
  • Now you can stream your favorite music seamlessly from the cloud straight to your devices in the TIDAL app.
2.
Fixed
  • Optical SPDIF LED light is off when nothing is playing.
4.6.336043
Release date: November 23, 2021
1.
Fixed the sound distortion via Aux in.
2.
Fixed popping noise issue.
