If your home network is unavailable, you can set up a mobile hotspot to keep your WiiM device connected and running smoothly. This guide provides clear instructions to help you connect your WiiM device to a mobile hotspot effortlessly.
Before You Begin
Prepare two mobile phones:
  • Mobile Phone A: Used to set up a hotspot.
  • Mobile Phone B: Install the WiiM Home app to set up your WiiM device.
Steps to Connect Your WiiM Device to Hotspot
  1. Set up a mobile hotspot on Mobile Phone A and set the password for the hotspot.
  2. Connect Mobile Phone B to the hotspot.
  3. Open the WiiM Home app on Mobile Phone B.
  4. Press and hold the Play button on your WiiM device for 3 seconds until the LED indicator starts flashing white. This puts the device into Wi-Fi setup mode.
  5. When the Set Up pop-up appears in the app, tap it to begin the setup process.
  6. Follow the on-screen instructions to complete the setup.
    During the process, select the hotspot from the network list, enter the password, and connect your WiiM device to the hotspot.
By following these steps, you can quickly connect your WiiM device to a mobile hotspot and continue enjoying uninterrupted audio streaming.
