While WiiM device and other AirPlay-enabled products operate on different streaming platforms and cannot be used interchangeably, they can be grouped together for a seamless audio experience using AirPlay. This guide provides step-by-step instructions on how to do this. For a detailed tutorial, please refer to this video guide.
Steps to Group and Play Music:
1. Controlling Playback from an Apple Device:
- For iPhone X or later, or iPad with iPadOS or later: Swipe down from the upper-right corner of the screen.
- For iPhone 8 or earlier, or iOS 11 or earlier: Swipe up from the bottom edge of the screen.
2. Accessing AirPlay:
- Touch and hold the audio controls in the upper-right corner of the Control Center.
- Tap the "AirPlay" icon.
3. Selecting Devices:
- Choose both the WiiM Mini and the AirPlay-enabled speaker from the list of available devices.
- Select a song or audio track to play.
Streaming Audio via AirPlay from Apps:
- Open any app that you want to stream audio from.
- Tap on the AirPlay icon within the app.
- Select the WiiM Mini and/or other desired AirPlay-enabled speakers.
For WiiM Mini Owners:
- Apple Device Users: Utilize AirPlay to stream from services like YouTube Music.
- Android Device Users: Use Bluetooth for audio streaming. Connect your device to the WiiM Mini and play music through the digital (SPDIF) or analog (Line out) outputs.
For WiiM Pro/WiiM Pro Plus/WiiM Amp Owners:
- Use Google Cast to cast YouTube Music to your WiiM device.
- Once cast, the audio can be played through the digital (SPDIF, Coaxial) or analog (Line out) outputs.
