Yes. It will perform the analog to digital then pass through to Aux-output. You can apply the EQ processing there too. It will do auto switching if you stream the music from your music services. However, to switch back to aux-input, you need switch it on the WiiM App.
Can I run pc to aux-in and have that audio play using aux-out? Will the audio convert to digital or pass-through? Will it auto switch to streaming? Print
Modified on: Wed, Sep 21, 2022 at 5:36 AM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
