When you select the Device tab > Tap the device setting gear icon > Network Status.
You can turn off the "Enable WiFi" option there.
If you want to connect to Ethernet, select the Browse tab > Go to the bottom of the page > Select source > Ethernet. Make sure the Ethernet cable is plugged into the WiiM Pro.
