This article will introduce the controls, interfaces, and indicator lights of the AudioPro C10 MKII WiiM Edition.
Top Panel Controls and Lights
Each numbered control and light on the top panel is explained below:
Power/StandbyPress to put the AudioPro C10 MKII WiiM Edition into standby mode or wake it.
Source SwitchPress to switch the input source among Wi-Fi, Bluetooth, and Line-In.
Bluetooth PairingPress to initiate Bluetooth pairing only when Bluetooth mode is selected.
Note: If switched to Bluetooth mode without an existing connection, the device will automatically enter Bluetooth pairing mode.
Volume ControlPress "+" to increase the volume or "–" to decrease it.
Preset
Press buttons 1~6 to play the corresponding presets.
PreviousPress to go back to the previous track.
Play/PausePress to start or pause the playback.
NextPress to skip to the next track.
Wi-Fi Status LEDIndicate the Wi-Fi connection status:
  • Fast flashing white: Waiting for Wi-Fi setup.
  • Slow flashing white: Restoring factory settings.
  • Solid white: Connected to Wi-Fi.
Bluetooth Status LEDIndicate the Bluetooth connection status:
  • Flashing white: Waiting for Bluetooth pairing.
  • Solid white: Bluetooth paired.
Line-In Status LEDIndicate the Line-In connection status:
  • Solid white: Line-In mode is selected.
Back Panel Controls and Interfaces
Each numbered control and interface on the back panel is explained below:
Line InConnect to external audio sources, such as CD players, audio players, for analog audio input.
Sub OutConnect to a powered subwoofer.
ResetPress to enter Wi-Fi setup mode.
Press and hold for 10 seconds to restore factory settings.
Power Input
100-240V AC input, 50/60 Hz.
