Play multi-room audio using Control Center on your iPhone or iPad
You can select specific music to play from the Music app (or any third-party music streaming app) and then use Control Center to set up multi-room playback.
  1. Select and play the audio you want to listen to from your preferred app.
  2. Access Control Center on your iPhone or iPad.
  3. Press and hold the Music Control panel.
  4. Select the audio track you want to play on multiple AirPlay 2 speakers.
  5. Tap the AirPlay icon.
  6. Select multiple AirPlay 2 speakers.
The audio will begin playing in every room that you selected the AirPlay 2 supported speakers for. You can also adjust the volume for each speaker separately or for all of them at once.
