For Apple users, AirPlay has been a reliable way to stream music across devices. But with WiiM Ultra, which doesn’t support AirPlay, you still have plenty of options to enjoy high-quality audio. Here’s how you can use Bluetooth to stream your favorite content from Apple Music or other services and even set up a multiroom audio experience that rivals AirPlay’s functionality.
1. Stream Apple Music and SiriusXM with Bluetooth—No AirPlay Needed
Though AirPlay isn’t available on the WiiM Ultra, Bluetooth offers a high-quality alternative for streaming from Apple Music, SiriusXM, or any other app not integrated into the WiiM system. Bluetooth on WiiM Ultra supports 256kbps AAC lossy audio, which is the same quality that AirPlay delivers.
This means you can continue to stream your favorite Apple Music playlists or SiriusXM channels via Bluetooth without compromising on sound quality. It’s a seamless way to enjoy your content without the need for AirPlay, giving you greater flexibility in how you use your Apple devices with WiiM Ultra.
2. Multiroom Audio with Bluetooth—Seamless Sound Across Your Home
One of AirPlay's strengths is its ability to play music across multiple rooms. WiiM Ultra replicates this feature using Bluetooth, allowing you to group several WiiM devices together. When you connect your Apple device to one WiiM Ultra via Bluetooth, the grouped devices can play the same audio in sync, creating a multiroom audio setup.
And just like with AirPlay, the audio quality remains consistent at 256kbps AAC lossy. This gives you the same high-quality listening experience, even when you’re using Bluetooth instead of AirPlay.
Embracing Bluetooth on WiiM Ultra
For Apple users, transitioning from AirPlay to Bluetooth might seem like a big change, but with WiiM Ultra, you can enjoy the same level of audio performance. Whether you’re streaming Apple Music or setting up multiroom audio, Bluetooth ensures you get high-quality sound without the need for AirPlay. WiiM Ultra empowers you to enjoy your favorite music, on your terms, with reliable Bluetooth streaming.
