Introduction
Each input source might have different audio characteristics. For example, a TV might produce different audio profiles compared to a streaming device or a CD player. Tailoring the EQ for each source ensures optimal sound quality for each type of audio.
Per-Source EQ: This feature allows you to customize EQ settings for each audio source input. It ensures that your listening experience is finely tuned and personalized for different inputs.
One of the advantages of Per-Source EQ is its flexibility. You can assign the same custom EQ settings to multiple inputs, as well as save, modify, or delete the EQ parameters for each source without affecting the settings of other input modes.
Step-by-Step Guide to Using Per-Source EQ
To effectively use the Per-source EQ feature on your WIIM Pro device with the WiiM Home app, follow these straightforward steps:
1. First, make sure you have the latest version of the WiiM Home App (version 2.8.8 or higher), which is available for download from the App Store or Google Play.
2. Launch the WiiM Home app and go to the 'Device' tab.
3. In the 'Device' tab, find and tap on the gear icon to access your device settings. Then, select the EQ option.
4. On the EQ screen, you will see the EQ settings for the currently selected input source of your device. Here, you can adjust the EQ parameters in the same manner as before, including switching between Graphic EQ and Parametric EQ modes.
5. To view and adjust EQ parameters for different input sources, tap on the input source button.
*Important Reminder: When adjusting the EQ parameters for a specific input source, ensure that your device is set to that particular input mode. For example, if you want to adjust the EQ for 'Line in' mode, make sure the device is currently in 'Line in' input mode.
By following these instructions, you can effectively utilize the Per-source EQ feature, allowing you to customize your audio experience according to your individual preferences and the unique characteristics of each audio source.
