This's very interesting use case. If you can connect it with your phone hotspot, it should work. We'll check it to make sure it can be used as that way. If not, we'll provide a way for this use case. Thank you for bringing up such an interesting use case.
Can WiiM work in a car? using only as an Airplay receiver? Print
Modified on: Tue, Sep 20, 2022 at 2:38 PM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
