Transform your living space into an immersive concert hall by connecting a USB disk to your WiiM Amp Ultra.
To achieve the best performance and ensure compatibility, it's essential to know which USB disk types and power specifications are supported by your WiiM Amp Ultra.
Supported USB Disk File Formats for Your WiiM Amp Ultra
Using the following file formats guarantees smooth operation and integration with your WiiM Amp Ultra:
  • NTFS
  • EXT4
  • FAT32
  • exFAT
  • VFAT
USB Port Power Specifications on Your WiiM Amp Ultra
Below are the detailed USB port power specifications:
  • Voltage Range: 5V
  • Current Capacity: 1.5A
This makes the USB port suitable for most standard USB disks (SSDs), allowing you to use them efficiently without needing any additional power source.
Additional Power Source for External Hard Disk Drives (HDDs)
For HDDs, an external power source is required to ensure proper functionality. This is because HDDs typically demand more power, which usually exceeds the USB port's power capacity.
USB Indexing
The WiiM Amp Ultra supports the USB indexing feature. After connecting a USB device (e.g., a USB disk, SSD, or HDD) to the WiiM Amp Ultra, you can use this feature to index its music files and create a USB media library, making it faster and easier to access your stored music.
For details, see
Building and Managing Your Advanced USB Media Library and Best Practices for Using a USB Music Library
Summary
Following these power guidelines, you can expand your audio experience with your WiiM Amp Ultra and enjoy diverse music and audio content. At the same time, you are confident that your USB disk is compatible and operating effectively.
