When switching between input sources, variations in volume levels can disrupt your listening experience. Maintaining consistent volume levels across different input sources on your WiiM device ensures a seamless listening experience.
This tutorial will guide you through achieving consistent volume levels using two options: Per-Source Pre-Gain and Per-Source Volume Control.
Option 1: Per-Source Pre-Gain
The Per-Source Pre-Gain feature provides precise control over the input levels of individual sources before they reach the main volume control. By adjusting the pre-gain for each source, you can achieve balanced volume levels across all input sources, minimizing noticeable differences when switching between these input sources.
Follow these steps to adjust pre-gain per audio input source:
- Open the WiiM Home app.
- Go to the Devices tab.
- Tap the Device Settings icon
of your WiiM device. - Select Audio Input.
- Expand the Pre-Gain section by clicking the drop-down arrow.
- Adjust the pre-gain value for each input source by dragging the slider to your desired level. Alternatively, tap Reset to Default to reset all input modes to their default pre-gain level (0 dB).
- Switch between input sources and play audio to verify the volume levels.
- If needed, return to the settings to make additional pre-gain adjustments.
Option 2: Per-Source Volume Control
The Per-Source Volume Control feature allows you to adjust volume levels of different audio input sources, ensuring a consistent sound across these sources.
You can also use the Per-Source Volume Control feature to customize volume levels for audio input sources, creating a tailored listening experience.
Follow these steps to adjust volume levels per audio input source:
- Enable Per-Source Volume Control.
- Switch between input sources and play audio to fine-tune their volume levels, ensuring consistent sound across these sources.
By following these options, you can enjoy a consistent audio experience across all input sources on your WiiM device.
