The WiiM Amp, WiiM Amp Pro and WiiM Ultra feature a USB output for high-resolution audio playback. This tutorial will guide you through the steps to use the USB output on these devices.
Benefits of USB Output
- Enhanced Digital Audio Quality: USB output ensures high-quality digital audio transfer, maintaining the integrity of the audio signal without the degradation that can occur with analog connections.
- Compatibility with Modern Digital Devices: Many contemporary audio devices (e.g., DACs) come equipped with USB ports. This makes it seamless to connect these audio devices directly to the WiiM Amp, WiiM Amp Pro, and WiiM Ultra.
- User Convenience: USB connections are typically plug-and-play, allowing users to easily connect and disconnect devices without needing to switch cables or navigate complex setup procedures.
- Increased Versatility: With USB output, the WiiM Amp, WiiM Amp Pro, and WiiM Ultra can be connected to a variety of Digital-to-Analog Converters (DACs). This flexibility allows users to upgrade their audio setup effortlessly and achieve superior sound quality.
How to Use USB Output
Before You Begin
- Check the power specification of the USB port in Compatible USB Drive Specifications for WiiM Ultra or Compatible USB Drive Specifications for WiiM Amp or WiiM Amp Pro. If your DAC requires more power, prepare a powered USB hub.
Steps
- Connect a DAC to the WiiM Amp, WiiM Amp Pro or WiiM Ultra using the option based on your situation:
– Option 1: If a powered USB hub is not required, connect the DAC directly to the WiiM device’s USB port using a USB cable.
– Option 2: If a powered USB hub is required, first connect the powered USB hub to the WiiM device’s USB port using a USB cable, then connect the DAC to the powered USB hub using another USB cable. - Open the WiiM Home app.
- Select the USB output in the WiiM Home app using any of the following options:
- Option 1: Navigate to Device Setting > Audio Output, and select USB Out.
- Option 2: Tap the
icon at the bottom of the Now Playing page and select USB Out.
Now, music played through your WiiM Amp, WiiM Amp Pro, or WiiM Ultra will now be output via USB.
