TABLE OF CONTENTS
- Benefits
- Enable Android Widget and Lock Screen Control
- How to Use Android Widget and Lock Screen Control
- Limitations
The WiiM Home app now features Android Widget and Lock Screen Control to simplify your music control. With this feature, you can control music playback directly from the lock screen and notification panel, without opening the app. In this tutorial, we will guide you through how to use this feature.
Benefits
Quick Access and Enhanced Convenience
Instantly control music playback without the need to navigate through multiple screens or apps, making your experience faster and more enjoyable.Effortless Volume Control
Quickly adjust the volume using your mobile device's volume buttons for easy and convenient sound control.Direct Access to WiiM Home App
With one tap, you can quickly open the WiiM Home app for more controls and settings.Seamless Multitasking
While using other apps or even when the Android device is locked, you can still control music playback. This helps you continue with other tasks without interrupting your music experience.
Enable or Disable Playback Control on Lock Screen
By default, this function is enabled. You can manually turn it off or re-enable it at any time by following these steps:
- Open the WiiM Home app on your Android device.
- Go to the More tab and tap App Preferences.
- Toggle Allow playback control on lock screen on or off.
While playing music from the WiiM Home app, you can control playback directly from the lock screen and notification panel.
Scenario 1: From the Lock Screen
If your Android device is locked, simply tap the screen to view music information, control playback (e.g., Play/Pause, Next, Previous) and adjust volumes. You can also tap the widget to quickly open the WiiM Home app for more controls.
Scenario 2: From the Notification Panel
If your Android device is unlocked, swipe down from the top of the screen to access the notification panel. From there, you can view music information, control playback (e.g., Play/Pause, Next, Previous), and adjust volumes. You can also tap the widget to quickly open the WiiM Home app for more controls.
Limitations
While the Android Widget and Lock Screen Control feature offers convenient playback controls, there are a few limitations to be aware of:
- It does not support certain music sources, casting methods, or physical inputs, including:
- Chromecast
- Spotify Connect
- QQ Music
- TIDAL Connect
- Qobuz Connect
- Bluetooth
- DLNA Cast
- AirPlay
- Alexa
- TV
- Line In
- Optical In
- Phono In
- When the mobile device is connected to your WiiM device via Bluetooth, you cannot adjust the volume using the mobile device's volume buttons, regardless of the audio source.
