Unfortunately, the Spotify app does not support displaying sample rate or bit depth information. As a result, this information cannot be viewed in either the WiiM Home app or the Spotify app.
How can I see Spotify Connect's sample rate and bit depth? Print
Modified on: Mon, Dec 22, 2025 at 4:48 PM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
