Overview
When you connect a USB drive with a large music library to your WiiM Amp or WiiM Ultra, you can enhance your experience with faster music discovery and better playback through our advanced media library. Follow these steps to build a premium media library from your USB drive:
Key Improvements:
- Instant access to your content
- Enhanced metadata management
- Improved user interface
Step-by-Step Guide to Using USB Manual Scan with WiiM Amp/WiiM Ultra
Step 1: Power on your WiiM Amp/WiiM Ultra, connect it to the Internet, and insert your USB drive into the USB port of the device.
Step 2: Open the WiiM Home App, navigate to the ‘Browse’ tab and scroll to the bottom.
Step 3: Tap ‘USB’. When the ‘USB Disk Detected’ pop-up appears, tap the ‘Scan Now’ button to start scanning the song files on your USB drive. This may take a few minutes.
Step 4: Once the scan is complete and 'Scan finished' is displayed, tap the 'Let's Get Started' button. You will now see all the songs available.
Step 5: To access your USB Media Library, refer to Step 2, or navigate to the ‘Browse’ tab and select ‘Home Music Share’. The USB Media Server of your WiiM Amp/WiiM Ultra will be displayed. You can enter the USB Media Server to play your songs.
Step 6: If there are new songs added or deleted in your USB drive, you can click '...' , then tap the ‘Rescan Your Music Server’ button to rescan to update the song list.
Summary
By following these steps, you can easily build and maintain an advanced media library on your WiiM Amp or WiiM Ultra using your USB drive. With instant access, enhanced metadata management, and an improved user interface, your music experience will be seamless and enjoyable. Remember to periodically rescan your USB drive if you add or delete songs to keep your library up to date.
By following these steps, you can easily connect your WiiM Amp/WiiM Ultra to use USB Media Library.
