You can use the WiiM Home app to customize the standby screen wallpaper to match your personal preference. This article will guide you through the steps.
 Step-by-Step Instructions
  1. Open the WiiM Home app.
  2. Go to the Devices tab, and tap the Device Settings icon of your WiiM Sound.
  3. Navigate to Screen Settings > Standby Screen Wallpaper.
    Note: Keep the Screen Display setting enabled. If it is turned off, the WiiM Sound’s screen won't display anything.
  4. Customize the clock style using one of the following two options:
  • Option 1: Directly select a clock wallpaper from Analog Clock, Digital Clock, or Live Clock.
  • Option 2: Choose custom wallpapers as below:
  1. Tap Choose Photos in the Wallpaper section.
  2. Tap Choose Photos at the top to select photos from your phone's photo library. You can also select preset wallpapers in the Featured tab.
    Note: You can choose up to 16 wallpapers, and they will display in rotation during standby.
  3. Select a clock face in the Clock Face tab.
  4. Once done, tap Save in the top-right corner.
With these steps, you can easily personalize the standby screen to best match your preference.
