1. Add Your Favorite Music Services
- Open WiiM Home App.
- Tab Browse "
" at the bottom.
- Select your favorite music services and sign in with the corresponding account.
- Tap "Manage Music Services" to see more services.
2. Rename WiiM
- Tab Device "
" at the bottom.
- Tap "
" on your device and select Rename.
- Choose or fill in your desired name.
- Tap the Finish button to save on the upper right corner of the screen.
3. Switch Audio Source(Wi-Fi/Aux-In/Bluetooth)
- Tab Browse "
" at the bottom
- Scroll down and select a source in “Select source on device”
4. Sleep Timer Setup
- Enter Now Playing screen and tap "
" the button
- Select Sleep Timer and choose the time
5. Act as a Bluetooth speaker
- Press and hold the +&- for 3s on your WiiM Mini or switch the BT audio source in WiiM Home App.
- Open Bluetooth settings on your computer, mobile device, and more.
- Scan the Bluetooth devices nearby.
- Select the device with the name WiiM Mini_xxxx to pair.
6. Restore factory settings
- Press and hold the "
” on your WiiM Mini
- Open WiiM Home app.
- Tap Device "
" at the bottom.
- Tap "
" on your device and select Speaker Info.
- Tap Restore Factory Settings and Confirm this operation.
7. Volume Limit
- Tap Device "
" at the bottom.
- Tap "
" on your device and select Volume Limit.
