Benefits of Adding USB Output Mode to WiiM AMP / WiiM Ultra
Enhanced Digital Audio Quality: USB output ensures high-quality digital audio transfer, maintaining the integrity of the audio signal without the degradation that can occur with analog connections.
Compatibility with Modern Digital Devices: Many contemporary audio sources, such as computers, smartphones, and digital audio players, come equipped with USB ports. This makes it seamless to connect these devices directly to the audio receiver.
User Convenience: USB connections are typically plug-and-play, allowing users to easily connect and disconnect devices without needing to switch cables or navigate complex setup procedures.
Increased Versatility: With USB output, the audio receiver can be connected to a variety of digital-to-analog converters (DACs). This flexibility allows users to upgrade their audio setup effortlessly and achieve superior sound quality.
How to Use USB Output with WiiM AMP / WiiM Ultra
Step 1: Connect a sound card or DAC to the USB port, and ensure the speakers connected to the DAC or sound card are working properly.
Step 2: Select USB Output in the WiiM Home APP:
  1. Go to Device Settings.
  2. Navigate to Sound (Audio Output).
  3. Select USB Out.
You can also select USB Output directly from the playback interface.
Once these settings are configured, the music played through your WiiM AMP / WiiM Ultra will be output via USB.
