Please follow these steps to assign a static IP address for your WiiM device on your NETGEAR Nighthawk MR60 router:
- Launch a web browser from a computer or mobile device that is connected to your router’s network.
- Enter http://192.168.1.1 . A login window displays.
- Enter the router user name and password.
- The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
- Select ADVANCED > Setup > LAN Setup and scroll down.
- Tap the Add button under Address Reservation and choose your WiiM device.
Tap the Add button to save the above configuration.
