This article will introduce the controls, interfaces, and indicator lights of the AudioPro A10 MKII WiiM Edition.
Top Panel Controls and Lights
Each numbered control and light on the top panel is explained below:
Volume LEDTen LEDs indicate the volume level of the AudioPro A10 MKII WiiM Edition.
Source SwitchPress to switch the input source among Wi-Fi, Bluetooth, and AUX.
Play/PausePress to start or pause the playback.
Volume ControlPress "+" to increase the volume or "–" to decrease it.
Preset
Press buttons 1~4 to play the corresponding presets.
Power/StandbyPress to put the AudioPro A10 MKII WiiM Edition into standby mode or wake it.
Bluetooth PairingPress to initiate Bluetooth pairing only when Bluetooth mode is selected.
Note: If switched to Bluetooth mode without an existing connection, the device will automatically enter Bluetooth pairing mode.
Wi-Fi Status LEDIndicate the Wi-Fi connection status:
  • Slow flashing white: waiting for Wi-Fi setup.
  • Fast flashing white: Connecting to Wi-Fi/Restoring factory settings.
  • Solid white: Connected to Wi-Fi.
Bluetooth Status LEDIndicate the Bluetooth connection status:
  • Slow flashing white: waiting for Bluetooth pairing.
  • Solid white: Bluetooth paired.
AUX Status LEDIndicate the AUX connection status:
  • Solid white: AUX mode is selected.
Back Panel Controls and Interfaces
Each numbered control and interface on the back panel is explained below:
Wall Mount HoleUsed to mount the AudioPro A10 MKII WiiM Edition on a wall bracket.
ResetPress to enter Wi-Fi setup mode.
Press and hold for 10 seconds to restore factory settings.
3.5mm AUXConnect to external audio sources, such as CD players and audio players, for analog audio input.
Power Input100-240V AC input, 50/60 Hz
