TABLE OF CONTENTS
- Supported WiiM Devices
- Stream Music to a WiiM Device via TIDAL Connect
- Control Playback
- Play Multi-Room Music via TIDAL Connect
- Issues and Solutions
TIDAL is a high-fidelity music streaming service that offers a vast library of songs, albums, and curated playlists—with support for lossless audio, Hi-Res FLAC, and exclusive artist content. With TIDAL Connect, you can stream music directly from the TIDAL app to compatible devices and control playback seamlessly within the app.
This tutorial will guide you on how to stream music to your WiiM device using TIDAL Connect for a seamless and high-quality listening experience.
The following WiiM models are compatible with TIDAL Connect:
- WiiM Mini
- WiiM Pro
- WiiM Pro Plus
- WiiM Amp
- WiiM Amp Pro
- WiiM Ultra
- A10 MKII WiiM Edition
- C10 MKII WiiM Edition
Before You Begin
- Install the latest version of the TIDAL app on your mobile device.
- Ensure your compatible WiiM device is updated to the latest firmware.
- Connect both your mobile device and WiiM device to the same network.
Step-by-Step Instructions
- Open the TIDAL app on your mobile device.
- Select your favorite music to play and then go to the Now Playing page.
- Tap the TIDAL Connect icon
in the top-right corner, then choose your WiiM device from the list.
If the TIDAL Connect option is not available on your iPhone, see Troubleshooting: TIDAL Connect Option Missing on iPhone for solutions. - Now, music will play on the selected WiiM device.
Control Playback
From the Now Playing page in the TIDAL app, you can control playback directly, including:
- Play/Pause
- Skip to Next
- Move to Previous
- Adjust Repeat or Shuffle mode
To stop TIDAL Connect streaming, select your mobile device from the list. Music will then switch back to playing through your mobile device.
Follow these steps to play multi-room music via TIDAL Connect:
- Create a WiiM multi-room group in the WiiM Home app. For detailed instructions, see How to Use WiiM Multi-Room Music to Enhance Your Listening Experience.
- Play music in the TIDAL app and stream music to the WiiM multi-room group. The group name will match the group lead device.
- Music will automatically play across all WiiM devices in the group.
If no devices appear in the list, go to your mobile device's Settings , and ensure that Local Network access is enabled for the TIDAL app.
