TABLE OF CONTENTS
This tutorial will walk you through the various methods to stream your iTunes music to your WiiM device. Whether your iTunes library is on your PC or synchronized to your iPhone, you have several options to stream your music to your WiiM device.
Stream iTunes Music from iPhone
If the iTunes music is synchronized to your iPhone, you can stream music to your WiiM device using one of the following options:
Option 1: Using WiiM Home App
- Open the WiiM Home app on your iPhone.
- Go to the Browse tab.
- Select My Music in the My Library section.
- Tap iPhone to open the iTunes library.
- Select a track to play. The music will stream to your WiiM device.
Option 2: Using Apple Music
- Open Apple Music on your iPhone.
- Go to the Library tab to access the iTunes library.
- Play music and stream it to your WiiM device via Bluetooth, AirPlay or Optical port. For details, refer to How to Stream Apple Music to Your WiiM Devices.
Stream iTunes Music from PC
You can directly use iTunes to play music on the PC and then stream it to your WiiM device using any of the following options:
Option 1: Using AirPlay
If your WiiM device supports AirPlay (check AirPlay compatibility in List of WiiM Devices Supporting AirPlay 2), you can stream music directly from your iTunes library to your WiiM device using AirPlay. For detailed instructions, refer to Streaming audio to WiiM device via AirPlay with iTunes on Windows PC.
Option 2: Using Bluetooth
If your PC has built-in Bluetooth, you can easily stream music to your WiiM device using Bluetooth. For details, refer to How to Stream Music to Your WiiM Device Using a PC.
Option 3: Using Physical Connections
If your PC has a compatible output interface (e.g., Line Out or Optical Out), you can directly connect your PC to your WiiM device using the appropriate cable. This provides a reliable, wired connection for streaming music from your PC to your WiiM device.
Select the option that suits you best and enjoy seamless streaming.
